Signal Cable vs Monster Cable - Speaker Cable
dorokusai
dorokusai Posts: 25,576
Demo: Signal Cable Double Run (8ft Length) vs Monster Cable Original (8ft Length)
Receiver/Amplifier: Sony STR-DA2ES 6.1 AVR (2003)
Source: Sony CDP-745, 5 Disc Changer(1993)
Selections: School Of Fish(School of Fish)/ Sheryl Crow(Sheryl Crow)/ Luscious Jackson(Luscious Jackson)/ Maxwell(Embrya) I chose all self titled, because I was weird that day.
Speakers: Polk Audio RTi38, wall mounted on BT-77 BTech brackets(Dynamatted). 5 deg downtilt, 2 deg toe-in, 7 ft separation.
Enviroment: 13' x 18', basic room.
Listener(s): dorokusai
Demo: This is actually a preview of a full on review. The cables are not burned in enough to justify a full review, IMO.
I will offer my immediate thoughts, as the change in the sound was quite obvious.
Construction:
Signal Cable - The conductor - stranded high purity oxygen-free annealed copper
PE Insulation offers low capacitance and low series resistance for improved frequency response over long distance cable runs
Twisted design reduces Electro-magnetic interference (EMI) Noise
DC resistance/1000' - 4.5 Ohms
Nom. Capacitance - 4 pf/1KHz
(per Signal Cable website)
Simply put, the SC is an OFC heavy gauge wire covered in a PE jacket. The cables were pre-terminated with Analysis Plus Banana plugs on each end. Cable is covered in a black sleeve, crimps are solid and overall quality is hard-on level. This cable looks like its ready to kick your arse.
http://signalcable.com/images/DoubleRunSingleWire.jpg
Monster Cable -
ADVANCED TIME CORRECT HIGH DEFINITION SPEAKER CABLE
Time Correct windings and Magnetic Flux Tube constructions deliver a new level of speaker cable performance
The new Monster Cable uses large gauge construction for improved power transfer and adds the latest advances from Monster's highest performance audiophile cable designs. Special Time Correct windings control distortion producing magnetic fields for a smoother, more natural re-creation of the music. Patented Magnetic Flux Tube construction provides improved bass response and dynamic range, important for home theatre and top quality music systems. A special LPE jacket minimizes dielectric distortions for smoother, more natural sounding highs. These advanced technologies in the new Monster Cable provide impressive sonic improvements, allowing you to listen into the music to more realistically experience the original recorded performance.
Flexible, round jacket for easy routing and installation
The new Monster Cable also features an entirely new, flexible, round shape that allows it to be smoothly run through round holes for easy installation. And our DuraFlex jacketing which is UV stabilized, and abrasion and chemical resistant keeps the cable looking good as well as sounding good.
Patented 24k Angled Gold Pins with our Lock-Notch design for a superior connection
Monster Angled Gold Pins are designed to provide an excellent connection for both push-type connectors and popular 5-way binding posts. The convenient angle makes it easy to get to hard-to-reach places. And our OmniFlex color-coded insulators take the strain off the connecting point allowing flexible rotation in all directions.
Get all the sound you paid for. Monsterize your entire sound system
With new Monster Cable you'll be able to maximize your loudspeakers performance to get all the sound you paid for. For improved performance throughout the entire playback system, we invite you to audition our Interlink and Monster Video high performance audio and video interconnects for the best possible performance and the most enjoyment from all your audio and video components.
(per Monster Cable website)
Simply put, the MC is a OFC heavy gauge wire covered in a heavy duty LPE jacket. The cables were terminated with Phoenix Gold Banana BI-Plugs. It is not pretty like the SC. The cable is basically a raw OFC heavy guage cable covered in clear LPE. This is a higher level of MC speaker cable. I have owned this run for many years, and it is extremely burned in.
http://www.monstercable.com/productPage.asp?pin=39
The difference in jacket composition of both, is n/a or negligible.
Demo: My main keyword in the whole review, is Depth. The cables from minute 1, exibited more depth than the MC. It is hard to explain, but all the music auditioned thru them feels "heavier", feels more well developed. Everything played through my source, just feels like it has substance now, like....fook....I cannot explain it. The MIT's originally opened up my soundstage so much that I thought I would shite myself. The SC has been the best compliment to the MIT's AND my system. Thank You F1Nut for letting me demo your MIT babies....oh and keep them safe :D
Example: Maxwell(Embrya) was pronounced and punchy, I was realy impressed. The bass, was so tight, I heard the pad hitting the drum, not just the thump. Midrange for his voice was really motivating as a listener.
I honestly cannot expound on any benefits of the MC as oppossed to the SC in any way. The SC speaker cables completely blow them out of the water, IMO. This is just 2 hours into the configuration.
Conclusion: I feel the SC speaker wires from day 1, have outdone my years old MC. Is this a fair comparison? Yes it is. The price is very competitive, and comparable to its MC counterpart.
MC is not going to cut custom lengths for you either, so waste is a factor. The self-termination factor of the MC is fine if that's what you want, but the pre-terminated Analysis Plus goodies on the Double Run are so good looking you should re-consider. The SC is also available with un-terminated ends. Honestly, I think this is an outstanding cable, and the best value you could possibly ask for.
You will not be disappointed
I apologize if this has been a loose review.
Post edited by dorokusai on
«13
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited July 2003
    Great review. I wonder how the SC would stand up against the M1.4 I have?? Is the RTi38 bi-wireable?
    Signal Cable is good stuff and I have Russ to thank for recommending my Analog 2.
    Yes the Analog 2 is "just" Belden cable. But I did a search for the exact model # cable, and it turns out that particular cable is famous in DIY cable making circles and beats out OEM cables costs hundreds more.
    I'm sure Frank got his start in the DIY community, so none of this surprised me. The Belden he uses in the Analog 2 is only surpassed by another even more expensive Belden cable. I also read that the quality of the terminations makes a big difference with the Belden, and Frank doesn't skimp in that department.
    Doc
    SVS
  • polkatese
    polkatese Posts: 6,767
    edited July 2003
    Doro, great preview! I am glad you immediately experienced the difference! Back in '85, I bought a pair of MC original clear cable (heavy 12 gauges) and thought those were so special (since I paid premium back then, and not to mention that the wire myths was considered black magic by average joe) When I got my SC, I retired my MC and who knows, it might become a collectible vintage one of these days. Having said that, I recently missed out a great deal on HTF in which a MC M2.4 8ft was offered for $200 almost new. I am curious as to compare them, since M1.4 and M2.4 were the two MC reference with great review. They are overpriced, that's why I am interested to own if the price is substantially less (M2.4 8ft retailed north of $400)
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • dorokusai
    edited July 2003
    Thanks guys. :)
    No the RTi-38 isn't bi-wire capable, it would be a nice feature.
    I wanted to stay in the same theory of the MC wire, beings that it had individual runs for + and - . I have heard alot of good things about the M series, it would compare favorably I am sure. I am really just blown away with the quality of the cable, its nice and heavy also. The MC original just looks plain compared to high end speaker cables, MC M included. Belden is aok in my book, lol.
    The video cables and digital coax showed up today, so a mini-review will be coming for them also. Now I can actually hear DTS, this should be good :)
  • dcarlson
    dcarlson Posts: 1,740
    edited July 2003
    Sean, sounds like you really dig cables. ;) Right on man, why spend a $1000 on a component and never reach it's potiential by masking it with bad cables?
    I'll be getting a Signal Cable Magic Power Cord in the mail next week. I've never ventured into the power cord realm before. It should be interesting. After it burns in, I'll be borrowing a wack of power cords from my local shop and have a shoot out. It'll be fun.
    Here's a question. Could I burn in that power on my computer while I work? Or should burn it in through some audio equipment?
    Derick.
    SDA-2a, Anthem Pre-2L, Anthem Amp 1, MF A324 DAC, Rotel RCD1070
    Senn HD650 Cardas, Mapletree Audio Ear+ HD2, Kimber KS1030, Bel Canto DAC2, M-Audio Transit, Laptop.
  • mantis
    mantis Posts: 17,326
    edited July 2003
    You know at the end of the day it's not the brand on the cable it's the way it sounds that matters....
    Having said that Beldon cable company is a well respected custom wire company.I have used it for years with steller results.I don't however think it's better then most premade interconnects made by monstercable.DIY is something in custom we do every single day.I built thousands upon thousands of cables from speaker wires,digital coax,interconnects(Analog),Cable and dss feeds,Network cat5e,phone,etc.Proper termination is key.Poor ends result in poor performance.
    What Signal cable is offerring you is a nice quality hand built product that will out perform most cheaper interconnects.Once you get into higher quality interconnects and speaker wire,the signal cable/Beldon products start to be left behind.
    Doc your M1.4s will crush the 16/4 signal cable bi wires.Yes they cost 300.00 for a reason new.But for what your paying for the 16/4,it's a very fair price.If I was Frank and selling my cables,I would ask his prices or even maybe alittle more.Mantis cable might hold alittle more value then a Frank cable.........LOL!!!Huh...Mantiscable.......hmmmmm......Mantiscable.com.....
    All joking aside cool review.I dig wire shootouts.It doesn't really matter to me who wins or looses.It's the fact that you can hear a difference between the 2 cables is what tickles me.....Sweet.
    Dan
    www.mantiscable.com
    coming soon!
    Dan
  • Dr. Spec
    edited July 2003
    I'll take your word for it Dan. All I know is that I'm very VERY happy with your recommendations on the 3803, 2900, M1.4, and Russ' recommendation on the Analog 2. The combination is most excellent - synergy - the whole is greater than the sum of the parts.
    Doc
    SVS
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited July 2003
    Derick.
    The ideal way to burn in a power cable is with a high current power amplifier playing lots of bass heavy music.;)
  • TonyPTX
    TonyPTX Posts: 545
    edited July 2003
    Dan
    www.mantiscable.com
    coming soon!
    And they can be bright green and yellow. Some good model names, Locus, Grasshopper and Praying Mantis.
    Praying Mantis: One listen and you'll be dying over them....
    Damn....8 lines...I've gotta put my sig on a diet now....
  • mantis
    edited July 2003
    Waaaaaaaaaaaaaaaaaaaaah!
    Dan
  • Demiurge
    Demiurge Posts: 10,874
    edited February 2007
    I'm thinking about getting that speaker wire for the LSi15s. Anything else I should consider? I know Frank is the bees knees and all that, but I'm just curious if there are any others out there to think about before I make the dive?
    I tend to be pretty loyal, so if I buy 2 runs of wire for my mains and I like them, eventually my ICs, power cords, and other speaker wire will be Signal Cable.
    Anything will be a step up from what I have now.
  • Willow
    Willow Posts: 11,223
    right now the bulk of my cables are AQ, I have been very tempted to try SC, myself. and I like you would then need most of my cables if not all to match. could be pretty expensive. But I only hear good things about SC.
  • shack
    shack Posts: 11,154
    I have both AudioQuest and Signal Cable. I really like them both. Most of my speaker cables and power cables are SC while most of my interconnects are AQ. Back in the days of the Cable Swap I had an entire rig set up with Signal Cable and it was very nice. SC may be the better value.
    Some of the Anti HI-FI Audio Insurgents (I just love that phrase big Ted came up with) will probably jump in to tell you to get some lamp cord from Home Depot and call it a day. :rolleyes:
  • Ricardo
    Ricardo Posts: 10,636
    I have analog 2 IC's and l love them; AQ type 4 for speaker cables, but need another pair and SC seems like a good option....I've also been looking into the "anticables"...they are supposed to be good; anyone tried them? Great reviews...
    http://www.anticables.com/
    SOPA
  • Demiurge
    Most of the taste you guys have is far more refined than I could ever hope for myself. I can definitely tell a difference in quality cables and wire. If it's all in my head, well, I think it's worth the money.
  • MikeC78
    MikeC78 Posts: 2,315
    I'll say it first...
    Go get some lamp cord from Home Depot and call it a day.;)
    I'm still really not a firm believer that certain brands make a difference in sound as long as the quality is there.
    I did shell out a few bucks and get some BestDealcables speaker wires for my LSi15's and did notice a difference, just something I'd say very negligible.
    Maybe when we have the gathering this summer, I might change my mind.:cool:
    Mike
  • candyliquor35m
    candyliquor35m Posts: 2,267
    That reminds me, I need to pull Maxwell Embrya off the shelf and listen to it. I don't think I've listened to it on my current setup.
  • AndyGwis
    AndyGwis Posts: 3,655
    I picked up some SC double run locally for real cheap (only half was terminated) just to give it a shot.
    I love it. Quality of construction is awesome for the price. I was shocked at how thick and high-end it looked and felt. Heavy cables, and anything heavy seems to be better in this hobby.
    I'm definitely gonna try some of Frank's other stuff when I have a need.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    Let's just hope that JohnADA doesn't see this thread and start trashing it!
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    You know it ShackDaddy, one day we will shorten it to AHAI, we will talk about it when we meet to discuss the secret handshake.
    I am RT1 unclean, unwashed, unshaven, audio wire buying Infidel.
  • IanD
    IanD Posts: 59
    I was just thinkming that some of that there orange stuff from Home.......oh never mind.:) :):):):)
    Yamaha RX-V1500
    Pioneer Elite DV-46AV
    Scientific Atalana 8300 PVR-HD
    Panasonic TH-42PX60U
    Polk RTi10
    Polk CSi5
    Polk F/Xi3
    Polk PSW 350
    Mike's IC's
    DIY speaker cables (Kimber 4VS Shotgunned)
  • mantis
    Damn you guys keep digging up the old ones. But i love it.
    To answer your question, I suggest for your Lsi15's is Audioquest Rockefellers. Or stepping down to type 8 bi wires or straight 2 conductors will also work well.
    Good luck with your wires man.
    Dan
    Dan
  • TroyD
    TroyD Posts: 13,124
    WAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
    Dan busting out the old flava o' the month chart. Just like old times.
    BDT
  • Monster Jam
    Monster Jam Posts: 919
    Advanced Time Correct High Definition Speaker Cable?! Talk about Snake Oil - WOW!!! LOL
    Do you hear that buzzing noise? :confused:
  • mantis
    BDT
    oldies but goodies. You know you miss me.
    Dan:D
    Dan
  • dorokusai
    That's a bad **** album.
    I didn't realize until now, that this is one of my first, "useful" posts on the forum after I joined....before I became jaded and mean.
    It's still an excellent bang for buck cable and the construction makes BJC look like kindergarten toys. Canare terminations are lame.
  • ViperZ
    ViperZ Posts: 2,046
    edited March 2007
    Hey guys,
    I am currently looking for speaker wires, probably just for the surrounds, but if the deal is good, I'll rewire all 5 speakers.
    My setup is in the signature. The runs will be around 10 ft to each main, same to center, and around 25 ft to each surround speaker, so total 80 feet should do the trick.
    Can anyone recommend good wire, best "bang for a buck", either locally in Houston (Texas), Toronto (ON, Canada), or online? I am on a pretty tight budget, so probably 14 AWG will do (maybe 12 to mains?).
    Thanks!
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    edited March 2007
    Excellent review! Love my Signal speaker cables. :)
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
  • cyberhazard
    cyberhazard Posts: 67
    edited March 2007
    ViperZ wrote:
    Hey guys,
    Thanks!
    OK. First off, the longer the run the larger the wire. Not the other way around. But in your case, as short a your surround runs are 14 AWG will be good for everything.
    IMHO, the best "bang for the buck" is always DIY. Check out this excellent post by mlhm5,
    http://www.polkaudio.com/forums/showthread.php?t=49044
    There are also many online resources for speaker cables. Blue Jeans Cable, BetterCables, Signal Cable and AudioQuest just to name a few. What specialty cable shops offer is high quality materials put together in a painstaking fashion. Some use very exotic stuff and most are down right pretty.
    But know this. On the sonic front, and were talking speaker cables here not interconnects. When you start laying out the bucks, you quickly hit the point of diminishing returns.
    The Escape Pod Equipment
    Samsung HL-S5679W
    Sony STR-DA5200ES
    Outlaw 7125
    Sony 60GB PS3, Blu-ray Disc
    TiVo Series 3 HD
    Universal Remote Control MX-900
    Polk Audio LSi9 ebony, fronts
    Polk Audio LSiC, center
    Polk Audio LC65i in wall, surrounds
    SVS PB12-Plus Piano Black
    Outlaw PCA interconnects
    BetterCables for HDMI & SUB
    Master Bedroom
    Sony KDL-46XBR4
    Sony 40GB PS3, 2nd Blu-Ray Disc
    Polk Audio i-Sonic
  • josh_parsons626
    josh_parsons626 Posts: 219
    edited March 2007
    So, which do y'all like the best out of the 3? Monster Cable, Signal Cable, or AudioQuest?
    Don't forget to look at My Home Theater :D
    Receiver - Onkyo TX-SR503
    Fronts - Polk Audio Monitor 40
    Center - Polk Audio CS1
    Surrounds - Paradigm Cinema ADP
    Subwoofer - Velodyne VRP-1200
    F1nut Posts: 51,703
    edited March 2007
    And you know this, how?
