The 1.2TL, Project Monolith
1…789101113»
  • ptrooper
    ptrooper Posts: 837
    edited November 10
    This is quick and simple ,they will be completely inert, Ai told me so :D Best to run it past the site Engineer @Gardenstater
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
    xschop Posts: 5,919
    What about the Unknown engineer?
    Surely he knows or has knowledge of all things inert.
  • Gardenstater
    Gardenstater Posts: 4,990
    I don't think the heat shrink would do much to lower the resonant frequency from around 2.2 kHz. It might lower it maybe 3% to 6% mostly from the small additional mass. It won't effect the flexural rigidity much at all.
    The adhesive layer will add a small amount of damping, but the resonant frequency is still well above any of the standing wave modes in that enclosure so it shouldn't really be an issue.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • ptrooper
    ptrooper Posts: 837
    Thanks @Gardenstater ,I'll try not to overthink it , do it once ,do it right. I like OVERKILL .
  • skipshot12
    skipshot12 Posts: 2,171
    edited November 11
    ptrooper wrote: »
    Wrapping them in this should do the job! What do you think?
    Was thinking the same thing.
    Or wrap it with dynamat?
  • ptrooper
    ptrooper Posts: 837
    @skipshot12 Or both? >:) Ill look into the sleeve sizes.It would remove a little internal vibe reflectivity from the dynamite aluminium I believe.Maybe a 1/4" butyl wrap like a barber pole under the sleeve ? There's still a bit of time until they go in.
    I'm dreading shipping !
    I was looking at a Mobile fidelity cd for $ 24 and $44 shipping :s
    xschop Posts: 5,919
    I could actually fit all 20 in a medium International flat rate.
    Final glue up before they head to the land down under.
    Pound each assembled, not bad...
  • ptrooper
    ptrooper Posts: 837
    Can’t wait thx Rob !
    Has any one dealt with this company ? Or , is there somewhere in the states that can do?
    https://audiotechnology.dk/
  • ptrooper
    ptrooper Posts: 837
    Exciting stuff! When the dowels go in , I’ll be having the crossover plates and tweeter bezels
    Anodised .
    I been using AI with its free 3 daily attempts and am close but still deciding on the tweet colour , it’s the duelund cap colour!
    What do you think?
    xschop Posts: 5,919
    The orange hue addition looks very nice.
    I never post dimensions to your plates cause they are 1-offs, but IIRC I tapped them 8-32 on the back.
