Mini models of the SDA SRS. i need help with crossovers.
    heiney9 Posts: 25,721
    Chains, links and rods.
  • Lerjebrink
    Lerjebrink Posts: 46
    Todays progress. Tweeters + wire are still left. And then there is one more speaker to do😅
  • Lerjebrink
    I am thinking of making a YouTube vid about them when i am done, with all the details, could be fun for you guys to nerd on
  • BlueBirdMusic
    BlueBirdMusic Posts: 3,137
    When I first saw you thread, I wanted to ask "WHY?".
    Now, I admire your creativity, determination, and "PATIENCE" especially with people.
    This is an entertaining "PROJECT"!
    Harry / Marietta GA
  • Lerjebrink
    Electronic test. Works beautifully. Now it is time to solder up speaker number 2.
  • skipshot12
    skipshot12 Posts: 2,171
    That looks awesome.
  • Lerjebrink
    xschop Posts: 5,919
    Epic. Where's the SDA IC cable?
  • Lerjebrink
    xschop wrote: »
    I decided to go without it. Many people in this thread told me that it would only work if the distance between the 2 rows of speakers are more or equal to ear-to-ear distance. So i scrapped the SDA cable. The tweeters are still 4 way tho.
    I have no idea if it would have worked with it
  • Gardenstater
    Gardenstater Posts: 4,990
    I feel like a lot of people are looking at those and saying how cool it would be to own something like that. Super job.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,919
    Lerjebrink wrote: »
    xschop wrote: »
    What is the center to center distance of the midwoofers?
  • Lerjebrink
    xschop wrote: »
    Lerjebrink wrote: »
    xschop wrote: »
    Guessing about 140mm, not exactly sure right now
  • Gardenstater
    Might've worked still, for nearfield SDA.
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • ptrooper
    ptrooper Posts: 837
    Lerjebrink wrote: »
    xschop wrote: »
    You don't always have to set them up for critical listening. Don't listen to the naysayers. If they’re anything like the big boys, they will have a nice balanced sound within reason to some placement.. I would have liked to see an SDA cable, you could remove it later! How are they sounding?
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
  • Conradicles
    Conradicles Posts: 6,436
    Those are purdy!
    VR3 Posts: 29,759
    In my random experiments I've found the sda channels add a little something regardless of the spacing but the closer to the stereo array the more narrow the sound and the farther away the wider more diffuse. There is a goldilocks zone where it works better than others but it is doing something regardless.
  • Conradicles
    I like the goldilocks zone quite well
    msg Posts: 10,650
    Anyone got a spare KVA?
    Ok, so now there are just regular speakers. Not SDA's. Sort of lets all the air out of the balloon for me. Cool looking, but nothing going on with the sound. :/
  • Lerjebrink
    heiney9 wrote: »
    You must understand too, that i dont want to pay 400$+ for more components that maybe wont make a difference. Maybe in the future, who knows.
  • Lerjebrink
    ptrooper wrote: »
    Lerjebrink wrote: »
    xschop wrote: »
    They sound better than i thought. The tweeters are so crazy clean sounding.
    Lerjebrink wrote: »
    heiney9 wrote: »
    Still a cool project, one I don't have the talent to complete. Spending another $400+ wouldn't get you an SDA type presentation. If they sound decent or even if they don't, still a cool looking project.
    xschop Posts: 5,919
    Lerjebrink wrote: »
    xschop wrote: »
    Lerjebrink wrote: »
    xschop wrote: »
    You'd still get SDA-IACC with a slightly smaller soundstage width than a set of 2B's. At nearfield, it may be even more expansive, who knows. JAT
    Great vision and execution either way.
  • ptrooper
    ptrooper Posts: 837
  • Lerjebrink
    Second one soldered.
    Now its time for dampening. Then the trim pieces on the outside
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,399
    I sent Matthew a photo of your "air guitar" model and he responded:
    "Okay, I've been laughing ever since receiving this. Somebody has way too much time...."
    I explained to him your project of building a small sized replica of the SDAs. I'm sure he'll love it.
  • SeleniumFalcon
    Matthew responded:
    "Kudo's to his model building skills. Looks faithfully to about 1/3rd or 1/2 scale. They could sound pretty good but will require quite a bit of tinkering. If the center to center distance between the low-mid drivers is still 6" - 9" SDA will work well. If the passive radiator is actually an active woofer keep the crossover below 100Hz. Does he have an idea how to wire the arrays and setup crossovers?"
    -msp
  • skipshot12
    Either way, damn friggin cool project 👍
  • Lerjebrink
    They are soon done! Just the front and side panels left
  • Lerjebrink
    Matthew responded:
    -msp
    Wow!
    The mids are under 6” between eachother. So i went without IC cable on them.
    I wanted good bass, so i made the passive radiator like the original. And i am going to use a seperate 8 inch sub, so i can get ”good” bass.
    All the crossovers are finished and playing good,
    I am going to measure them up soon.
