my setup
2456711
  • Sherardp
    Sherardp Posts: 8,038
    edited December 2007
    Very nice, am I correct in thinking you will have a 9.1 setup?
  • SlowcarIX
    SlowcarIX Posts: 887
    edited January 2008
    yep, its 9.1.
    the csi5 is still at the ups depot...
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • McLoki
    McLoki Posts: 5,231
    edited January 2008
    Rear speakers seem really far apart. (I am only running 5.1 though, so I could be mistaken) For those in the know - how far apart are your rear speakers supposed to be? I thought it was only 2 or 3 feet. (like I said, I really do not know, so looking to gain a little knowledge in the new year)
    Michael
  • SlowcarIX
    edited January 2008
    Keiko wrote: »
    That is some serious HT rig you got goin on there slowcar. The RX Z9 is one serious receiver. Do you think you have enough RTi4's? :D
    lol
    i like to see speaker placements for ppl who got the new yamaha RX Z11 :eek:
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited January 2008
    McLoki wrote: »
    Michael
    Hi Mike...this is my 1st try at a HT setup, i dont know what the spacing should be...i just followed the owners manual exactly
    my 7.(1x4) HT setup
    Buttkicker
  • McLoki
    McLoki Posts: 5,231
    edited January 2008
    So they are supposed to be the same distance apart as the front speakers? Did not realise that.....
    Thanks for posting that.
    Michael
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2008
    As far as rear surround speaker placement I spoke with Paul about it and Polk recommends them to be placed close to each other, of course I did not do this.........well, my experience has been that having them around eight feet apart works well, my rear are ceiling mounted and I can aim the tweets. Like all things there are some room dynamics to consider, I would say that keeping them around 3 ft off the side walls is a good idea.
    Never had anyone complain about the rear speakers.
    RT1
  • SlowcarIX
    edited January 2008
    McLoki wrote: »
    Michael
    Mike, do different brands of avr require different speaker positioning/placement? :confused:
    my 7.(1x4) HT setup
    Buttkicker
  • McLoki
    McLoki Posts: 5,231
    edited January 2008
    Could be - Like I said, I only have 5.1 right now. On my Pre/Pro there are 3 settings (from what I remember) 1ft. apart, 12" -30" apart and more than 30" apart.
    Like I said, that is from memory so I could be mistaken on the exact distances, but it is somthing like that....
  • SlowcarIX
    edited January 2008
    RT1
    RT, the automatic setup should take care of sound levels for each speaker right?
    YPAO Automatic System Calibration
    Yamaha’s YPAO system uses a small microphone and sophisticated equalization to automatically set the best sound for any room, no matter where the speakers are. First it checks the speaker connections and phase of each speaker. Then it sends out tones which are captured by the microphone to analyze the room acoustics and sets a variety of parameters, such as the speaker size, the distance of the speakers and even the sound pressure level, etc. Until it achieves the best sound conditions for your room and you don't have to do anything!
    RX-V2500 and newer models have an improved system that is faster (less than three minutes), also adjusts frequency response, and provides three programed EQ patterns, plus the ability to manually adjust parametric EQ settings. Six YPAO settings can be held in memory and recalled via two system memory buttons on the remote control.
    my 7.(1x4) HT setup
    Buttkicker
  • capitan100
    capitan100 Posts: 172
    edited January 2008
    Very nice indeed...
    Sony DA7ES 7.1 A/V Receiver
    Sony DVP-NC80V - SACD/DVD player
    CS400 - Center channel
    RT2000i - Fronts
    RT1000i - Surrounds
    a/d/s MS3/u - subwoofer
    Hitachi 62 inch HD TV
    2 Channel Room
    Niles HDL-4 Speaker Selector
    Niles HDL-6 Speaker Selector
    Sony V555ES receiver
    Sony DVP-S7700
    Polk SDA-2B
    Polk Monitor 5
    Thiel 03a
    B&W 2001 ZMF
    Signet SL-250 B/U
    a/d/s L400e
    Wharfedale Valdus 100SE
    Polk PSW 350 - subwoofer
    Pioneer Elite Big Screen
  • SlowcarIX
    edited January 2008
    there are 2 bass reflex ports on the RTi4 (lower front and upper back behind the black plastic hanger plate)...are both of them connected?
    my 7.(1x4) HT setup
    Buttkicker
    treitz3 Posts: 20,142
    edited January 2008
    My gawd, have you ever thought about moving your sub to where it could breathe? That thing is squeezed in there like......***clears throat***......well, I won't go there. Seriously, would you consider moving the sub to a location that would best suit the acoustics of the sub and room?
  • Sherardp
    edited January 2008
    treitz3 wrote: »
    While youre at it, spread the 15s out a tad bit wider and toe them in slightly.
  • SlowcarIX
    edited January 2008
    treitz3 wrote: »
    i was going to put it on the left side of the left lsi15 but there is a woofer on the side.
    Since bass is a movement of a lot of air...there is a big gap between the lsi15 and the feet...not enough? :confused:
    Whats a good spot for the sub?
    This is my 1st try at a ht system...bare with me :o
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited January 2008
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited January 2008
    Sherardp wrote: »
    Me? move the 15s apart more?
    my 7.(1x4) HT setup
    Buttkicker
  • Face
    Face Posts: 14,340
    edited January 2008
    SlowcarIX wrote: »
    I believe he was speaking to you.
    They should be equal distance from the ideal listening position and equal distance apart from each other. Like a equilateral triangle.
    I have no personal experience with LSi15's, but as far as toeing them in, it's worth a try. I found that it gives better imaging and detail.
  • Sherardp
    edited January 2008
    Slowcar it was only a suggestion, you may notice improvement, I have as Face mentioned.
  • jflail2
    jflail2 Posts: 2,868
    edited January 2008
    Nice slowcar, its starting to come together!
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited January 2008
    Those single black chairs look comfortable! where they from?
    nice setup btw, that's alot of 4's
  • SlowcarIX
    edited January 2008
    Face wrote: »
    the fronts of lsi15s and face of tv lines up
    lsi15s are 8ft apart
    ear to screen is 12ft
    need to pull the speakers apart more
    thx for advice!
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited January 2008
    Sherardp wrote: »
    i'll try it out. thx
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited January 2008
    black single chairs are from ikea - the model name is POANG
    they are very comfortable!
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited January 2008
    btw...can subwoofer stay or it needs to be moved?
    my 7.(1x4) HT setup
    Buttkicker
  • Systems
    Systems Posts: 14,872
    edited January 2008
    Very nice! Only one concern "for me" though. I see the space and where the speakers are located. Everything in its place and may just sound great. But I'd be the first to bang my head SEVERAL times on the rear mounted by the door. Just me and my wine talking....LOL. I'd bust that speaker every time I opened a bottle...turn the corner coming into the room and catch the rears every time. Just me and knowing me. But it looks good bud.
    Testing
    Testing
    Testing
  • SlowcarIX
    edited January 2008
    :D
    i already "walked" into them twice! lol
    dont mind walking into them if i get good sound :)
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited January 2008
    one last item...just waiting for the banana jacks to get in :)
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    edited January 2008
    subwoofer good there?
    my 7.(1x4) HT setup
    Buttkicker
  • McLoki
    McLoki Posts: 5,231
    edited January 2008
    For toe in - the inside edge of the speaker should be pointed at your ear on that side. (well start with that anyway and tweak from there....)
    I though the sub was ok where it was at, but to be honest, your best bet is to put some wood on your couch, set the sub on it (basically so the sub is firing into the wood rather than into the couch cushion), play some bass heavy music and crawl around on the floor till you find a place that the bass sounds good. Then switch positions wth the sub. Sounds really stupid, but it works pretty well.
    Michael
