what cabble to get to hook up my recever to amp?
goingganzo
i dont want to spend a mint on cabbles and need 7 of them.
i am looking at
monster cabble 400 Mk II
acustic reaserch audio cabble
i want to olny make the buy once but dont have alot of extra cash.
i am looking at
make your own canare cables
Gonzo,
Based on recommendations from others on this forum (polkatease, Russ, etc.) I recently purchased some Signal Cable Analog two interconnects for my system. $53 / pair. They sound great. Buy a pair and see if you like them for two channel audio.
For a little over $200 you can have what you are looking for.
Paul -
Think I answerd your question in the fleamarket but I 'll put it here as well.
M550i's by Monstercable.Right up your alley and would match your system nicely.On a budget there great.They retail for 50.00 for 1 meter.Great price and lifetime warranty.Dan
Check this place out...It's DIY cable but the work is already done for you...
www.bluejeanscable.com
My buddy uses them on his B&K rig and he loves them...great price performance and solid construction...
-BLTWFTPQ
Receiver: Outlaw 1050
Amps: Outlaw M-200 x 3 (Powering Mains and Center)
Mains: RT800i; Center: CS400i; Surrounds: F/X500i
Sub1: 214L Vented Tempest
Sub2: 122L Sealed Tempest -
Depending on how the old bidding process goes, I may be able to build you some nice silver plated copper ones.
Your cost would be my cost(ie pennies per foot) Labor would probably be free. After all it's a labour of love.
Update: I lost the bid while I was at work.Make it Funky!
Ditto to Bluejeans cables. They are very service orientated and the product is good quality.
Rick
