Holy SonoSub!
ben62670
ben62670 Posts: 15,969
edited July 2007 in DIY, Mods & Tweaks
I have decided to build a sonosub. I am using a Dayton Titanic 15" woofer Fs at 19.96, and 800watts nom. The amp I will be using is a bridged GFA-555 putting out 850 watts clean at 4 ohms. I will be using 18" sonotube, and I am using sonosub.exe for the design. The program already has the driver loaded into it. The subs overall height will be over 83 inches with end caps included. I am starting this project tonight. I should be done Thursday. :D
Ben
Post edited by ben62670 on
«1345
  • Systems
    Systems Posts: 14,872
    edited April 2007
    Cool, be sure you take lots of pics of the build and post them.I bet you are going to like the results.
    Testing
    Testing
    Testing
  • engtaz
    engtaz Posts: 7,672
    edited April 2007
    Lets know how it goes and if it scares the neighbors. LOL
    engtaz
    engtaz
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2007
    Awesome!
  • ben62670
    edited April 2007
    I just finished making the circle pieces for the top, and the bases. I am making a top kinda like a chimney top so the whole thing will be symmetrical. I want to veneer the thing, but I would need 2 sheets to do it. It will have almost a 64 inch circumference.
    Ben
  • dorokusai
    edited April 2007
    You should paint it flesh colored, with a purple stained top....see if anyone gets it.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited April 2007
    dorokusai wrote: »
    roflpmp NICE,very nice
  • ben62670
    edited April 2007
    Well just finished gluing the inner baffles together. Woofer will be here Thursday. I'm working on the tube tonight, and the caps, and the port.
    Ben
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited April 2007
    dorokusai wrote: »
    They would all think it came from Jenna Jameson's house...:eek: :D
  • ben62670
    edited April 2007
    Maybe I should put a 1.5x8" port in the side about 36" from the floor? Can anyone recommend good port lube? :o
    Ben
  • Bill Ayotte
    edited April 2007
    ben62670 wrote: »
    That would be awesome, but your junk might get ripped off in the process if that massive **** is running......:eek:
  • ben62670
    edited April 2007
    I was thinking leave it on and do a sine sweep:D
    Ben
  • dudeinaroom
    edited April 2007
    ky no need for a sweep, just set it at 10 hz and it will be hummering very well
  • dorokusai
    edited April 2007
    I think a 10hz test tone would provide a happy ending to that movie.
  • Ricardo
    Ricardo Posts: 10,634
    edited April 2007
    We want pics!!!!! (of the building process....)
    SOPA
  • engtaz
    engtaz Posts: 7,672
    edited April 2007
    pics pics pics
    engtaz
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    So I see you decided not to go with Pr's....
    Way to go Ben
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • ben62670
    edited April 2007
    I messed up and didn't have my memory card in my camera, and I can't find the usb cable, but here is a pic of the half finished construction.
    Gross volume 10.17 cu ft
    Estimated weight over 100 lbs
    Total height85 inches
    Port 6" 30 long
    Driver 28 lbs
    15 Hz tune
    Ben
  • ben62670
    edited April 2007
    Well I have the girls today. Ashley, and JJ. 3 1/2, and 1 1/2. I gotta see if i can get away with doing some sanding, and painting. My woofer is on the truck for shipping. I have to make the legs, and finish the bottom plate. I'm thinking about using undercoating for the finish on the tube after I paint it.
    Ben
  • engtaz
    engtaz Posts: 7,672
    edited April 2007
    Put in a movie on the Projector and you will have about an hour and a half.
    engtaz
    engtaz
  • ben62670
    edited April 2007
    engtaz wrote: »
    engtaz
    That is my plan :)
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Where did you find a tube like that Ben? What sizes and how much?
    Jake
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    Local hardware store. 18"x12' $35. If you want you can come over and have the other half. That is if I don't make a second!
    It's still a little wet. Got it in just before the rain storm!
    Ben
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    Project is looking great. No hardware store around here carries that (I dont think)
    I'm trying to find one that about 14" x 4'. For an SVS 12.1. I'm trying to figure how to mount my Rythmik Audio plate amp to it. I will prpbably have to buid a seperate housing for the amp.
    But yours looks great. I cant wait to hear from you about sound quality.
    Jake
    P.S. Looks like my kind of shop too...;)
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    Pics
    Ben
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2007
    jakelm wrote: »
    check with concrete supply places. That's where I got my tube when I built my sonosub. Mine was even priced by the foot.
  • ben62670
    edited April 2007
    Also use sonosub.exe for calculations. I will be able to do some test tonight to see how flat it is with a sweep.
    Ben
  • engtaz
    engtaz Posts: 7,672
    edited April 2007
    ben,
    where did you get the sub?
    engtaz
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited April 2007
    engtaz wrote: »
    ben,
    engtaz
    Thats a PE Dayton sub right?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ben62670
    edited April 2007
    Yes it a PE 15" Titanic Mark III. Moves 3 litters of air bla bla bla...
    Ben
  • ben62670
    edited April 2007
    My ears hurt.
    Ben
