SRS interconnect cable
Neskahi
This question must seem stupid, but to be sure: On the interconnect cable
for SDA SRS's, does the blade actually connect to the other blade on the ends of the cable? And pin to pin? They aren't crossed are they. I am having to make a cable and I woke up in the middle of the night with this thought and cant put it to rest. Thanks
SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 1C/Solens/RDO's [gave to my Uncle]
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
M91 x 2 Pioneers/C91 Pre
Yaqin MC10l
DCD-1520/1560/2560 Denon
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2
Post edited by Neskahi on
I think I just figured out that a switch in wires is made at the interconnect
receptacle, according to the compendium.SDA 2.3/RDO's... xovers by Ben
SDA 2.3TL/Stock..
SDA 2B RDO's
Snell Type CV
SDA 1.2TL's
GFA7700 Adcom
GFP750 Adcom
TFM55X Carver
M90 Pioneer/C90 Pre
Yaqin MC10l
Marantz DVD-8400
Carver m1.5T
DV-79avi Pioneer
TFM35X x 2 -
The SRS's use a blade/blade cable and both wires carry a signal. Since you mentioned a pin, you can't have SRS's. In the pin/blade version, only the pin carries the signal unless it's the AI-1 version in which case both wires carry a signal.Political Correctness'.........defined
President of Club Polk -
Maybe he means one of the pin/blade SRS models (2.3TL, SRS 1.2, etc.)rather than the original SRS from 1985.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Raife, can you clarify for me that it is correct for my CRS+ blade/blade connections to be small blade left to large blade right? This is the only way I have gotten a homemade cable to work properly.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis,
If you look at the CRS+ schematic, you see that the blade connections are reversed at each speaker. Therefore, the small blade of one speaker connects to the large blade of the other speaker.Proud and loyal citizen of the Digital Domain and Solid State Country! -
I haven't ever had an original SDA cable apart to see the crossing, but wiring it large to large/small to small sure sends the amp into protect mode.....HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Yeah, I'm sure that's the case.......just trying to keep things straight to prevent any confusion down the road.Political Correctness'.........defined
