Head unit so many choices
does anyone know where i caN BUY the optional led light bar/fankit for the polk Pa 1200.1 power amp i know they make one but cant find it anywhere?tyler birch
ht system
denon avr-1907
monitor 70 towers-polkaudio
nakamichi bx -100 tape deck
sony 5 disc cd/dvd player hdmi ready
velodyne dps-12 subwoofer
Car audio
AMP: FUSION EN-AM8001 800 watts max 368 watts rms x 1 channel @ 2 ohms stable
SUB: 12 INCH 1000W DVC VOLFENHAG 2 Ohm stable useable ohms 2-8ohms -
Id run down to your local audio or tuner shop and see what theyve got.
I dont know if the 701 controller will mount in a double din cause Ive never tried it. As a guess Id say it should.polkaudio sound quality competitor since 2005
The 701 controller will mount in a double din location along with a din sized head unit. It should come with the hardware to mount it.Team Schil Acoustics
05 MECA world champion
06 MECA world champion
06 MECA Culbertson cup (best of show) -
ah i love you meca boys yall are so damned helpful. Got a question for you though, mac and 300 my friend says that polk doesnt make good amps or cubs and there speakers are only decent, is he full of it, he said for the price her can get much better, with alot more wattage, ive always known polk to be like the elite in audio matters, is he full of it.tyler birch
ht system
denon avr-1907
Car audio
mac has come in 2nd at world finals 2 years in a row with polk.....
that makes him one of the best right?
Kobe Bryant - the best basketball player in the nba... his shoe is a nike... if the shoe is good enough for him to play in... wouldnt u trust yourself to wear it when u played basketball?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
thats is a good point if its good enough for mac to take to the world finals, than its good enough for me.tyler birch
ht system
denon avr-1907
Car audio
my friend was talking bout soundstream and ma audio, and matts i never heard of themtyler birch
ht system
denon avr-1907
Car audio
i guess now that i have made my mind up its torture time till i can buy it. and what exactly do you do with the modeling clay on the doors do you smear it on the trim or what.tyler birch
ht system
denon avr-1907
Car audio
and i was wanting to save a little bit of money since im going with the h701 processor would a cheaper alpine hu work just fine, i was just wondering because the 9887 has imprint built in to it but why pay for the imprint if im not going to use it. so what would be a good alternative to the 9887tyler birch
ht system
denon avr-1907
Car audio
ok the polk sr 124 dvc come wired at 2 ohm, correct? If i install two of them in the same box and wire them together i either get 4 ohm or 1 ohm , correct? Now the pa 1200.1 puts out 1200w rms @ 1 ohm, the two subs wired together would be rated for 1400wrms @ 1 ohm. I was planning in running one pa 1200.1 to each sub indepently, which would give me a total of 1600wrms, 800 per sub. if was was two wire the subs together should i bridge the two pa 1200.1 together, which would give me 2400wrms @ the ohm im not sure of. how should i wire these bad boys up, run them indepenently, or two 1200.1 bridged and just turn the gains down alot?tyler birch
ht system
denon avr-1907
Car audio
Ill put them up against anything out there. I dont think Polk speakers are the best in the world, but dollar for dollar they are and regardless of cost, the SR's will hold theyre own against the best in the world.
You have to remember tho that no speaker will sound good if you install and/or tune them poorly but a mid level speaker will never sound great no matter how well you install them or tune them but a great quality speaker, like the SR's, can sound awesome if done right.....and sound pretty damn solid out of the box too.polkaudio sound quality competitor since 2005
true how bout the wireing dealtyler birch
ht system
denon avr-1907
Car audio
any ideas on the baest way to wire these uptyler birch
ht system
denon avr-1907
Car audio
If youre going to use 2 1200.1's then get 2 SR124DVC's and wire each one per amp. That would be 2 ohms per amp and 800 RMS per sub.polkaudio sound quality competitor since 2005
ok thats the way i was thinking about doing it, now do i slave one amp off the other and daisy chain them together so they work in sync. or how does that work i know the power and grounds are run seperateim talking about the rca cords and stufftyler birch
ht system
denon avr-1907
Car audio
Just run them independantly of each other.polkaudio sound quality competitor since 2005
ok so dont worry about using the master/slave functiontyler birch
ht system
denon avr-1907
Car audio
but coming out of the hu i only have one subwoofer preout or does the h701 have multiple sub outputs how are two differnt sub amps connected to the processortyler birch
ht system
denon avr-1907
Car audio
the amp has preamp outputs, just run an rca from one amp to the other.kenwood excelon kdc-x991 h.u.
Rockford Fosgate 360.3 DSP
Rockford Fosgate POWER1000 running entire system
Image Dynamics IDQ12 Sub
Morel Elate 6 front stage -
any ideas or should i go with the 9887tyler birch
ht system
denon avr-1907
Car audio
ok but mac said to run the indepently of each other how is this possibletyler birch
ht system
denon avr-1907
Car audio
most of the units now have imprint. i have the 9885 and it works well.... if u have the processor... i dont think there is much of a diffrence. the 9886 is the same price and a little better..... 100 bucks diff. up to u2013 Toyota Prius
Mosconi 6to8 v8 -
i've decided to go with the 9886 its a hundred bucks cheaper, and with the 9887 i was paying for eq bands that i will just be bypassing with the processor.tyler birch
ht system
denon avr-1907
Car audio
i went to my local shop the other day stereo joes in kingsport. they have trophies all over the wALLS and in the shop. meca and others. any way he told me to check with him as far as price goes cause he may be cheaper then crutchfield. He also said they can help me out as far as how to do stuff, and he said when i get everything put in bring it back and he would help me tune it for sq. and he said he can tune for sq and spltyler birch
ht system
denon avr-1907
Car audio
i just heard a full sr setup today similiar to what im getting and it is the only system where u can actually hear the music and the bass at the same time the sr components have enough ummph behind them to be heard over the bass i hate when the bass drowns out all the musictyler birch
ht system
denon avr-1907
Car audio
Sounds like a good shop. Any shop that supports and participates in competition is one I support and is usually a better shop because theyre out there putting their stuff to the test.polkaudio sound quality competitor since 2005
are shops usually cheaper the crutchfieldtyler birch
ht system
denon avr-1907
Car audio
well the shop i went too had probebly a hundred or so trophies from comeptitions so they are more into competing and customization work. it just want to spend less than what cfield wants is all.tyler birch
ht system
denon avr-1907
Car audio
Your local shop can usually give you better deals if you talk with them. Tell them what youre looking for and what youre willing to spend and you may be surprised. Plus, if theyre going to do the install for you they may give you a discount on the gear.polkaudio sound quality competitor since 2005
well why is cfield so dang high then, i mean mac tell me what you think bout the price heres the break down anyone else feel free to chime in too:
98thumpin's Cart
Quantity Description In Stock? Reg Price Your Price
Remove
Save to Wishlist
Polk SR5250 5-1/4" Component System
Vehicle: 1998 Ford Crown Victoria Sedan without Premium sound (change)
Speaker Location: Front Door
Yes $749.99
» Add ServiceNet Service Plan
» Add Accessories
1
Speaker Bracket 142SA68
Yes $14.99
FREE
1
Speaker Harness 12071058
Yes $12.99
FREE
Remove
Save to Wishlist
Polk Audio PA1200.1 800W x 1 Car Amplifier
This item is temporarily out of stock
No $1,199.98
» Add Accessories
Remove
Save to Wishlist
Alpine PXA-H701 Multi-Channel Audio Processor
Yes $499.99
» Add Accessories
Remove
Save to Wishlist
Polk Audio PA500.4 85W x 4 Car Amplifier
Yes $399.99
» Add ServiceNet Replacement Plan
» Add Accessories
Remove
Save to Wishlist
Polk Audio SR 124 DVC 12" DVC 4-ohm Component Subwoofer
ETA: 6/13/2008 $699.98
» Add Accessories
Remove
Save to Wishlist
Alpine CDA-9886 CD Receiver
Yes $299.99
» Add Accessories
1
Receiver Kit 120995600
Yes $12.99
FREE
1
Receiver Harness 120701771
Yes $12.99
FREE
1
Receiver Add-on 120865618
Yes $4.99
FREE
Remove
Save to Wishlist
Alpine RUX-C701 Controller for PXA-H701 Audio Processor
Yes $249.99
Remove
Save to Wishlist
Alpine KCA-100BT Bluetooth Interface Module
Yes $199.99
» Add Accessories
Remove
Save to Wishlist
Autosound 2000 CD Set 5 Test CDs
Yes $69.95
Remove
Save to Wishlist
Dynamat 19100 License Frame Kit
Yes $12.99
Remove
Save to Wishlist
S&G Tool Aid 87650 Door Trim and Panel Removal Tool
Yes $9.99
1
Crutchfield MasterSheet Instructions
Yes $4.99
FREE
1
FREE Crutchfield Guide: Amplifier Installation
Yes
FREE
1
FREE Crutchfield Guide: Vibration Damping Installation
Yes
FREE
1
FREE Crutchfield Guide: Component Speakers Installation
Yes
FREE
1
FREE Crutchfield Guide: Subwoofer Installation
Yes
FREE
Merchandise Subtotal:
$4,392.83tyler birch
ht system
denon avr-1907
Car audio
