Whats the best adhesive to glue ceramic magnets on Polk 6.5" drivers?
Im on my way to get some JBWeld. Im not sure which type I will end up with yet though. Probably doesnt matter other than avoiding obvious like types for "underwater use"; wood etc. I think there is a set with 2 seperate tubes and a set with 2 syringes together with 1 plunger for easy application.
When freedom is outlawed, only outlaws are free...
  • tonyp063
    tonyp063 Posts: 1,142
    edited August 2016
    Loctite Power Grab is what you want to use.
    Home Depot carries it
    See the pics in this thread
    http://forum.polkaudio.com/discussion/171529/polk-10b-monitors-crossovers-and-tweeter-upgrades
  • Nightfall
    Nightfall Posts: 10,083
    afterburnt wrote: »
    Village Idiot of Club Polk
  • lawdogg
    lawdogg Posts: 469
    I've re-set many magnets and have found 2-part epoxy to be the superior adhesive.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • drumminman
    drumminman Posts: 3,396
    I used JB Weld, the original 2 part epoxy (the dark stuff). Takes a while to cure, but it really holds.
    msg Posts: 10,510
    NF, what are the Sharpies and drill bit for?
  • tat
    tat Posts: 159
    Well I left before the Power Grab was suggested so I picked up some ACE brand Quick Set Epoxy (2 part) 1500psi. The power Grab looks like it is easy to work with and make inconspicuous. Im sure they all work fairly well if applied accurately.
    I was a bit confused by the attchd thread that has pics of disassembled 6.5" driver along with explanations on how to glue it up. I was going to just run a bead along the top of the magnet (with speaker face down) where it meets frame. But it looks like the above thread has several other places it suggests treating.
    F1nut Posts: 52,101
    edited August 2016
    I thought I already cleared that question up for you. Apply it top and bottom, that's it.
    BTW, if you got the 5 minute epoxy you're going to have some messy fun. I suggest you return it and pick up the Power Grab.
  • gimpod
    gimpod Posts: 1,793
    NO KIDDING!! I did the drivers in my SDA 1C's with JBWeld before anyone around here started suggesting Power Grab and they look like fecal matter. I did 2 sets of spares with Power Grab. Sooooooooo much nicer and cleaner to work with plus this time I didn't end up gluing some Q-tip's, paper or my T-Shirt to a driver.
  • pkquat
    pkquat Posts: 748
    Its best to apply it on both sides of the magnet filling in the corner where it touches the plated steel,
  • tat
    tat Posts: 159
    Maybe ill get the grab. I just bought a pair of CRS as well so Ill have a bunch to do at once. I wasnt sure about the dual tweeter version of CRS (esp with SL1000), but theres a decent deal on these in great condition now and I dont wanna wait any longer lol. I have a pair of Peerless I can drop in for the stereo SL1000's if I find the 1000's tiring, but I suspect I will like the air. These peerless are smooth and unfatiguing though, best thing about these 7's.
  • Nightfall
    edited August 2016
    Peerless tweeters cannot be swapped around with any other tweeter Polk used except, IIRC, on the RTA-12B and C's which have the same crossovers regardless of tweeter. The Peerless tweeters absolutely crush the SL1000 and SL2000's, you will find that out in short order.
    afterburnt wrote: »
  • Nightfall
    msg wrote: »
    Larry's rings and marking cut lines on Dynamat.
    afterburnt wrote: »
  • tat
    tat Posts: 159
    edited August 2016
    Yeah the crossover is my worry, hopefully someone will chime in with a solution. I measured my Peerless both at 3. whatever ohms DCR (4 ohm impedance) but everyone keeps saying they are 8 ohm. Is there a known conflict with switching Peerless for Sl1000s in CRS's or is it merely potential problem bc of crossover change?
    I had the SL2000's and can recall the fatiguing spike but I also appreciated things about that tweeter.
    F1nut Posts: 52,101
    The CRS never came with SL1000 or Peerless tweeters. You cannot drop the Peerless into them either. Get the RD0194-1, which is the proper tweeter and better than the Peerless.
  • tat
    tat Posts: 159
    Well this 1984 pair has them in it. 4 of them. Ive heard that they even came with Peerless.
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    I don't think they came with peerless. They did come with the SL1000's in the early dual tweeter version. The main point that needs to be kept in mind, is that they are NOT interchangeable due to differences in the crossover. Best thing to do with all models is to upgrade to the RDO194's. No need to keep going around in circles on this.
  • westmassguy
    westmassguy Posts: 6,850
    Disconnect the outer dimensional tweeters, they're not needed.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    F1nut Posts: 52,101
    Maybe I am getting old and starting to forget stuff, but damn, I sure don't recall seeing SL1000's in the blade/blade CRS.
    F1nut Posts: 52,101
    TNHNDYMAN wrote: »
    Those don't even fit the openings properly.
  • TNHNDYMAN
    I had them in and out a couple times, but that is what was in them when I got them from a guy in Knoxville. I never really researched it to see if it was proper though.
    F1nut Posts: 52,101
    SOB, after hunting around online......yep, very early (1983) CRS came with SL1000's.
    txcoastal1 Posts: 13,519
    Betcha that drove you nuts :D
  • HzTweaker
    HzTweaker Posts: 1,065
    ^^ Am I the only one that found @F1nut 's last post funny?
    TNHNDYMAN wrote: »
    I bought the pair. I was getting ready to leave work early and check for myself.. .
    F1nut Posts: 52,101
    txcoastal1 wrote: »
    Drove my curiosity, that's for sure.
    txcoastal1 wrote: »
    So any prediction on differences in the crossovers??
  • tat
    tat Posts: 159
    Id love to hear people summarize that...
    I am pushing the Peerless bc 1) I have a pair on hand already and 2) they should fit the SL1000 routing. I would love to hear WHY the Peerless would be a poor match for the above model, I think the schematics are available here:
    http://forum.polkaudio.com/discussion/55888/polk-audio-speaker-wiring-schematics-more-stereo-dimensional-array-sda#latest
    https://us.v-cdn.net/5021930/uploads/attachments/1/8/5/1/1/26679.pdf
    F1nut Posts: 52,101
    Because the Peerless was never used in any SDA speaker. That I am 100% certain about. You can't go swapping tweeters or drivers around just because they have the same resistance. There are many other important parameters.
    F1nut Posts: 52,101
    txcoastal1 wrote: »
    txcoastal1 wrote: »
    No, but maybe we can get one of these guys to give us the values, which we can then compare to the SL2000 clad CRS.
  • tat
    tat Posts: 159
    I think the 2nd link I added is of the SL2000 bc it notes switch from fuse to protection. I havent seen an earlier schem.
