Dedicated Line?
124»
  • Systems
    Systems Posts: 14,872
    edited September 2007
    MikeC78 wrote: »
    Better fault protection, how do you figure?
    Because if there was a failure to occur on that line that drew excessive current then a 15amp breaker would trip sooner than would a 20 amp.
    but I believe skimping on your power isn't one of them.
    Mike it is for this reason that I ran the 12ga wire to feed my amps.The fact that I use the smaller breaker does not diminish this.
    Testing
    Testing
    Testing
  • MikeC78
    MikeC78 Posts: 2,315
    GV#27 wrote: »
    True to a point, but that's not the real reason behind a breaker? If something electronically is drawing excessive power, then the fuse on the unit itself is what blows/breaks. The breaker is just a distribution of power, you don't want to overload and trip it.
    I'm no expert by any means, but that to me just makes no sense.
  • MikeC78
    Had to consult with my father on this one(who's a retired electrician).
    You are suppose to match the load size to breaker, which I see in what you are saying now. But there is no "fault" protection, unless you get a fault protection breaker, a regular breaker will not have fault protection.
    I have three amps on one 20 amp breaker, and If I crank my system to loud levels, I can easily push the 15 amp rating. The reason I would always use 20 amp circuits for my HT.
  • Systems
    MikeC78 wrote: »
    Yes that IS the whole purpose and function of the breaker.Internal fuses within a component are not going to protect for a fault that happens between the service panel and the AC wall outlet.
    Testing
    Testing
    Testing
  • Systems
    MikeC78 wrote: »
    but there is no "fault" protection, unless you get a fault protection breaker, a regular breaker will not have fault protection.
    When I say fault I mean a short,not a ground fault which a GFCI outlet protects against.
    Yes and apparently my amps current demands are within the 15 amp rating of the breaker im using.
    Testing
    Testing
    Testing
  • SKsolutions
    SKsolutions Posts: 1,820
    GV, I think he means Arc Fault, which would be on the breaker.
    So, are the lines in yet?????????????????????????????? I'm on to new digs in 12-14 months, so I'm not putting a line in here, but will be at the new place. I'd love to read about the improvement. Maybe post a new thead. . .. I've done my part in derailing. . sorry.
    -Ignorance is strength -
  • Systems
    Thanks SK that may well be what he meant.
    Apologies to you EarlyB for sidetracking the thread.
    Testing
    Testing
    Testing
  • Early B.
    Early B. Posts: 7,900
    Not yet. Hopefully, it'll go in on Saturday. Just depends on the availability of the installer. I'm gonna buy the wire tomorrow. When it's done, I'll start another thread.
    "God grooves with tubes."
  • Music Joe
    Music Joe Posts: 459
    You are going to like what they do top to bottom.
