TT What do you think?
13»
    treitz3 Posts: 20,076
    edited July 2008
    Just looked it up. 1.75g of force. That's for the MMF-5 though.
  • ben62670
    ben62670 Posts: 15,969
    edited July 2008
    Well with the dial at anything less than 6 it just skates. I'll give the shop a call tomorrow. I have the kids anyway.
    Ben
    Ben
    edited July 2008
    What the hell. I asked this on the Vinyl Engine.....concerning anti-skating and the weight.
    http://www.vinylengine.com/phpBB2/viewtopic.php?t=10763
  • Systems
    Systems Posts: 14,872
    edited July 2008
    treitz3 wrote: »
    Could you put another scratch on the pre just for Chuck? I hear he likes his stuff like that. That way, he concentrates on the music and not the gear.
    Don't do me any favors man.
    Chuck
    Testing
    Testing
    Testing
  • strider
    strider Posts: 2,568
    edited July 2008
    ben62670 wrote: »
    Ben
    The dial on the counterweight should be set from 15 - 20 Mn. When I began with mine, it was set to about 17.5. Ortofon suggests it be set at 1.75g, which converts to 17.5 Mn.
    The portion of the manual that deals with the anti-skate weight contradicts itself. I'm at work right now, but if I remember correctly, at one point it tells you to put the string for the weight at the end of the pin, in another it tells you to put it on the middle notch of the pin. I have mine on the middle notch. If everything is set up the way it says in the manual, and the arm is still flying off the the album, try bending the arm that the counterweight string pivots on.
    Wristwatch--->Crisco
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2008
    oh my goodnes Ben, all this talk of weights and grams and forces, ok, you had the table playing, you said it sounded great, so the weights and forces were ok. As you were wanking around the table and playing with stylus cover on and moving this and moving that is it the least bit possible you fat fingered it and moved the cartridge? Did it come with a protractor to check?
    RT1
  • ben62670
    edited July 2008
    ...Ben...you fat fingered....
    RT1
    I am big boned:)
    Ben
  • ben62670
    edited July 2008
    This one is for Chuck.
    AA is closed on Monday.
    Ben
  • Systems
    edited July 2008
    I know. I hate that too.
    Chuck
    Testing
    Testing
    Testing
  • Ricardo
    Ricardo Posts: 10,634
    edited July 2008
    ben62670 wrote: »
    So what's the big deal? You just go back drinking on Mondays. :D
    SOPA
  • Systems
    edited July 2008
    right....bottoms up!!
    Chuck
    Testing
    Testing
    Testing
