SRS interconnect cable
Neskahi
Neskahi Posts: 297
This question must seem stupid, but to be sure: On the interconnect cable
for SDA SRS's, does the blade actually connect to the other blade on the ends of the cable? And pin to pin? They aren't crossed are they. I am having to make a cable and I woke up in the middle of the night with this thought and cant put it to rest. Thanks
SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
Post edited by Neskahi on
  • Neskahi
    Neskahi Posts: 297
    edited September 2007
    I think I just figured out that a switch in wires is made at the interconnect
    receptacle, according to the compendium.
    SDA 2.3TL/Stock..
    SDA 2B RDO's
    Snell Type CV
    SDA 1.2TL's
    GFA7700 Adcom
    GFP750 Adcom
    TFM55X Carver
    M90 Pioneer/C90 Pre
    Yaqin MC10l
    Marantz DVD-8400
    Carver m1.5T
    DV-79avi Pioneer
    TFM35X x 2
    F1nut Posts: 51,763
    The SRS's use a blade/blade cable and both wires carry a signal. Since you mentioned a pin, you can't have SRS's. In the pin/blade version, only the pin carries the signal unless it's the AI-1 version in which case both wires carry a signal.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Maybe he means one of the pin/blade SRS models (2.3TL, SRS 1.2, etc.)rather than the original SRS from 1985.
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Raife, can you clarify for me that it is correct for my CRS+ blade/blade connections to be small blade left to large blade right? This is the only way I have gotten a homemade cable to work properly.
  • DarqueKnight
    Dennis,
    If you look at the CRS+ schematic, you see that the blade connections are reversed at each speaker. Therefore, the small blade of one speaker connects to the large blade of the other speaker.
  • Dennis Gardner
    I haven't ever had an original SDA cable apart to see the crossing, but wiring it large to large/small to small sure sends the amp into protect mode.....
    F1nut Posts: 51,763
    Yeah, I'm sure that's the case.......just trying to keep things straight to prevent any confusion down the road.
