CRS+ RestoMod
Looking forward to the finished amp pics. Quite a lot of fine work here.
Fly cutting the long thin covers caused to much heat and started to warp. Decided to put on large upright belt sander 120 grit and cleaned them up. Will finalize at 320 grit hand belt sander to contrast with the flycut faceplate...
Don't take experimental gene therapies from known eugenicists. -
240 wet sand....
Went with .218 drill thru and touch deeper countersink to give more case adjustment of stainless flat heads and add bling before final sand...
Last piece of the puzzle...
Will tie it in with a chamfer to match the faceplate...
