Interconnects, and why I now hate you guys
Rivrrat
Rivrrat Posts: 2,101
I've known for a long time that there's a difference in speaker cable. Back in 85 when I bought my m10's the place I got them from threw in 20 ft or so of 10g "Monster Cable", I don't know if it is or not, but that cable made a huge difference over my 16g lamp cable.
Fast forward to now. I've been reading for a year now the arguements over IC's and what not, not really believing that a low voltage signal could be that much different over different wire, as long as the gauge could support the signal (what happens when you do digital telcom cabling for a living).
So on a lark, I bought some Monoprice rg59 IC's during one of my orders while I'm recabling my HT to inwall. I'll be damned if it didn't make a noticable difference, a REALLY noticable difference. Even my wife said something.:eek:
So now, I'm wondering if I shouldn't pop for more, fancier IC's. This could turn into a vicious cycle, AND IT"S ALL YOUR FAULT.:D
My equipment sig felt inadequate and deleted itself.
Post edited by Rivrrat on
«13
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited March 2008
    What sort of a difference did you hear? According to all the "believers" here, monoprice cables suck, like putting a blanket over your speakers. Very interesting that those cheap horrible cables would be an improvement, but hey, your wife heard it too, right?
    And no one believes this is all just imagination.:rolleyes:
  • obieone
    obieone Posts: 5,077
    edited March 2008
    You are absolutely right! It's OUR fault that YOU can HEAR a difference!:D
  • Rivrrat
    edited March 2008
    WilliamM2 wrote: »
    These feed a dvd changer that mostly just gets used for cd's on some Atrium 45's on the patio (everything inside is optical off an Oppo 981). But, they opened up the soundstage, I can hear things I didn't hear before,( that's what my wife noticed, and she didn't know I did anything), but I can understand the blanket thing. I'd say it bumped up the soundstage, the bass and midrange a bit, but maybe it took something off the top end.
    I'm thinking I can reverse the speaks so the tweets are turned in instead of out, and that should help the highs a lot.
    I'll probably build some nice ones down the road (soldering and or brazing skills here). but I'm not going to say anything right now, what with the WAF and all.
    Still, they're better than the stock POS interconnects.:rolleyes:
  • nikolas812
    nikolas812 Posts: 2,915
    edited March 2008
    I have had three different IC's. They all sounded different. I went from stock in the box IC's to Blue Jeans cables and then to Audioquest Copperheads.
    When I went from the BJC's to the Audioquest cables and did some real testing. I was floored.
    I felt like I was witnessing a miracle or would that be hearing a miracle? Either way I could not believe what I was hearing.
    There is no doubt in mind cables do make a difference.
    I did a full review on the Audioquest Copperheads VS the BJC's if you are interested. A quick search in this forum should get it.
  • Sami
    Sami Posts: 4,634
    edited March 2008
    Rivrrat wrote: »
    The monoprice IC's are pretty good cables, nothing wrong with them. The stocks that come with cheap stuff, well, I wouldn't use them either. Don't expect much from going from the monoprice to higher priced cable, that way you won't be disappointed.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited March 2008
    Oh **** the Jeane is out of the bottle now ;)
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited March 2008
    Be very careful or you'll be buying tube equipment next and a turntable ;)
  • beardog03
    beardog03 Posts: 5,550
    edited March 2008
    once you discover MIT, you will never be the same again !!!
    trust me on this one.....
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • dragon1952
    dragon1952 Posts: 4,907
    edited March 2008
    WilliamM2 wrote: »
    Geez, what an ****. Two insults in one post. First you knock his new IC's and then his intelligence. Good one. :rolleyes:
    treitz3 Posts: 19,960
    edited March 2008
    This is normal for him. "Troll" would be appropriate here.
    Just goes to show you that you should listen to the credible members more often. ;):D:)
  • WilliamM2
    edited March 2008
    dragon1952 wrote: »
    Geez, what a jerk. Two insults in one post. First you knock his new IC's and then his intelligence. Good one. :rolleyes:
    I did not knock his cables, I have recommended monoprice to several posters here. I only commented on what many others have said about monoprice cables here.
    This is the first time I have seen anyone gush about a $3 cable. Thought it was odd, and the complete opposite of what others report.
    As far as knocking his intelligence, what are you talking about?
  • WilliamM2
    edited March 2008
    treitz3 wrote: »
    Really? How many times have you recommended monprice for superior sound?
    edited March 2008
    WilliamM2 wrote: »
    None. Have I recommended better cables? Yes. Price is not always a factor nor will it dictate any change for the better or worse in the end result.
    In this case, he heard a change. Respect it and move on without insulting his intelligence please.
  • jabrax
    jabrax Posts: 315
    edited March 2008
    Rivv, I saw the IC light myself just today. I purchased some hga silver ICs from Muveling and put them in today. A very noticeable difference over the ultra 600 Ics i was using.
    TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
    Pre/Processor - Emotiva MMC
    Seven Ch AMP - Emotiva LPA
    Fronts - Tyler Acoustics 7U's
    Center - Polk LSIC
    Sub - DSWPRO600
    DAC - Music Hall 25.3CD - Marantz cc4001
    Blue Ray - PS3
    Speaker cables - Audioquest cv4 dbs
    Interconnects - MIT AVT1's
    Power Filter....Monster HTS 3500 MKII
    edited March 2008
    WilliamM2 wrote: »
    You confuse me sir. You recommend, yet you claim [through your posts] that you have not heard a change or difference between cables/ IC's or otherwise.
    Why would you recommend a certain cable if you hear no difference?
  • Sami
    Sami Posts: 4,634
    edited March 2008
    treitz3 wrote: »
    Because of price. Nicely constructed cable and it's cheap.
    edited March 2008
    WilliamM2 wrote: »
    This is where you insult his intelligence.
    1. You classify "us" and "him" and his wife as a "believer".
    2. You insult him knocking his purchase of monoprice cables.
    3. You have recommended monoprice cables to posters here, yet you just said in your quote above that "monoprice cables suck, like putting a blanket over your speakers."
    4. You insinuate that his wife didn't hear a difference either.
    5. Then you insult all that know better that "no one believes this is all just imagination.:rolleyes:"
    Give the BS. up.
    edited March 2008
    Sami wrote: »
    Not you Sami, WilliamM2....
  • WilliamM2
    edited March 2008
    Well what would you call people who believe in something that no one has been able to prove?
    Nice out of context quote.
    5. Then you insult all that know better that "no one believes this is all just imagination."
    People falling for placebo effect, or expectational bias has nothing to do with intelligence, and I never insulted his. Not believing that expectational bias exists, when is is a known fact on the other hand...
    Give the BS. up.
    As soon as you do.
  • WilliamM2
    edited March 2008
    treitz3 wrote: »
    Happy now?
  • Sami
    Sami Posts: 4,634
    edited March 2008
    treitz3 wrote: »
    Because that's his reasoning. Am I right William? While I'm at it...
    treitz3 wrote: »
    He didn't say that, this is the actual quote:
  • WilliamM2
    edited March 2008
    edited March 2008
    Post #17. William, could you answer this?
  • WilliamM2
    edited March 2008
    treitz3 wrote: »
    I already did, in post #22.
    edited March 2008
    treitz3 wrote: »
    You got me there. My bad.
    edited March 2008
    So, you recommend a "Nicely constructed cable and it's cheap."
    This has nothing to do with sound and what it can do for a particular system.
  • WilliamM2
    edited March 2008
    treitz3 wrote: »
    Never said it did, in fact, I have been saying that cables don't change the sound. Are you just now getting this?
    edited March 2008
    WilliamM2 wrote: »
    Boy, oh boy....measurements are one thing. How exactly do you measure a sound stage? Precise imaging? Stereo separation and blending? Depth perception?.....and a multitude of other things in audio reproduction?
    You can't. It's subjective. Everything affects everything.
    Now to answer your question, "what would you call people who believe in something that no one has been able to prove?"
    Experienced.
    edited March 2008
    WilliamM2 wrote: »
    Yes I am, I am finally getting the fact that WilliamM2 recommends cables because they don't change the sound, but they look pretty.
    In the exact words...."Nicely constructed cable and it's cheap."
    HELL of a recommendation William, Hell of a recommendation. My hat's off to you as you obviously know why we are all here. For the looks of things. :rolleyes:
    I should have known better.
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    Beating a dead horse here. I have done it, and have been sucked into it with Bill, and I agree to disagree. There are probably only 3 members here into audio that can't hear a difference. I try to ignore them, and post my opinion on cables.
    Ben
