what cabble to get to hook up my recever to amp?
goingganzo
goingganzo Posts: 2,793
edited May 2003 in Electronics
i dont want to spend a mint on cabbles and need 7 of them.
i am looking at
monster cabble 400 Mk II
acustic reaserch audio cabble
i want to olny make the buy once but dont have alot of extra cash.
  • dlew308
    dlew308 Posts: 530
    edited May 2003
    make your own canare cables :)
  • pjdami
    pjdami Posts: 1,894
    edited May 2003
    Gonzo,
    Based on recommendations from others on this forum (polkatease, Russ, etc.) I recently purchased some Signal Cable Analog two interconnects for my system. $53 / pair. They sound great. Buy a pair and see if you like them for two channel audio.
    For a little over $200 you can have what you are looking for.
    Paul
  • gidrah
    gidrah Posts: 3,050
    edited May 2003
    Between those choices I'd go with the AR.
    Make it Funky! :)
  • mantis
    mantis Posts: 17,658
    edited May 2003
    Think I answerd your question in the fleamarket but I 'll put it here as well.
    M550i's by Monstercable.Right up your alley and would match your system nicely.On a budget there great.They retail for 50.00 for 1 meter.Great price and lifetime warranty.
    Dan
  • BeginnersLuck
    BeginnersLuck Posts: 213
    edited May 2003
    Check this place out...It's DIY cable but the work is already done for you...
    www.bluejeanscable.com
    My buddy uses them on his B&K rig and he loves them...great price performance and solid construction...
    -BL
    TWFTPQ
    Receiver: Outlaw 1050
    Amps: Outlaw M-200 x 3 (Powering Mains and Center)
    Mains: RT800i; Center: CS400i; Surrounds: F/X500i
    Sub1: 214L Vented Tempest
    Sub2: 122L Sealed Tempest
  • gidrah
    gidrah Posts: 3,050
    edited May 2003
    Depending on how the old bidding process goes, I may be able to build you some nice silver plated copper ones.
    Your cost would be my cost(ie pennies per foot) Labor would probably be free. After all it's a labour of love.
    Update: I lost the bid while I was at work.
    Make it Funky! :)
  • rickfaldo
    rickfaldo Posts: 49
    edited May 2003
    Ditto to Bluejeans cables. They are very service orientated and the product is good quality.
    Rick
