Home Theater Receivers
Thanks Paul. I finally made a decision and got the 4ES and I'm really happy with it. My polk sounded better than with the other unit. This thing is a tank! I think it weighs 44LBS. I just watched WINDTALKERS and it sounded great. I did a noise test with this unit by choosing CD without playing any CD and turned the volume up and as the volume got louder I started hearing hisses coming from the speakers. Does anybody know what causes this? Is it the harmonic distortion? Any input would be greatly appreciated. NICOSONY 4ES RECEIVER
EARTHQUAKE 5CH AMP.
DENON DVD 2200
SONY 400 DISC CHANGER
RTI50, CS400I, RTI38, RT55I, INFINITY IL SUB
MONSTER CABLES
SONY LCD 50" VEGA -
. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces. -
Here is my question. I hve Polk R40 in front R15 in back and cs175i for a center. I have $600 to spend for a reciver. I'am looking at the Pioneer VSXD811S, Pioneer VSX41 ELITE, Denon AVR1803, Sony ES STR-DA1ES ,and the Yamaha HTR-5490. Which is the best reciver out of those. I have to buy a new reciver in the next 2days so I need to know soon.Any advice is welcome.
Nico- i have the V555-ES receiver, and I love it a lot. I have the same problem as you where I can hear a faint hissing noise when I turn the volume up with no cd. It is not really noticeable unless I turn it way up. It really doesn't bother me, but I'd like to fix it anyways. I have talked to good guys about it and they said it can be fixed and it has been occuring on some ES models. I just haven't had the time nor want to part with my receiver for any period of time.Home Theater
Sony DA7ES 7.1 A/V Receiver
Sony DVP-NC80V - SACD/DVD player
CS400 - Center channel
RT2000i - Fronts
RT1000i - Surrounds
a/d/s MS3/u - subwoofer
Hitachi 62 inch HD TV
2 Channel Room
Niles HDL-4 Speaker Selector
Niles HDL-6 Speaker Selector
Sony V555ES receiver
Sony DVP-S7700
Polk SDA-2B
Polk Monitor 5
Thiel 03a
B&W 2001 ZMF
Signet SL-250 B/U
a/d/s L400e
Wharfedale Valdus 100SE
Polk PSW 350 - subwoofer
Pioneer Elite Big Screen -
Thanks I also went to good guys and talked to someone extensively regarding the hissing. We actually listened to different receivers ie. DENON, YAMAHA, and even their PARASOUND amp. and they all had the hissing when we tested them. So he says that it is normal for all unit to have some hissing. NICOSONY 4ES RECEIVER
EARTHQUAKE 5CH AMP.
DENON DVD 2200
MONSTER CABLES
SONY LCD 50" VEGA -
Nico:
The hissing is inherent noise being produced by the amplifier. All amps, no matter how well built, produce some noise. The key is how much noise do they produce compared to the gain they provide. This is known as the signal to noise ratio or S/N for short. If you were actually playing a music source at that volume setting, it would be so loud that the background hissing would be completely inaudible. S/N ratios of around 100 dB are typical for quality audio components. In short, it's nothing to worry about.
Doc"What we do in life echoes in eternity"
SVS -
Thanks Doc that makes me feell a lot better. NICOSONY 4ES RECEIVER
EARTHQUAKE 5CH AMP.
DENON DVD 2200
MONSTER CABLES
SONY LCD 50" VEGA
