Greatest thing since sliced pizza?
stretchl
stretchl Posts: 1,334
Are any of you following the thread below on audiogon? Sounds like a lot of hogwash to me, but then again tin foil hats were never my style.
https://forum.audiogon.com/discussions/new-tweak-its-fantastic
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
  • decal
    decal Posts: 3,205
    Like all "tweak" threads, it's just a big pissing contest.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Not commenting on the efficacy, but it seems like a coordinated guerilla marketing campaign. Pretty incredible, though, how it can make a $10 CD player sound like a $10,000 model! :p
  • marvda1
    marvda1 Posts: 4,880
    edited June 2018
    I have some cerious technologies speaker cables and interconnects based on graphene, while they are great sounding cables they are not miles ahead of every other cable.
    www.cerioustechnologies.com
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
    msg Posts: 9,492
    edited June 2018
    I'm just here to say the thread title made me stop for a second, and gave me a chuckle.
    Just quickly skimmed a few of the posts in the other thread. Interesting idea in the name of "smoothing" or "closing the gap" in the conductivity path. It's something I'd be open to a demo for to satisfy the curiosity.
    mhardy6647 Posts: 33,083
    microarching, eh?
    Tiny bridges?
    Tiny ships from the old testament?
    maybe microarcing?
    (as if that were a thing)
    Clipdat Posts: 12,620
    Literally snake oil.
  • mlistens03
    mlistens03 Posts: 2,767
    The Audiogon thread says it makes a world of difference... yet somehow I still think it’s a “difference” I can’t hear... :tongue:
    Jumping off my AQ Type 2 review thread, I think you'd easily be able to hear the difference between standard speaker wire and the T2. Hope you can give it a try soon.
    mlistens03 wrote: »
  • mlistens03
    Clipdat wrote: »
    mlistens03 wrote: »
    I was talking in direct correlation to the “special paste” mentioned in that thread, not cables, I know that they’d make a difference. I will be getting cables when my gear sells, but I just have to wait for... well, my gear to sell.
    Micah
    Yeah I know you were talking about the aforementioned snake oil, it just reminded me of your situation and I got excited for you to hear the change between standard wire and the Type 2! :)
    mlistens03 wrote: »
    Well -- you know what they say...
    https://youtu.be/CbIhYhrOJAg
  • [Deleted User]
    [Deleted User] Posts: 7,658
    In my semi-humble opinion a similar improvement would be heard if all anyone did was disconnect and reconnect all pertinent connectors in an audio chain; from cartridge pins to RCA cables, fuses in fuse holders, speaker wire connections, circuit board edge connectors, AC cords and tape head blocks. Anyplace one piece of metal attaches to another.
    Even audio conservative Julian Hirsch felt that would improve things.
    Interesting. I've heard/read something from the opposite end of the spectrum, that you don't want to touch/disturb/move interconnects and speaker cables once you've installed or put them into place. The thought behind it is that as you use them, small cracks/fissures/pathways form on the surface of the copper wire where the electrical signal is traveling. Moving/bending the cable would disrupt those paths and they'd then have to be reformed by several hours of use.
  • [Deleted User]
    I know my system is a lot quieter if I don't disturb the on/off switch.
    Similarly, in terms of cable debates, I've always found that my hifi sounds considerably better with cables than without.
    Now I'll admit that the source material may have some impact on that.
    PS No offense meant to any Kenny G fans on the board -- whether you'd wish to cop to it or not.
  • kharp1
    kharp1 Posts: 3,453
    I'll admit to being somewhat of a fan...got lots of, umm, knowledge in the biblical sense. Went to two different concerts back in the early 90's with two different ladies that loved him. Was surprised that he really put on a good show and had a good band. He has a great sense of humor. The things I've done to get next to a girl.
  • kharp1
    kharp1 Posts: 3,453
    Back on topic, I prefer snail slime to coat all my contacts. It's organic.
  • [Deleted User]
    There was an electrical contact "enhancer" named Tweek that was highly touted for improving the quality of sound. And, I confess, it did seem to make a beneficial difference when used sparingly on connections that transferred small level signals. It was highly reviewed in both Stereophile and The Absolute Sound. The problem was that after some time the chemical composition of the material would change and conductivity would become intermittent, so you'd have one channel or both dropping out. Everybody had to cleanup all their "Tweeked" RCA plugs and sockets
    pitdogg2 Posts: 24,623
    I remember that.
  • mdaudioguy
    From the little I read, I got the idea that this new product was also from the same inventor as Tweek. I could be wrong, but I don't care enough to go back through the thread... I'll probably just go the rest of my life with sub-optimal connections. :/
  • verb
    verb Posts: 10,176
    I had to chuckle on that one. In the meantime the seller packed up his covered wagon and rode into the next town! :smile:
    F1nut Posts: 49,846
    I'll stick with Pro Gold.
  • westmassguy
    westmassguy Posts: 6,850
    I used it back in the day, and it worked initially, but after some time it "Hardened" to a glue like consistency. I ripped a few ground shields off trying to pry interconnects off my receiver or amp at the time.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • westmassguy
    microarching, eh?
    Tiny bridges?
    maybe microarcing?
    How can you have an arc, micro or otherwise, if the there's already a mechanical connection between the two metal contacts?
    microarching, eh?
    Tiny bridges?
    maybe microarcing?
    The ad copy invoked microarching -- I envision a tiny Utah landscape.
    Not sure what the sonic impact would be of that -- maybe tiny echoes?
    msg Posts: 9,492
    My understanding of this theory and all the micro talk was about how no hard metal surface is truly smooth at the micro level, hence the arcing (or arching for little Utahs), and that this conductive liquid fills in the gaps.
  • [Deleted User]
    edited July 2018
    Gentlemen, please remain on topic, thanks.
