What does "reference" mean?
And that is why I say auto-calibration will get you closer than doing nothing, but follow it up by checking yourself if you want accuracy.
The real question is - what way sounds better? Dialog and surrounds should be more active with your settings, just wondering if that works out to a better surround sound for you....
Michael
The surrounds are much more pronounced now. As well as the center.
I dont know which sounds better, cause I was so used to the HK's way.
I didnt think that there would be that much of a difference.
I really have no clue as to what the HK is doing. Other than equalizing. But the SPL is sure way off.
I think the difference is the sweep instead of the pink noise.
If I go back to the HK's way, I will know, deep down inside, that all channels are not even. I dont know if I could live with that.:p
Im a big numbers guy.
I will run my REW tonight, to see if the freq is still flat.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
You should have the centre and surrounds at same level as getting them present correctly is the job of sound engineers. Calibrate the system and let the soundtrack take care of the rest.
wow, i just looked at the hk vs manual chart. there is a huge 6db difference between the levels...
Dont you worry my friend, I have plenty of movies to test the new setting on , this weekend.
And when the amp comes in. I get the to do it all over again...wooohoooo!!!:D
But thats the fun of having too much **** to play with...:pMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Yep, after I calibrated and plugged my numbers in. I said
WWHHHAAATTT???
:eek::eek:
I checked and rechecked. All of my measurement or within .5dB's
Who ever said you cant really tell a difference in 1dB is really mistaken.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Can you?? I mean really, can you have too much **** to play with???:D
You are living proof that you can. -
You tell me.
The other buttons are for tweeking..
But that button is really the only one button I worry about.
It gets pressed/turned once a month.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
George Grand wrote: »
Nobody likes me.....so all I have is my ****...just me..my 5 ears and my ****..:( Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
I think all it means for me at least, is that you listen to what you're supposed to hear, or you hear what your supposed to hear.Denon 3803
Denon CD
old Sony Receiver 110W/ch
LSI25 two rights looking to swap for one left (what can I say it was a good deal on two rights)
CS101 center looking for LSiC
KEF KIT200 and IQ3
Cervin Vega AT-12 and LS-12
JBL TLX181
white van Dynalab speakers -
Couldnt have said it better myself..:rolleyes:Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
It appears after rereading this thread that HT and 2-channel have separate "reference" levels, no?I always read about people talking about listening to music or movies at "reference" levels. What exactly does this mean?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Balancing output, weather 2 channel or 20 channels is all the same. Now, if your talking about the Dolby reference? I dont know. I never heard of reference level until I got into HT.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
In order to be a Reference you have to be over 50, before that your just a plain old Book.
RT1 -
reeltrouble1 wrote: »In order to be a Reference you have to be over 50, before that your just a plain old Book.
RT1
Hey, stay out of this. This is manly talk:DMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
dB is always in reference to something else. If you are thinking of loudness or pressure in acoustics, 0dB is the threshold of human hearing (reference). It can also be in reference to a known voltage, wattage, current, intensity, velocity etc. It can be used in equation with other measures where the reference is known. dBu, dBv, dBm, dBf, dBw, etc.
In electronics, ie your receiver, it's common to use the dB log scale to display intensity. AVR's usually use a dBf scale that uses 0 as a clipping (reference) point, and counts down from there. It means nothing, and the only known quantity is the point at which the AVR will begin to melt.
Heres a calculator:
http://www.sengpielaudio.com/calculator-db-volt.htm
When you hear people using reference in two channel, it's the level they are accustomed to, or the level that the music would be played, if it were live.
I could be entirely wrong.-Ignorance is strength - -
Not true. Reference level (DD reference level that is) is 105db peaks from each channel except the sub. (it gets 115db peaks)
Since each system (if you use Avia or DVE to calibrate) is calibrated from your seating position to the same volume, (that is what the -+ for each channel is for) -20 with my system in my room should be the same volume as -20 with your system in your room.
If you calibrate using Avia you calibrate 0 to 85db because Avia is recorded to exactly 20db under reference level. If you calibrate using DVE, you calibrate to 0 to 75db because it is recorded 30db under reference.
You can now go back to your regularly scheduled pissing match...
Michael
im shure i heard that somewhere too.(the spl part) i would agree with this.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
^^^ It is, in one instance, and only one instance, Dolby Digital for HT.
Here's a good wiki for starters.
http://en.wikipedia.org/wiki/Decibel-Ignorance is strength - -
For now they are.
Reference level is a marketing concept that stuck but we're all slaves to it now. HT should have some kind of standard, so its a catch-22 as I agree with the idea. If the industry didn't develop a baseline some folks would be more confused than they are now.
I don't know what happened to playing with knobs/buttons until it sounds good but at least 2CH is free from this machine.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
