Signal Cable vs Blue Jeans Cable
MKZ
I'm a little confused to buy these affordable cables. Which one is better interconnect?
Is capacitance matter for sound quality? Blue Jeans 12.2 pF/ft vs Signal 17.3 pf/ft.
Thanks.
Signal Cable
Blue Jeans Cable
Thanks.
Signal Cable
Blue Jeans Cable
Post edited by MKZ on
This is a no-brainer. Signal all the frickin' way. Unless you are on a really tight budget. Signals worst speaker cable sounds better than BJC's best. Detail, Bass, Resolution, Soundstage, Dynamics are all better from Signal.
That being said, Signal costs considerably more than BJC. Both are excellent valuers for the money. -
I cannot speak of BJC as I do not own any of their products. My entiire HT is wired with cables from SC. You just cannot beat the price and quality. End of story.Michael
NORTH of 60° -
I have never used any Signal Cable. But that being said, I certainly have no complaints about BJC. Well made, wonderful connectors that slip on & off like a dream, and at a reasonable price.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
I've owned both and Signal Cable is the flat out champion in this duel to the death.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
There's no difference; all cables sound the same._________________________________________________
This isn't a cut and dry question, Signal cable has 3 different models of cable while Blue Jeans can have close to 20 depending on the coax picked.
Capacitance is important, so is inductance, resistance and shielding.You just cannot beat the price and quality. End of story.
That is a matter of opinion.
If you are looking at the Analog 2s (the spec you gave) all they are is Belden 89259, which you can get at BJC for less. If you want bullet plugs you can get them at Heartland Cables for less then Signal as well.
I have had good experiences with all three companies, with my preferred vendor being HeartlandCables. -
Just go get some Rat Shack cables and call it a dayLife without music would♭
Techincal specs? What are those . . . I bought Signal because they are pretty.
I use coat hangers, uncoated of course."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
I never understood this comment, how on earth would you use a coat hanger as a cable? I can see speaker cable, use 2, but I can't see this being physically possible for interconnects. -
2 Coat Hangers are needed, 4 are needed for Bi-Wiring.
Ok 6 are needed for Tri-Wiring
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Coat hangers are great for bending and setting your interconnects around tricky corners. The dynamics aren't as great as other solutions, but with the right Eichemann Bullet PLugs you can get some good results.
Is that why i get no sound?"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Did you sauder the connections? Try crimping.
Seriously, BJC is good stuff as well as Signal Cable. I went with Signal because Frank has helped out a lot on this forum and he's a stand up guy and gives a 5% discount to Polkies.
I work hard for my money and I don't mind giving it for Signal Cable products.
SolidSqual wrote: »Did you sauder the connections? Try crimping.
It might needs ceramics or cements for connections and better sounds.:D -
BINGO!If you are looking at the Analog 2s (the spec you gave) all they are is Belden 89259, which you can get at BJC for less
Blue Jeans cable version is not as "pretty" though. And Signal Cable supports the Polk Community.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
BINGO!
How does he support the Polk community? By charging $6.00 a foot for the same cable BJC sells for $0.55 a foot? And then giving 5% off? Wow, incredible support. -
That might quite possibly be the most trollish post I've ever seen on this forum.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
He supports the Polk community by giving away products at our gatherings; at the Chicagofest everyone came out with something.
Not sure how you get to that $0.55 per feet; I went to the BJC site and the cheapest 3 ft interconnect is $26.75????
Because we are talking Analog 2 comparisons here, right?
EDIT: I found the 89259 in BJC; price is $22.50 for ONE 3 ft. cable. Does not sound like $0.55/ft to me_________________________________________________
Yeah, I found that Heartland cables are most bang for the buck if they use the same cable. Is it?
BJC
Heartland Cables
SC
Or
DIY -
Let's see... I have a 6' pair of SC Ultras in my 2 channel rig that Frank DONATED as a door prize for the Polkfest at Troy's house.
Wow...that IS incredible support!"Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
William? William where are you? Please come back and fix the mess you left around here..._________________________________________________
I don't know what you're looking at but you can't get Belden 89259 coax for $0.55 a foot anywhere!How does he support the Polk community? By charging $6.00 a foot for the same cable BJC sells for $0.55 a foot? And then giving 5% off? Wow, incredible support.
Blue Jeans 89259 IC's are like $8-9 less expensive but the terminations don't look near as nice as Signal Cable.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Add 6 feet to it, price goes up $3.25. Add 6 feet to the Signal cabe, price goes up $36.00. And the Signal cable is $49 for two feet, so 3 foot is $55. Just a little more (over double) than BJC, for the same cable. -
why limit yourself to just these two brands of cables?PolkFest 2012, who's going>?
And how does that compare to saying $0.55 a foot???? Yes, there are price differences, but there are also different terminations, and also different profit margins maybe?? I will gladly pay a bit more for Signal just for the personalized service I get from Frank. But I will never bash BJC.
And yes, Frank and Signal Cable supports the Polk community, no matter what you say._________________________________________________
The terminators are different, so I compared the price of the wire. Different margins? I'll say... -
WM2, you are a putz, He has donated a lot of cable to many of our events with no questions asked. At the lllinois gathering he gave away 3/pr reg speaker cables; 3/pr bi-wire speaker cables; 6 power cords; and close to a dozen interconnect pairs. No questions asked and he didn't even know most of us.
Plus giving a 5% discount across the board to any Polk Club member is certainly not nec., but he does it anyways. In my book I'll recommend him everytime. Not to mention his cables are hand assembled at his shop and the quality is top notch as well as the sonics. I'll pay extra knowing his character and the fact that he will make things right *if* there is a problem.
You can certainly choose not to buy his products, but STFU when it comes to questioning his integrity and what he has done as far as support around here. All you seem to do is troll around here acting like an ****.
Both are homegrown companies. Both use the same wire. One makes it pretty & makes you pay for it & one doesn't.
Both are quality cables. I let my wallet, & practical nature decide who got my business.
Basically it went something like this... Wires stuck in the back of a machine that were not distinctly in plain view that weren't really going to be touched after connected.
Winner BJC!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
