Best powered Subwoofer out there?
I'm on the hunt for a thumper that won't break the bank.
Over the years I have heard that Velodyne is one of the best....is this true?
I used to have a CT-100 and I sold it like an idiot....shoulda kept it.
I have a 8in older polk PSW120 but it just don't have the "punch" I want.
I wanna sell it and get a worthy 10 or 12in replacement.
I wanna get something I'm happy with cuz I can't keep swapping out subs.
I'm looking for a versitile use Home Theater typa deal.
The Velodyne DPS-10 catches my eye.
Need your input cuz this is gonna be my last purchase for a while!
Yamaha RX-A710 90Watt 7.1
Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
Music CD: Sony CDP-CE375 5 Disk
HD TV: Vizio 42" LCD 1080p E420VO
Blu-Ray: Sony BDP-S350
DVD: Sony DVP-NC665P 5 Disk
AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
Phones: Sennheiser HD280 Pro
Post edited by Motzart on
I am sure there are lots to select from, but I am really happy with the SVS I purchased a few years ago. Definitely worth a look. Good luck.Michael
NORTH of 60° -
Is Dayton any good?
Never really heard of em but I see the boast some real high powered amps!
Phones: Sennheiser HD280 Pro -
Look into Martin Logan. I feel they make the best overall subs for the money. Musical and theater is excellent. The Dynamo and Grotto are not expensive and are so impressive.
Tweeter is going out of business so you could pick one up there cheap.
DanDan
Dan
No Tweeter near me!
What is "Not expensive"?
There is a ML dealer near me but NOTHING they sell is cheap.....very high end store!!
SVS or Epik should hold you down for a very long time.Shoot the jumper.....................BALLIN.............!!!!!
In my snooping around I found a "PROFICIENT S12 SUB WITH A NEW DAYTON 250W AMP & REMOTE". (It's actually 150watts @8ohm) This can be had for $203.00
Worth a ponder or no?
Both subs are under a grand. To me thats cheap for a sub. And now with Tweeter selling most stuff at 30 to 50 % off , you probably can pick one up for a couple hundred bucks. You would be getting a high class sub for half off.No Tweeter near me!
What is "Not expensive"?Dan
try the klipsch there are two available at best buy one is higher priced, I bought the lower priced and its just fine and not to expensive..I have enough rattling of my glasses using this I dont need more to start damaging my plasma
The only way a sub from best buy would damage a plasma is if you threw it at the TV....Mains.............Polk LSi15 (Cherry)
That woulda been great but it's like a bizzilion miles to get to one from here.
Run with the big dogs...Velodyne!!!! Everyone else is still playing catch up. -
What is your price range, Motzart? Epik, Velodyne, SVS all make good, relatively inexpensive subs. If you are truly looking for the BEST as you stated in your first post, you'll want DIY sub about the size of a closet. JL Audio makes the GOTHAM, which is freakin' awesome, but also costs about $12k.....so......what is your price point?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Actually, I believe it's the other way around... Velodyne has a long way to "catch up" with the internet based companies.
The gotham is nice; however, you can grab dual f113's and they'd out do the gotham for half the price. -
Definitely consider Velodyne Subwoofers for their quality and price!!!
Trying to keep it under $300 and want at least a 10-12in @ 120-150watts
What are your room deminsions ? is it closed or open to other areas of your house ?
Surprised no one has asked that very important question.
If your room is 10'x10'x8' a $300 sub will be ok but if you are approaching 1500^3 or larger you are wasting your money. Save 300 more and buy a HSU 33 that is onsale right now.
If your room is approaching 4000^3 then go with the SVS PB13 but that is 5X more than you want to spend.Speakers: SDA-1C (most all the goodies)
You can't be serious? Velodyne has been on the forefront as much as anyone else. They use Class D which some say don't perform as well as A/B amps that some higher manufacturers use, but come on. How many sub makes include a remote and microphone to easily tweak your sub from the listening position?
What has SVS done that is so exceptional in terms of technology? They just make a decent product that's affordable. IMO Hsu makes a better sub and has taken a leap forward with they new wireless subs. Epik is no different than SVS other than the fact that they use massive drivers and build a good cabinet. How have they developed the forefront?
Emotiva is making several new subs that will have a proprietary amp designed by the company themselves as well as tweaking with a remote and computer based GUI. These are the subs I'm waiting for. Emotiva may be a small company that's pushing the forefront, but companies like Velodyne were the first to implement the ideas. -
I have two JL F112's that will pretty much rattle ur teeth.;)60" pioneer elite plasma, pioneer elite vsx-01, pioneer elite bdp-05fd, 2-JL audio fathom F112's, 2-Polk audio LSi 15's, Polk LSi center, Polk incieling surround and rears.
I have a odd sized small living room.
It's 10ft wide.....15ft long and 8ft ceiling.
Partly open on one side and open on the long end.
It's a goofy setup!
So I really need a high dispersing sub to get the most out of it.
Another I have been researching that's reasonable price is a Yamaha SW315 with the QD Bass system.
If you want to keep it around $300 I think this is one of the best you could get. It would be $350 shipped.
http://www.edesignaudio.com/product_info.php?cPath=2_41&products_id=407
If you check Craigsub list there is pretty much nothing that touches it for that price.Samsung 5085
Denon 1909
Polk RTi A5 Fronts
Polk CSi A4 Center
Polk FXi A4 Surrounds
MFW-15 Sub -
Sorry...but I've already traveled down that ID road. Now for my hard earned money, I need not look any further than the Velo SPL-R series. The other subs I've tried (both ID & loaners from dealers) were terrific for HT but laid a huge goosegg for 2 channel listening. The Velo is truly awesome at both, that's enough to keep me happy & smiling.
Velo has always set the pace for technology advances, offers a tremendous lineup to fit a multitude of budgets. There R&D is second to none & it shows. -
free shipping? damn, i should've gotten this over my used SVS PB10 for $330 shipped...Onkyo 805, RtiA5s, Csi5, Rti6s -
Velodyne HGS series. Get the biggest one. Houseshaking...
FBHarman Kardon HK 3490
Stanton STR8-100
Polk SDA SRS 2.3TL (Proud newbie owner!) -
Thanx for all the input Guys!
Still not quite sure what I'm gonna get but I found a Yamaha YST-SW315 that looks to be top on my list.
How do these specs look?
Advanced YST Technology
QD Bass Technology
High Efficiency Power Amplifier
Multi-Range Driver 10" Cone
Magnetic Shielding
High Cut Filter 40 - 140 Hz
Phase Control (Normal or Reverse)
Auto Standby
BASS (Bass Action Selector system)
Dynamic Power 270W
Frequency Response 20 - 160 Hz (-10 dB)
Impressive dip to 20hz!! :eek:
Your thoughts?
QD Bass Technology
Magnetic Shielding
Auto Standby
Dynamic Power 270W
Your thoughts?
Specs are for people who believe what they read. Hearing is believing. It may go down to 20hz but if it sounds like a garbage disposal then what's it worth????? -
Advanced YST Technology •
QD Bass Technology •
High Efficiency Power Amplifier •
Magnetic Shielding •
Phase Control (Normal or Reverse) •
Auto Standby •
BASS (Bass Action Selector system) •
Dynamic Power 270W
Your thoughts?
It may hit 20hz but I wonder at what decibel level.
The A2-300 I provided the link for above has a response of 18-100hz.
Another you may want to look at is this. $239 and it has received may good reviews from people who have used it.
http://www.theaudioinsider.com/product_info.php/loudspeakers/acculine/p/acculine-asub/cPath/21_32/products_id/68
BIC Accoustech also has one that is supposed to be cheap and very good.Samsung 5085
Denon 1909
Polk RTi A5 Fronts
Polk CSi A4 Center
MFW-15 Sub -
If it's 10dbs down at 20hz, it's unlikely it's usable on an entry level sub. If you're really looking for a bargain try this...Thanx for all the input Guys!
QD Bass Technology
Magnetic Shielding
Auto Standby
Dynamic Power 270W
Your thoughts?
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-394
This is the Hsu design based on the venerable STF 3. You'll get very real 20hz performance and great output. Sure it's fugly, but it will perform.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Well I did ask for your honest opinion! :rolleyes:
Honestly I can't afford over $300 total...too close to Christmas.
I wish I could afford about $400+ but......:(
