Math Problem
Recoil isn't calculated to the shooter but to the weapon. Do they give you the length of the barrel? You are not calculating work either, just force (F) so m*a should be enough based on the info given.
They don't give the length of the barrel.
All that's given in the problem is what I quoted in the original post.
I've been trying desperately to figure this out since it is due in 2 days and will be graded.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
The average barrel length is what, 30-40 cm? After the bullet travels that far the gas is vented and doesn't matter anymore.
Well, the problem does not talk about barrel length so I don't think it is part of the calculations.
I'm starting to think this is straightforward - but I'm still unsure as to how to do the problem.polkaudio RT35 Bookshelves
So does that mean the recoil force adds up to = 8 times the force of the first shot?polkaudio RT35 Bookshelves
you have to figure out part the problem to get the last part, a given round has a known fps "feet per second value" and that said the weight of the bullet comes into play for the force applied to find out the distance traveled.:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
I don't know the answer to your question, but recall from some full auto training that Newtons Third Law may apply. The basic rule was shoot in shorter bursts to maintain accuracy to reduce muzzle rise. But as it has been mentioned, weapon design affects the ability to control it. All I remember from school daze is to not look too far past what was presented in the question. What I remember about actually shooting a full 30 round clip from an M-16 in a standing position is you had to continually lean into it to keep on target.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
as i have only had general science i am not a lot of help as to this but somthing that might help: Ek=1/2 mv^2, that is kenetic energy(J) = 1/2 mass(Kg) times volicety(m/s) times volicety(m/s)
1J=1N*1M but i dont think distance helps much because in the calculations that is didtance strate up and not sidewase, as far as i know you can calculate with that unless you it is a straight line then you use the calculations for the simple machine inclined plane, wish i could help more but i cant do this with out more information, the acceleration would make this a quick calculation but without it i am stuck.Polk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT -
I understand that F = m*a and that F = d(mv)/dt, but I'm unsure as to how to find the distance that the bullets traveled in the work equation. Since W = F*d and F = m*a, then Work should equal W = m*a*d.
Well why didn't you just say so in the first place? The answer is STFU MF. -
This problem falls under the Impulse-Momentum Theorem. Average force = mv/t. The mass is 8*.00745kg. The velocity is actually the change in momentum which the initial velocity is 0 so the change is 293m/s. The time is how long it takes to fire the 8 rounds which is about .48 seconds. This will give you an average force of 36.38N (Newtons). The number of shots is not relevant. You can figure it with 1000 rds with t=60s and get the same answer. This means the equation could be simplified to f = mvr. I am not an expert but am pretty sure this is correct. Good luck!
0.00745 x 293 / (8*60/1000) N = 4.55N
Edit: Looks like Tex beat me to it and remembered to include the number of bullets, 8. 8*4.55 = 36.4 -
Well, I didn't know how to find the distance, and Tex just figured out the problem.
Thanks Tex!polkaudio RT35 Bookshelves
I'd like to thank you all for helping me solve this problem - I really appreciate it.
I don't know what kind of grade I would get if you guys didn't help me figure out the calculations, but anyways, I hope I get an A on the problem.
Again, thanks!polkaudio RT35 Bookshelves
Well, you're welcome, but .... I can't take ALL the credit.
....or can I ?Sal Palooza -
Thanks tex, I forgot about the change in momentum can substitute the Newtonian acceleration equations-Well done!.
(I burned all my physics and calc books when I left school and had forgot about that)
Recoil guys: He's talking about the recoil the weapon feels or the transfer of energy to the bullet. If the weapon is moving backwords/up and down, the bullet would lose speed as well since that is NOT included in the question, it should be assumed away. Remember that in physics and math, a horse is a cylinder and not a mammel with 4 legs.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
I thought it's still the same equation m * dv/dt? Change in time, dt, is the rate of the fire.
mass = 0.00745 kg
dv = (293 - 0) m/s
dt = 60/1000 s = 0.06 s
The number of bullets cancel each other out in the equation so it's not relevant.
0.00745 kg * 293 m/s / 0.06 s = 36.38 kgm/s^2 = 36.4 N -
What calculus is this? Calc 2?
Very interesting question...don't think I could have figured it out with a lot of input, either. Hope you get a good grade on it!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Just saw this.
F=ma or the recoill force of the bullet = the mass of bullet times it's acceleration.
Bullet starts with V1=0 as it leaves the barrel V2=293m/s
Time for bullet to travel (accelerate) is 60seconds/1000bullets
a=dv/dt or (V1-V2)/time for bullet in barrel
F=(7.45g)a
plug and chug
Did that help? -
audiobliss wrote: »What calculus is this? Calc 2?
Its differential calculus with physical applications. Part of my electrical engineering program.
Don't know what it is called, Calc 2 maybe?polkaudio RT35 Bookshelves
Sounds interesting enough, for sure. I'm not sure how the different Calc courses are broken up at different schools, but according to my experience Calc 1 is differentiation, Calc 2 is integration, and Calc 3 is three-dimensional applications of 1 & 2.
I haven't gotten into any physics yet, though. At least no more than the small amount of physics necessary to do some of the problems in math.
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Yes, it's more of a physics problem than math. Wait until you get to the part where you need to calculate all the applicable forces...
I'm still having nightmares of my 'Solid mechanics' classes. Ever tried to calculate forces applied to a bridge? LOL -
Well, I did differentiation and integration in HS, so maybe Calc 3? Again, the courses are not numerical at all schools...
audiobliss, are you the same audiobliss from the Definitive Technology forum?polkaudio RT35 Bookshelves
Pffft, statics was a freakin snap, I'd due trusses and structural work all day long as long as I could stay out of AC circuits and dynamic physics.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin -
Different strokes for different folks.Pffft, statics was a freakin snap, I'd due trusses and structural work all day long as long as I could stay out of AC circuits and dynamic physics.
I'm a software engineer now and my main goal is to stay away from DSP's (I work with RX's and TX's all day). They say it's not that bad but one look at those algorithms is enough to scare me away... -
Yeah, I know the AC circuits and dynamic physics stuff can be pretty hard.
I've still got 9 years of school left though.polkaudio RT35 Bookshelves
Nope, never been on that forum. I also did Calc 1 and Calc 2 in HS.
What?! So, wait a minute...how old are you? Where are you schooling? Are you some kind of genius?! :eek:I've still got 9 years of school left though...right now I am a bit younger than Sid (Vr3MxStyler2k3)
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
Interesting... there was an audiobliss on the Def Tech forum some 2-3 years ago. I think he was also from NC.
I don't want to give away my age or location.polkaudio RT35 Bookshelves
audiobliss wrote: »What?! So, wait a minute...how old are you? Where are you schooling? Are you some kind of genius?! :eek:
I think we started with those kinds of test questions around 15-16y of age (I went to school in Europe). The way it is worded can be confusing and you might think of it as a more complex problem. I think that's part of the idea too. -
I agree the question was confusing and made it seem like a more complex problem.polkaudio RT35 Bookshelves
