my setup
SlowcarIX
SlowcarIX Posts: 887
edited August 2009 in Speakers
TV - Mitsubishi wd-65734
AVR - Yamaha RX-Z9
Fronts - Polk Lsi15
Center - Polk Csi3
Presence - Polk RTi4
Surround - Polk RTi4
Back - Polk RTi4
Sub - Polk DSW600
Source - Yamaha DVD-S2700
and maybe a D-Sonic 1000S for the Lsi15s
room is 20'x20'...all paid and will be delivered saturday dec 15/2007...good combo?
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612
Post edited by SlowcarIX on
«13456711
  • beardog03
    beardog03 Posts: 5,550
    edited December 2007
    datsa lotta RTi4`s !!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • SlowcarIX
    got them for a good deal, 145/pr new
    my 7.(1x4) HT setup
    Buttkicker
  • Sherardp
    Sherardp Posts: 8,038
    I particularly like the D-Sonic. That thing is a monster, you'll be impressed with it. Everything looks good, though I would subtitue the LSi 15s for an RTi10 or 12 to have everything matched. Or just go all LSi. Also I would go for the CSi5 instead of the 3 for better dialog. Last but not least go for a better sub, SVS since theyre on sale.
  • SlowcarIX
    i actually got the RTi12 initially, then changed it to the lsi15...
    let me search around and see if i can find the csi5 for a good price
    on the d-sonic, i keep going back and forth on the 1000s and the 500s....the lsi15 are rated 250wpc, 4ohm...and the 500s puts out 500wpc, 4ohm...seems to be enough for the LSi15?
    Also spec on the icepower module in the 500s seems a bit better than the 1000s
    http://www.icepower.bang-olufsen.com/files/solutions/icepower500aspdata.pdf
    Vs.
    http://www.icepower.bang-olufsen.com/files/solutions/icepower1000aspdata.pdf
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    bump for more advice on the d-sonic amp
    thanks
    my 7.(1x4) HT setup
    Buttkicker
  • McLoki
    McLoki Posts: 5,231
    If you are going to stick with the LSi15's, you should really look at replacing the center with the LSiC.
  • Sherardp
    As for more info on the D-sonic 500S, I havent had my ear on it, The 1000S is my first go at the D-Sonic stuff, and I can tell you right now I love what I hear from the unit. Very detailed, very good bass and midrange. As mine has'nt exactly broken in yet, its only been in my system since this past Saturday. I dont think you can go wrong with either. The units are constructed very well, 20lbs may not seem like allot but these units are solid. Email Dennis for any questions you may have, he's nice guy to work with. And last but not least heed McLoki's suggestion on the LSi or Rti speaker selection. Though being that you have Rtis mentioned for the other speakers I would consider the Rti 10s/12s which should save you some coin and put that towards the SVS sub.
  • Pepi28
    Pepi28 Posts: 248
    McLoki wrote: »
    I'm with Loki on this one too.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • Ricardo
    Ricardo Posts: 10,634
    What is a "Presence" speaker? Never heard of that.
    SOPA
  • SlowcarIX
    Pepi28 wrote: »
    i'll look for a piece of lsic...
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    Ricardo wrote: »
    #10 and #11 are the presence speakers
    my 7.(1x4) HT setup
    Buttkicker
  • Systems
    Systems Posts: 14,872
    SlowcarIX wrote: »
    Ive heard about that feature of Yamaha's Isnt there even an AVR that puts a speaker right above the listener?
    Testing
    Testing
    Testing
  • SlowcarIX
    above the listener = on the ceiling, above the listeners head?
    my 7.(1x4) HT setup
    Buttkicker
  • ruf993turbo
    ruf993turbo Posts: 39
    Post some pics of your setup! Sounds like a great setup!
  • SlowcarIX
    havent gotten far...:p
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    my d-sonic m500s
    front
    back
    belly
    this unit has some weight to it, very solid construction! :D
    my 7.(1x4) HT setup
    Buttkicker
  • Sherardp
    Welcome to D-Sonic, another Icepower pimp has joined the ranks. Setup looks good thus far, I suggest cable management right now so everything will be under control as you go. I didnt take a pic of the bottom of my amp, 1000S but now I know what it looks like. Those things have very solid construction. Congrats, now lets break open those boxes bro. I also recommend Signal Cable for your speaker wire and Interconnects for your amps.
  • ruf993turbo
    I got some new speakers coming today for my master bedroom....I'll post those pics up when the guy delivers them. Should be really soon! :D
  • ruf993turbo
    Here it is guys....it's actually a gift from my gf for my new house that I'm having built. Hope you enjoy the pics! When the speakers and components for my theater room comes in, I'll post some pics of those, you guys will be blown away!
  • SlowcarIX
    very nice! i think they look better w/o grille - the kevlar low/mid are awesome!
    why different colors?
    mine are mixed too...front/center/sub = black
    6 surrounds = cherry
    my 7.(1x4) HT setup
    Buttkicker
  • Sherardp
    I never thought about mixing speaker colors, but that doesnt look too shabby. What amp you using on those. What models are they? Congrats, and what will the rest of the system consist, Im hoping a projector and screen is apart of the mix.
  • cfrizz
    cfrizz Posts: 13,415
    WOW! some good looking setups taking shape! Congrats to you both.
    I want to see a pic of the Polk DSW sub.
  • ruf993turbo
    Not trying to thread jack, but here's an explanation of my setups:
    I'm running a Classe SSP-600 sound processor with a Classe CA-5200 200Wx5 on them. Source will be a PS3 for BluRay and Rotel RCD-1072 CD player. This setup is for my bed room. As for the question of mixing colors, my dealer did not have the rears and center in black, so they let me take the display home why I wait for the black version to come in...that's all.
    As for my living room, I will be using the same Classe sound processor. But for amplifier I will be using FIVE of the Classe CA-M400, these things are 80lbs each! Three each to power FR, FL and center. One to power the two rear surrounds and one to power the side surrounds. Speaker wise, FR, FL and center will be powered by B&W 800D (the towers shown in the pic below, I will post pics of them when they arrive) and for the surround rear and sides will be using B&W 803Ds which are the tower pictured in the pic below the 800Ds. Finishing the speakers off will be a pair of Revel B15a 15" subwoofer (in the last pic). I have not decided on audio and video source yet. I will post my setup once they arrive and then when my new home is finished building, I will post pics of them all set up! I can't wait for the living room setup :)
  • SlowcarIX
    cfrizz wrote: »
    front
    back
    belly
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    Sherardp wrote: »
    i thought all copper is the same...got a 500ft spool of 12AWG cable :o
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    B&W 800D *drool*
    i grew free standing diamond windows for a couple of years...properties nothing come close in the materials world :D
    my 7.(1x4) HT setup
    Buttkicker
  • McLoki
    McLoki Posts: 5,231
    Damn - very impressive setup Ruf. Will be interested to see pics and get your impressions when everything is in place.
    Enjoy.
    Michael
    BTW - So when is the housewarming?
  • ruf993turbo
    McLoki wrote: »
    Enjoy.
    Michael
    Thanks, don't even know when the house will be done yet :( There are some appliances, wood flooring and granite that are taking longer to import in than expected....kind of aggravating me. When everything is done and I'm moved in and setup, any of you that are local to me are more than welcome to come and check out the system! :D
    I need to stop thread jacking SlowcarIX (I appologize) so I posted my own thread, after I got done setting up the speakers. Thread located here:
    http://www.polkaudio.com/forums/showthread.php?p=763798#post763798
  • SlowcarIX
    my 7.(1x4) HT setup
    Buttkicker
  • SlowcarIX
    my 7.(1x4) HT setup
    Buttkicker
