Head unit so many choices
I will have to consider that option as well, I consider polk audio the best of the best, I have a pair of Polk monitor 70s in my bedroom and absolutley love them. So Two 12 inch Polk SR's would be better than three Alpine type r 12's, It just such a hard decision to make because i want to crack paven, but also want tight clean bass. I guess a man cant have both, SO would the sr's be a good choice for what i want?tyler birch
ht system
denon avr-1907
monitor 70 towers-polkaudio
nakamichi bx -100 tape deck
sony 5 disc cd/dvd player hdmi ready
velodyne dps-12 subwoofer
Car audio
AMP: FUSION EN-AM8001 800 watts max 368 watts rms x 1 channel @ 2 ohms stable
SUB: 12 INCH 1000W DVC VOLFENHAG 2 Ohm stable useable ohms 2-8ohms -
Im glad got there own ebay store nowtyler birch
ht system
denon avr-1907
Car audio
one reason i was going to go with the alpine type r is the price, the polk sr's at 350.00 bucks a pop are a bit pricey for me No doubt they are a better subwoofer, polk builds great stuff, there just a bit high on the price range.tyler birch
ht system
denon avr-1907
Car audio
If you ask me, I'd say they're worth every penny. But if its out of your price range, its out of your price range. Alpine builds pretty solid products as well. -
the type rs have a frequency response range of 23-500hz while the polk has one from 20-200hz does this make a huge differencetyler birch
ht system
denon avr-1907
Car audio
its a difference of 200 dollers for the alpines and 350 for the polks so a 150 buck difference thats why the alpines caught my eye. has anybody heard these in a sealed boxtyler birch
ht system
denon avr-1907
Car audio
id like to compete in a sq'spl comp once to see how i do, mac is the setup im going with capabletyler birch
ht system
denon avr-1907
Car audio
u askign for 2 diffrent things. if u wana be able to get a high db reading for a contest... u are going to need to throw in the 3 12s and still prob not do very well..... if u wana win a sound quality compeitions u are going to want prob no more than the 2 12"..... start with 1 12" sr and see if its enough for u... if its not, add another.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
i have 2 sr124-dvc's and have plenty of output and great sound quality. i would go that way.kenwood excelon kdc-x991 h.u.
Rockford Fosgate 360.3 DSP
Rockford Fosgate POWER1000 running entire system
Image Dynamics IDQ12 Sub
Morel Elate 6 front stage -
I couldn't agree more
clearly u cant spend money u dont have.... so dont subtle for the alpines right now... if u dont have enough for the 2 SRs now, get 1 and get another later.2013 Toyota Prius
Mosconi 6to8 v8 -
OK say i go with the sr subs what are good amplifiers to power these 700wattrms beaststyler birch
ht system
denon avr-1907
Car audio
I'd say start off with one SR124 DVC and use a PA1200.1 to power it. That'll give you 800 watts. Thats plenty of overhead. If you find, you'd like more bump in the future, you can add another DVC sub. That amp will put out 1200 watts at a 1 ohm load, so each sub will be getting 600 watts. -
that is a lot less power than i was orginally going to go with, now when the sr subs hit do they hit hard, can you make them take your breath away. will they rattle your teeth. I was listening to my buddies system last night he has two crunch 12's and took your breath away i was smiling like a kid in a candy shop. of course we were in a little hatchback with the praticallly right behind our heads. but it was a nice back massage, plus i know one 12 will not be enough i allready have one twelve in the trunk now its a volfenhag, and i cant even tell i have a sub in the car, its quit as a mouse, it blows. so i dont know if 2 12s will be enough i have a huge trunk and it is a long way from the trunk to the driver seat, im driving a crown vic remember.tyler birch
ht system
denon avr-1907
Car audio
ok i decided im going to go with to polk sr 124dvc sub and im going to run a pa1200.1 to each sub, that will give each sub 800rms i know the polks can handle that, my question is i called crutchfield and they reccommend putting a cap on each mono amp do i need this, or are they trying to sucker me out of more money? i dont want to buy extra **** i dont need.tyler birch
ht system
denon avr-1907
Car audio
what kinda car do u have? and no u shouldnt need a cap.2013 Toyota Prius
Mosconi 6to8 v8 -
and how about instead of that alpine amp u go with a
Polk Audio PA1200.12013 Toyota Prius
Mosconi 6to8 v8 -
I run type R 15s in a Caddie Escalade and they get very loud yet sound very good. Running them down to 1 ohm off a Hifonics BXI 2806, tuned to 32hZ ported enclosure.Shoot the jumper.....................BALLIN.............!!!!!
Make sure you have a high output alternator as well. Mine's 125 amps and still the lights dim to the beat of music when I pound it.....with a 1.5 cap.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
If you don't mind me asking, what setup do you have? -
eloplayspolo wrote: »what kinda car do u have? and no u shouldnt need a cap.
1998 crown victoriatyler birch
ht system
denon avr-1907
Car audio
eloplayspolo wrote: »and how about instead of that alpine amp u go with a
Polk Audio PA1200.1
I am going to be running two PA1200.1 One amp per subtyler birch
ht system
denon avr-1907
Car audio
so if i run a high output alternator and a optima battery i wont need to worry about caps? does any body have a rough idead houw much it would cost to have a sub box custom made?tyler birch
ht system
denon avr-1907
Car audio
im sure cody can give u a pretty good estimate, the alternator in a crown victoria should actually be pretty solid... dont they use them for cabs.... if the one in cabs are different u could maybe go to a salvage yard and yoink one from a cab (if they have a better one).
that setup is sounding very impressive.2013 Toyota Prius
Mosconi 6to8 v8 -
How custom do you mean? I personally recommend making it yourself... especially if you like working with your hands. Plus its a lot more satisfying knowing you've done all the work! -
black magic wrote: »How custom do you mean? I personally recommend making it yourself... especially if you like working with your hands. Plus its a lot more satisfying knowing you've done all the work!
custom meaning a box for the two sr subs with a plexiglass window on top of the box so you can see down inside it, and a lime green led tube inside the box. and im not that skilled at the art of woodworking to build my own boxtyler birch
ht system
denon avr-1907
Car audio
eloplayspolo wrote: »im sure cody can give u a pretty good estimate, the alternator in a crown victoria should actually be pretty solid... dont they use them for cabs.... if the one in cabs are different u could maybe go to a salvage yard and yoink one from a cab (if they have a better one).
what setup are you refering too if i may ask? and yes they use crownvics for cabs and police cars i am going to put a 220amp alternator on the car with a optima batterytyler birch
ht system
denon avr-1907
Car audio
what do you all think about eq will i need a eq, im going to try to compete in a sq competition sometime, i was thinking about the Pioneer DEQ-7600tyler birch
ht system
denon avr-1907
Car audio
if anyhone has any pointers on sq competitions i would appreciate ittyler birch
ht system
denon avr-1907
Car audio
this is a question for MAC, hey mac what do i need added to my setup to stand even a slight chance in a sq competition? and is the pioneer eq a good choice i have the kenwood x792 picked out but i could easily switch to a alpine unit. help me mac i would love to be able to fair decent in a sq competitontyler birch
ht system
denon avr-1907
Car audio
