JL Audio F113
1235»
  • danz1906
    danz1906 Posts: 5,144
    edited February 2011
    rio203 wrote: »
    my ht
    Sweet!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • rio203
    rio203 Posts: 15
    i need that one more jl sub
  • toucanet
    toucanet Posts: 581
    Any of you guys using a JL sub with a two channel system?
    I am toying around trying to connect one of my F113s to my two channel system with no luck.
    I've calibrated the sub via the A.R.O. but very little sound is coming from the sub.
    I am using a Rogue Audio Magnum 99 Tube Preamp and two monoblocks. I have the RCA interconnect connected to the preamp's "Left" channel output (there are two sets of outputs on preamp) and the interconnect connected to the "Left or Mono" input on the back of the sub. The sub is set to the "Variable" setting instead of the "Ref" setting.
    Any suggestions?
  • Ern Dog
    Ern Dog Posts: 2,237
    First I would try to isolate where the problem is. Preamp? sub cable? sub?
    To check if its the preamp connection- unplug the speaker cable from your preamp and use one of those same outputs to your sub. If problem still exists, try a different sub cable.
    Maybe it's the setting on the sub. Check to make sure you have it set to "Master" and not "slave".
  • Ern Dog
    Has anybody tried using the Balanced inputs on your Fathom sub? What difference did you notice vs. the rca inputs?
  • DMara
    DMara Posts: 1,434
    Ern Dog wrote: »
    I tried but did not hear any difference in sound quality. Also the hum level when I put my ears right in front of the sub was the same, therefore I switched back to RCA to save me from installing a new line of in-wall XLR. By the way I only used Monoprice XLR, nothing fancy.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • danz1906
    edited March 2011
    DMara wrote: »
    Running balanced should be a little quieter and the bass a tad bit tighter.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • toucanet
    toucanet Posts: 581
    edited March 2011
    DMara wrote: »
    I haven't set them up yet since I'm still awaiting the long XLR cable for master-slave connection, therefore the grills are still off as of now.
    How do you like the "Master/Slave" connection? I ended up setting both subs as Masters. I purchased the xlr cable (BlueJeans) but have not moved the gear to connect it to the subs.
  • jjk_reef00
    jjk_reef00 Posts: 23
    edited March 2011
    I love JL products, I just need to scrape together the cash...
  • danz1906
    edited March 2011
    jjk_reef00 wrote: »
    You and me both Bro:tongue:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • Hawkeye
    Hawkeye Posts: 1,313
    edited March 2011
    I use a pair of 112's in my 2 channel system with XLR connectors. You might try using a splitter. Is the JL even turning on? Perhaps your not sending enough voltage to auto turn on? Suggestions: Buy pair and run them stereo!!:biggrin::biggrin:
    Gordon
    toucanet wrote: »
    Any suggestions?
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • Hawkeye
    edited March 2011
    toucanet wrote: »
    I tried the M/S combination but it did not give me enough room to tweak each sub for it's location. I set each one with the SPL meter and a test disc, then ran ARO independent of each other. Lots of work but worth the effort!!
    Gordon
    2 Channel -
  • toucanet
    toucanet Posts: 581
    edited March 2011
    Hi Gordon,
    Once I got behind my gear, I realized I had the RCA in the wrong input. once I corrected that minor detail, the pair were ready to rumble... and rumble they did.
    Since then, I have re-connected them back to my HT AVR. I was just curious as to how they would sound with two channel stereo.
    I'm running out of space in my media room with these toys!
  • toucanet
    toucanet Posts: 581
    edited April 2011
    For those of you that may be interested in the JL F212, someone on eBay is offering two of them in separate auctions:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160568761686&ssPageName=STRK:MEWAX:IT#ht_500wt_1156
  • danz1906
    edited April 2011
    toucanet wrote: »
    No bids so far 20mins to go!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • toucanet
    toucanet Posts: 581
    edited April 2011
    I'm surprised that not one bid has been submitted in either of the two auctions. I think that his starting bid is pretty good for the age of the subs.
    This is really tempting me.
  • danz1906
    edited April 2011
    toucanet wrote: »
    Go for it, I would if I had the Coin:tongue:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • toucanet
    toucanet Posts: 581
    edited April 2011
    I would definitely need to sell my pair of F113s if I grabbed these.
  • toucanet
    toucanet Posts: 581
    edited April 2011
    Someone got a good subwoofer for $3,000.00. The seller is liquidating all of his gear (4 McIntosh MC501 mono blocks and other items).
  • danz1906
    edited April 2011
    toucanet wrote: »
    Wow,,,,,,,,That was a great deal!!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • danz1906
    edited April 2011
    leroyjr1 wrote: »
    Let's make a Deal....You buy them and I will pick them up:tongue:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • JimAckley
    JimAckley Posts: 1,138
    edited April 2011
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • danz1906
    edited April 2011
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • JimAckley
    edited April 2011
    danz1906 wrote: »
    Expensive Subwoofer!
    $6,663 less than those twin-Gothams brand new, and it could become even cheaper if you take away little details like the granite and emblems, and switch the amps to the I-Tech 6000.
    - Computer Rig -
    - Main Rig -
