POLK RTiA5 System
Hi Erick,
Im thinking of upgrading to the Larger RTiA9 for my Fronts.
Are you Local?
Have you considered the LSI series. -
No disrepect Dan, but I have to agree that the RT line doesn't really bring the best out of your amp choice. The LSi line is a much better test for the quality of gear you are amassing. You might actually heat the SEs up a bit if you faced them with the 4 ohm load the LSi has. I personally feel that the LSi/Odyssey matchup is a good one, worth a try.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Hi Dennis,
No disrepect taken, I may look into the LSI line.
The LSI line may be out of by Budget these days.
I have a friend that may sell me his RTiA9 at a great price.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Hello,
Whats the price range for the LSI lines?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Hello,
How would you characterize the sound of the LSi25 and LSi15?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
You need to look into the Taylo 7u...
Same price at around 2,500 or so new like the LSi25..
Used for much less...
A GREAT SPEAKER that mates VERY well with those amps...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Purchasing new or used? New is price controlled so should be the same almost everywhere (from an authorised seller)
Used - 15's in the $700-$800 range, 9's in the $500-$600 rangeMains.............Polk LSi15 (Cherry)
The LSi sound would best be considered smooth and laid back. Personally, I like the 15's much more than the 25's. (especially if you are running them with a decent amp)
From what I have read and heard, they also respond well to crossover upgrades if you are into that sort of thing....
Michael,
Thanks for the great info. I prefer a smooth sound.
Is it hard to blend in the Subs in the LSi Floorstanders?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Hi Guys,
What are the Taylo 7u's going for Used???Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Around 2,000
You can get ones new from Ty on his website for around 2,600 to 2,800
You will not regret it...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Very Nice System!
Which CD player is that?(Shanling)Sweet.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Thanks ---
CDT100
Everything has been great... no complaints at all- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I just picked up a New Kavent/Shenyge CD-1031 player.
The CD-1031 has a nice balance sound which is smooth and detail.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Wow that looks bad ****..
Congrats
I wouldnt mind laying my ears on that!
Ive had my CDP a while now - no real desire to move on...
Although as one point I really wanted to pick up Klaus's CDP he can get for like 2,500 - very plain looks, but man I bet it sings...
Just cant justify the money...
You have a great rig...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks,
Klaus is one Cool Dude, I drove down to Indy to pick up my amps in person.
When the Economy settles down, I will look into those Awesome Tylo 7us.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Hey Guys,
Day 14, the RTiA5 are sounding much better.
I hate breaking-in Speakers.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
The monos will take roughly 300 hours to break in...
The Mono-Bloc are well broken-in, I bought them in April 2007.
Just cant wait until the RTiA5 are broken -in all the way.
I can see the Light at the end of the Tunnel:)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Mine took a lot longer than I expected them to. Those 6.5's were very tight when I first got them.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Hey Curved,
How many hours did it take to break-in or months?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
It is pretty easy to blend the 15's with a sub. I had the 25's for a short while but I don't remember exactly how hard or easy they were to integrate.Michael,
Hey Guys,
Did the tweeters break-in or change in tone over time?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Hey Guys,
Is there a difference in the Highs(tweeters/upper mids) between thr RTiA5s
and the RTiA9s.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Hey Guys,
Is anyone using Harmonic Technology cables?Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
I think you would get much better sound if you got the sytem out of the corner. Wouldn't hurt to minimize all the equipment between the speakers as well.
Hi,
Thanks for the Advice,but at this time thats the only set-up I can use.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Is the sound changing for you?
Hello,
The more the RTiA5s break-in the better they sound.I was thinking of
upgrading to a pair of RTiA9s. I added a small M&K 8in subwoofer that I had.
The Sound of the RTiA5s with the M&K sub,is a good combo!
Now I have a nice Crisp top-end with a fuller bottom-end.
I think this combo will hold me until I upgrade to the RTiA9s.:)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
Hey Guys,
The Polk RTiA5s sound really good on Movies(The Incredible Hulk-Indiana Jones)Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
Odyssey Mono-Blocs
