Myth of break in period for speakers
Home Theatre
Home Theatre Posts: 469
edited May 2011 in Speakers
Is there any truth to this? The guy at Tweeter said I should just leave my speakers on for 48 hours. If these speakers are going to get better, I will be happy.
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
«13456
  • McLoki
    McLoki Posts: 5,231
    edited November 2006
    They do break in. My LSi's sounded quite a bit different after about 100 hours of playing.
    Michael
  • Lsi9
    Lsi9 Posts: 616
    There is a perceived difference after some time but what I don't particularly believe is that you need to keep your speakers on for days, why not take your time and try to catch the percieved difference? the speakers aren't going anywhere if you plan on keeping them.
    Audio Physic Scorpio II
    Pathos Logos
    MIT Shotgun S3
    Bada HD-22 CDP
  • Frank Z
    Frank Z Posts: 5,860
    There are as many people that don't believe in the myth as there are those that do, it's almost as bad as the $$$$ wire debate. If the speakers sound good right out of the box, it (break-in) doesn't matter. If they don't, why keep 'em?
  • rskarvan
    rskarvan Posts: 2,374
    You are breaking in your ears and brain. The speaker characteristics don't change. Your perception of the sound changes.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Speaker break-in is not a myth. Period.
    Argue about cables.... argue about source vs amp.... argue about friggin' world peace, Jessica Simpson, or your favorite flavor of yogurt. But please don't tell me that many (if not all) speakers don't need time to break-in. We're not talking about needing a "golden ear" to ascertain this.
  • W WALDECKER
    W WALDECKER Posts: 900
    It is not a Myth that break in occurs in loudspeaker drivers. it is a proven fact! after a long protracted and nasty debate over loudspeaker break in @ the Audiocircles website Danny Ritchie of GR Research posted before and after testing results of a large variety of loudspeaker drivers that clearly shows that after use the characteristics of the drivers do change and can be proven with scientific measurements .thanks....WCW III
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • Frank Z
    Sorry, never have bought into the manufacturer's published hype. Moot point actually, if you want to believe it and it makes you feel better about your purchase...then thats all that matters.
  • PolkThug
    PolkThug Posts: 7,532
    The speakers might sound better BEFORE break-in, so make sure YOU are there for the first 48hrs.
    MUHAHAH
  • markmarc
    markmarc Posts: 2,309
    Look for an article in the December issue of Affordable$$Audio on this subject with scientific measurements proving one side or the other on this debate!
    Former Staff Member TONEAudio
    2 Ch. System
  • RuSsMaN
    RuSsMaN Posts: 17,986
    Ed Zachry.
  • rskarvan
    Oh come on people... yes, speakers may change an itsy-bitsy bit in the first 48 hours as things loosen up. But, the fact of the matter is that your brain, your memory, your perception changes much more than anything acoustically. We used to think cassette tapes sounded pretty good until the CD came along. Now, are brains have adjusted. Same is true with with speakers. You can claim that you have perfect perception... but, I think the physics related to the speaker and amp are much more consistent than your perception. This is what drives upgrade-itis. Our brains adjust and then we hear something that is better. Of course, there are those that think the they can perceive differing oxygen levels in the copper in speaker cables too. So, I think thats just ego coming into play (again, brain based opinions). You can't separate opinion from fact without measurements. So, until I see an Oscilliscope printout to a step function at differing frequencies... there is no point arguing with other peoples "perceptions".
  • Jim Shearer
    Jim Shearer Posts: 369
    Let me cast my vote in favor of speaker break-in!
    I do not believe in expensive speaker wire or ICs. Don't believe in a break-in period for electronics (unless you have NIB caps that have never been powered on before.)
    My non-golden ears tell me that speakers do change a bit over the first 40-100 hrs. And how fast this occurs, and to what degree, depends on the construction of the driver(s). But if the speakers sound like total crap at first, then they probably are. No use waiting for the sow's ear to turn into a silk purse.
    Cheers, Jim
    A day without music is like a day without food.
  • dudeinaroom
    dudeinaroom Posts: 3,609
    It is not a myth. The during the break in period the suspention on the drivers losse some of their stiffness and move a little smother. wires will expand a tiny bit in the voice coils and settle as heat is built up. For break in I would use a cd with a broad spectrum of sounds, not necessarily music, face both speakers face to face about an inch apart and wire one out of phase to help keep the perceived sound level down, and the volume set at moderate level( enough so you can see the drivers moving). Then let it go for around 24 hours or so if you can.
  • dave shepard
    dave shepard Posts: 1,334
    I can say that I have (for **** and giggles) bought a pair of Mundorf silver/gold caps (sized as close to the original as poss.)and put them in a spare set of RTi-70 crossovers (tweeter side) and the sound was painfully bright to the point that I had to leave the room with them still playing in about 1.5hrs the sound tamed down to the point of where it was before I changed them except with a whole lot more detail in the upper freq.. So I can tell you that the electronics will have to seat themselves before giving you their full potential not to mention the actual speakers themselves.
    just my 2 cents
    Dave
  • schwarcw
    schwarcw Posts: 7,358
    Like Dave said, the caps need about 50 - 100 hours to break in. Cheap speakers with cheap components won't sound much different. Good speakers with good crossover components will have burn in time to come into their own.
    Carl
  • Home Theatre
    Would Monitor 60's be considered a good speaker?
    F1nut Posts: 51,771
    By some, yes. By others, no. The same applies to just about all gear.
    You sure do ask a hellva lot of questions!!!
  • cfrizz
    cfrizz Posts: 13,415
    Whether it does or not, don't worry about it! Just play your system & enjoy!
  • Joey_V
    Joey_V Posts: 8,600
    Does a system break in?
    I think it might, but I havent heard an audible difference really. I remember having a pair of the Axiom M22ti bookshelves and I had a problem with the vinyl veneer and Axiom sent me another pair of the M22... I had two pairs in my room (the old one was about 4 months old, so plenty "broken in" by anyone's standards). I plugged them both and I heard absolutely ZERO difference. The beauty is, the whole time, I thought my Axioms broke in. Funny how it was all in my head.
    As for the other speakers, I think I got used to the sound rather than them breaking in.
    So even though I can "see and understand" how/why speakers would be able to break in (as opposed to the dielectrics of cables and whatnot), I have not experienced break in.
    Joey
  • DarqueKnight
    DarqueKnight Posts: 6,765
    This is somewhat like asking if sneakers require break in. The answer is some do and some don't. Likewise, some speakers require a break in period and some don't. Some speaker manufacturers specify a break in period and some don't.
    With the virtually infinite variety of speaker designs, materials, and testing procedures among speaker manufacturers, it is impossible to make a valid blanket statement regarding the requirement for break in. For example, one manufacturer's speakers may require a 50 hour break in before the driver suspensions reach their optimum compliance and the crossover capacitors reach their optimum performance capability. The manufacturer may decide to do the break in procedure as part of the manufacturing process (which adds cost) or they may decide to do only minimal functional testing and let the consumer do the break in. Dunlavy Audio Labs, a former manufacturer of very expensive (up to $35,000 per pair), very accurate, high performance speakers, performed extensive break in procedures on their speakers because they wanted them to be delivered to the customer at their optimal design performance.
    The requirement for break in could also vary among the different speaker series from the same manufacturer. A manufacturer could skip break in procedures for their lower priced series but include it in their top of the line speakers.
    From my personal experience, the LSi speakers that I purchased new (LSi7, LSi9, LSi15, LSiC) sounded great right out of the box. However, they did become more responsive with more overall detail and bass definition after about 100 hours of play. It was not a night and day difference, but it was noticeable.
  • John K.
    John K. Posts: 822
    It's been said, with only slight tongue-in-cheek, that "Break-in was invented so that we could never return anything!". See "Speaker Break In: Fact or Fiction" .
    F1nut Posts: 51,771
    Once again, Johnny imposes on us some article he dug up on the net instead of sharing his personal experiences. Of course, the fact that he thinks Sony mega changers and Axiom speakers are the best available, leaves no doubt as to why he has nothing personal to share. :rolleyes:
    I'm your huckleberry.
    BTW Ron, do you need an oscilliscope printout to tell you if something sounds good or not!?! Yeah, that's what I thought.
    I really have to wonder what is wrong with some of you. If you can't trust your own ears, WHY are you even in this hobby???
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    If it makes you more happy with your purchase to believe speakers dont break in you should rock on with your bad self.
    RT1
  • Frank Z
    FI,
    Did you even read the entire article? Why is is so hard to accept that YOU just might be wrong. Perhaps it's your ears that are AFU.
    At what point did Ron say he needs to see a printout to tell if a speaker sounds good? Are you refering to this?...
    I DO trust my own ears and they tell me there's no difference. I'm in this hobby for the love of music and good sound from my HT and 2-channel systems, not for bragging rights about how much I spend or save. I'm not in it to waste money on a speaker that doesn't sound good right out of the box.
    You claim there's a difference after X amount of hours, fine. If that's what you believe, fine. I claim that there's zero difference after the sam amount of time. Who's right? Either one of us can make any claims we like to suit our argument and could easily find something in writing, somewhere, from aN expert to support our arguement. So whos expert is right?
    Too many of you have folks have taken this old debate way to far. Stop for a minute, listen to your gear, relax a bit. Does anyone else's belief about break-in affect your enjoyment of what you're hearing? I didn't think so.
  • zombie boy 2000
    Well.... if it's as simple as my ears simply acclimatizing to a particular sound, I think I'll just borrow John K.'s Sony boombox and wait for the "magic" to happen....
  • MSALLA
    MSALLA Posts: 1,602
    I herd an improvement with a set of Boston VR-30's I had. The Monitor 40's never really seemed to change. I'm sure they all improve after break-in, just some more then others.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • Flash21
    Flash21 Posts: 316
    Speaker sound can definitely change during initial use. And blaming it on perception doesn't wash, because I am not listening to them during break-in, except for short sessions each day or so.
    And I should note that I have been a skeptic when it comes to things like equipment break-in, powercord "sound", etc., but have been forced to acknowledge they do exist by my own ears. In other words, I am not predisposed to believe in such things, but have come to accept the evidence in front of me.
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • FicmanS
    FicmanS Posts: 134
    Sure seems like my 70's took 100 hours to break in, noticeable difference in sound from them now verses when I bought them. I don't think my hearing has changed in that amount of time... I think it took warming mine up more than just a few times for them to warm (sound wise) up...
    Call me crazy I believe the break in period is valid...
    Rockin' In My House :D
    Pioneer 50 inch Plasma TV
    Denon AVR-3806
    Denon DVD-1930ci
    Polk Montor 70's
    Polk PSW-12
    Polk CS2
    Polk Monitor 40's
    Sirius Satellite Radio, Monster 3500MKII
  • wingnut4772
    wingnut4772 Posts: 7,519
    I can definitely say that my Von Scweikerts have opened up since I have bought them. I am breaking in my new surrounds also.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
    F1nut Posts: 51,771
    Frank,
    Unlike you or I, the posters in question want to rely on "tests" rather than their own ears, which was my entire point.
    When I'm wrong, I admit it. In this case, I'm not.
