Rti10...which receiver?
Hi, just one quick question. For the Rti10 can the Harman Kardon 435 handle it? or would you guys suggest the 635. can save like 100 bucks if the 435 is good enought.
thanks.
thanks.
If you want to spend under a grand and don't want to go separates, I recommend the Harman Kardon avr-635/40
Buy a Denon receiver for RTi's. Great balance. Better than HK (IMHO)My current new system (step by step
A/V Receiver: YAMAHA RX-V657
DVD Player: YAMAHA DVD-S657
Main Towers: polkaudio® Monitor 50
Wiring: NeoTecH KS1007 OFC High Definition Speaker Cable ( 2 x 2.64 mm² ) -
i'll properly go with the 635. you guy know how much for a decent seperate amp would cost? if i chose to get the 435.
I have the same speakers with a Pioneer Elite receiver, which is no slouch, and am also looking for a good amp to power them. The HK 635 is a good choice, in addition to more power I think it has more features than the 435.
Unfortuantely a decent two channel amp can run 500.00 or more, almost as much as the receiver. I am thinking about a Parasound/Halo amp because they are on the warm side and I feel the RTi-10s are a little bright. Don't have one yet and it will be some months before I can get one. So when you get your setup let us know what you got and how it sounds.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
I just got an Anthem MCA 20 to power my RTi10's and they sound great i was running it off just an onkyo txnr801 but now i have the anthem doing the amp work and i am so much happier.Reciever: Onkyo TXNR801
Mains: Polk RTI10's
Center: Polk CSI5
Sub: Polk PSW505, Polk PSW10
CD: Onkyo DXC390
DVD: Samsung DVDHD841
HDTV: Panasonic 44" LCD
XBOX 360 -
plattq45 wrote:Hi, just one quick question. For the Rti10 can the Harman Kardon 435 handle it? or would you guys suggest the 635. can save like 100 bucks if the 435 is good enought.
thanks.
Harman Kardon DPR 2005.
cleaner and smoother then the other H/K products.
120x7 and actually delivers.
It's under 1grand at www.jr.comJVC 61FN97
Harman Kardon avr330
RTi10 l/r front
CSi5 center
Atrium 45 (four for the surrounds.) -
Patience is the key here. Look for used amps on Audiogon and eBay. Let Richie Rich buy it new, when the upgrade bug bites he'll sell it to you (for a lot le$$)plattq45 wrote:i'll properly go with the 635. you guy know how much for a decent seperate amp would cost? if i chose to get the 435.
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
I agree, I have a Denon as a pre/pro. An Adcom 5503 is powering my tens. I never even attemped to run them off a receiver.RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James -
RichterCAG wrote:Harman Kardon DPR 2005.
Onecall has the DPR 2005 for just $499.99 + shipping after instant 25.00 off coupon. This price is only good for the weekend. Sounds like a great deal on this HK.
http://www.onecall.com/ProductDetails.aspx?ID=23876Receiver: harmankardon AVR235
Mains: polk R30
Center: polk CSi3
Rear Surrounds: polk R20
Subwoofer: polk PSW404
DVD: Panasonic DVD-S29 -
Mike682 wrote:Onecall has the DPR 2005 for just $499.99 + shipping after instant 25.00 off coupon. This price is only good for the weekend. Sounds like a great deal on this HK.
HK DPRs will not perform anywhere close to 120W. Test shows they are around 39W with all 7 channels driven.
Looks like HK is discountinuing them and thats why the good deals are showing everywhere.
Dont buy DPR. Period.
_Golu. -
Golu wrote:HK DPRs will not perform anywhere close to 120W. Test shows they are around 39W with all 7 channels driven.
_Golu.
HK does very well in power output specs actual vs published..
Here are a couple of examples..
AVR 7300 speced @ 110W x 7
S&V measured 139W/CH (all channels driven) 21% above spec
202W into 8 Ohms & 343w into 4 Ohms
AVR330 speced @ 55W x 7
S&V measured 66W/CH (all channels driven) 17% above spec
95W into 8 Ohms & 148W into 4 Ohms
If you need a few more just hit the goggle button and type in...
hkamps_exceedspecs..JVC 61FN97
RTi10 l/r front
CSi5 center
thanks go much guys... didn't know i have so many options
i just now thought about the receiver, Im using an HDMI/SACD dvd player and having a hard time finding a H/K that have HDMI input/output that is not up the mountain price
I love my 635 and I personally feel like it has way way more than needed for the rti10's that I use. Its just so simple and clean and works each and every day just like it is supposed to.Harman Kardon AVR635
RTi10's Up Front
CSi5 Center
RTi6's Rear Surround
Furman RA-1210:rolleyes: -
RichterCAG wrote:HK does very well in power output specs actual vs published..
Richter,
I think what Golu was trying to comment on was the DPR line and not the AVR line. The HK AVR does extremely close to its given ratings. All the reviews and inputs I have seen on the DPR is just the opposite. It is almost like there are two Harman companies, those that make the AVR and those that make the DPR.
Of course I have not owned either so I am just relaying back what I have read. Hope I didn't inadvertently mislead anyone.Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote -
I understand, of course there is a difference between the AVR and DPR line. If the DPR line from H/K is pure junk, I will conceid to that.
Afterall, just doesn't add up why a 110x7 watt reciever would sell for 500-700 dollars...if the wattage was TRUE.
But now I am a bit concerned. You see, a few days ago I recemended the DPRO2005 sight unseen to a fella on irc...yeah, you can see where this is going.
JVC 61FN97
RTi10 l/r front
CSi5 center
Well if he bought it based upon your recommendation are you going to buy it off him? Might make a decent boat anchor!!
Wonder why the better recievers have pre-outs?
Start thinking current ratings/headroom, bottom line, receivers are pretty terriffic for HT, most all of them are lacking or compromised as far as Hi-Fi audio goes. No need to worry though, enjoy the ride, its fun.
RT1 -
i was wondering if the H/K 240 has pre-out for external amp?
and how many channels amp should i be looking at?
thanks. -
plattq45 wrote:i was wondering if the H/K 240 has pre-out for external amp?
thanks.
yes it does. look at either a 5ch. amp or 7ch. depends on if you want 7.1 or 5.1. If you sit against the rear wall, 7.1 is useless. -
thanks.... im looking at a 5.1
The essential truth of the matter is that no reciever will drive the RTi10's as they are meant to be. Useless venture. Believe me, I know first hand.JVC 61FN97
RTi10 l/r front
CSi5 center
What a crock.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
dorokusai wrote:What a crock.
Not a crock, but a truth.
The only sugestion from the members' of this forum are 8,000 dollar parasound power amps.
"oh gosh, its only 4 grand! Thats a budget deal!"JVC 61FN97
RTi10 l/r front
CSi5 center
That's not true, but feel free to generalize all you want. Happy listening!CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Generalizing in audio is very foolish. Also making an absolute statement is foolish. There are receivers that are capable of running the 10's beyond what most would consider very loud.
http://www.outlawaudio.com/products/rr2150.html
http://www.rotel.com/products/specs/rsx1067.htm
http://www.rotel.com/products/specs/rsx1056.htm
http://www.adcom.com/newproducts/gfr700ii.htm
http://www.bkcomp.com/avr507.asp
These are just off the top of my head. I much prefer seperates but one of the above receivers for HT would do quite well with the RTi line.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
heiney9 wrote:Generalizing in audio is very foolish. Also making an absolute statement is foolish. There are receivers that are capable of running the 10's beyond what most would consider very loud.
Generalizing is very unfair and is harmful to the forums. I retract my words and appologize to anyone who may have been offended.
Only frustrated. :cool:
Back to the topic ... my system is currently driven by a reciever, an H/K 330 but its not sufficent for me. I agree that power seperates are the best way to go, and along those lines I was/am considering Parasound HCA-1200.
but then again, let's face facts...the only contributions are "omg...its 12,000 dollar parasound. thats for budget buyers..get that for your rti10s." your heads are in the cloudsJVC 61FN97
RTi10 l/r front
CSi5 center
The greatest enemy of truth is very often not the lie - deliberate, contrived and dishonest - but the myth - persistent, persuasive and unrealistic.
Blaming the prince of the fools should not blind anyone to the vast confederacy of fools that made him their prince. -
JVC 61FN97
RTi10 l/r front
CSi5 center
Ive got a pair of RTi-10s with a Denon AVR 2801 and it sounds awesome.....so what am i missing ?
Just enjoy what you have, don't get caught up over a few comments.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Dorok is spot on, truly.
Do not allow the comments of others to detract from your enjoyment of home theatre gear. Unless you are running Bose equipment. narf! :rolleyes:JVC 61FN97
RTi10 l/r front
CSi5 center
