The 1.2TL, Project Monolith
1…7891012
    xschop Posts: 5,932
    The semi-rings only need 2 taps per driver and 2 extra hurricane nuts.
    Easiest way to do the 2 taps is use a spring loaded auto-punch while the MW is mounted to the baffle. Remove MWs, drill and tap with a new tap drill combo.
    Easiest way to drill the 4 extra MW thru-holes is with a jig on a drill press. No need to tape off anything, just blow off with compressed air when done.
    I'll be glad to send you the one I built if you want to do this mod. It stiffens the baffle further and obviously couples the MWs completely.
  • Unknown
    edited October 19
    xschop Posts: 5,932
    Good deal. It's not vintage Polk unless you can remove a pound of goo lol.
    What is the round tube behind that tweeter cutout?
  • Unknown
    edited October 20
    xschop Posts: 5,932
    Is there a bolt in the back baffle holding the tube?
    Viking64 Posts: 7,836
    edited October 20
    It seems to me that the tube had something to do with the threaded rod that allowed the 1.2s and 2.3s to be attached to the wall. It allowed the rod to screw in and out without disturbing or getting caught in the fiber.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,224
    Viking64 wrote: »
    That's correct.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • Unknown
    edited October 20
  • michaeljhsda2
    edited October 20
    The cardboard tube fell off of mine and since I was never going to use the bolt to attach it to the wall I threw the tube in the trash and used hot glue to seal it on the inside.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    ptrooper wrote: »
    Thank you , good to know. I didn’t think to look and I wonder how long the internal thread is ? Bolts a must , to be air tight ?i2yf7bdl1hfb.jpg
    I can't recall exactly but I think the bolt that's shown in your picture is only the depth of the back of the cabinet with a nut on the inside and then the cardboard tube is glued on to the back of the cabinet.
    SDA SRS 2.3TL's
    SDA 2B TL's
    xschop Posts: 5,932
    edited October 21
    Taking the design a little further....
  • Unknown
    edited October 22
  • Unknown
    edited October 22
    xschop Posts: 5,932
    edited October 22
    Those mortars even come rigged with 2 fuses. :D
    Seriously, 6061-T6 only expands (CTE) 0.023mm or 0.0009" / 3.3 linear ft.
    And 1.2TL rods only require a third of that, so 0.0003"
    I'd wager these large baffle Polks are a multitude higher travel than that just off low freq vibes when the volume knob is twisted clockwise lol.
    I'm also not going to use the locknuts on mine for simplicity sake. Blue Loctite is all that is needed and one less wrench to handle and turn while up in the cabinet. :)
  • Unknown
    edited October 22
    xschop Posts: 5,932
    edited October 22
    I'll post some pics this weekend of them in my 8TLs when I permanently glue the ends.
    Initially, just use a marker on threads near alloy so when you go back with glue, you only coat below that line with Blue Loctite. You'll have 10 minutes to adjust so a win/win there too.
    24 hrs full cure time will match Power Grab or Liquid nails.
    I adjusted the pointed spud base dimension for faster MDF penetration before full seating.
    Used the same Superglue I use on MW magnets to permanently attach the large washers last night. Already cured this morning rock solid. I'll do the same for your 1.2TL batch.
    I Should have built these long ago for my old Polks.
    Early bird gets the java...
    xschop Posts: 5,932
    edited October 23
    These have been installed last couple days with off-on loud playing. Luckily clearanced the MW ring and tweeter magnet on these 8TLs. Semi-Rings are still glued SOLID to the MDF. Had to remove a 1.5 x 1.5 inch sq. Sound foam at back.
    Install just needed a 13/16" wrench to hold bolt hex while hand twisted rod to firm seat at front.
  • Unknown
    edited October 23
    xschop Posts: 5,932
    edited October 23
    Did those pics for install reference with washer/bolt/wrench combo. I just squeezed on some PowerGrab and reinstalled.
    Too many irons in the fire this week. Working on transformer housing and gaskets...
    xschop Posts: 5,932
    Here ya gooey go... B)
    After it dries, I'll cut a slit into the Dacron and pull it back up.
  • Unknown
    edited October 23
    xschop Posts: 5,932
    Pic is upside down, but I think the point was a little off from dry run. Indeed it lines up faster with some wet goo applied. :D
  • Butter
    Butter Posts: 70
    Everything lines up faster with wet Goo!
    xschop Posts: 5,932
    edited October 25
    Got to listen to them today for about an hour. ZERO baffle vibes now at high volume. Passes Cameo's "She's Strange" test lmao. Let them play loud while I worked on my amp in the garage shop too. Fun times.
    https://www.youtube.com/watch?v=jUgsmsvSYow
    xschop Posts: 5,932
    Set these up on CNC lathe so I can make more later. Headed home for glue up. Cutting the 1.125" stock for programming tomorrow night.
    xschop Posts: 5,932
    Programmed the tip to have a slightly wider base, allowing for a little thicker layer of glue to remain...
    xschop Posts: 5,932
    ptrooper wrote: »
    Excellent stuff ,This transition zone adds substantial structural rigidity and acts as a localized vibration dampener <3
    I'd like to see what Unknown thinks lol
  • Unknown
    edited November 10
    xschop Posts: 5,932
    edited November 10
    You could try a couple vs. butyl wrap and see if they pass the ring test. These 1.125 dia. should be more inert than the 1"
