The 1.2TL, Project Monolith
1…5678911»
  • ptrooper
    ptrooper Posts: 671
    Ok. I’ve ordered a tape measure. Check out the 1970’s remaster from another Aussie classic band .
    Sounds extraordinary on SDA’s
    https://www.youtube.com/watch?v=oYSdjCu_lC4
    treitz3 Posts: 20,353
    What do you have that going from/too?
  • ptrooper
    ptrooper Posts: 671
    edited September 24
    From the Luminu2x -to the Soon to be replaced Jlti oppo205 ! New dac will be a ???
    This SInope SE cable is replacing an Audioquest diamond .75
    After ten hours I’m very impressed,sounds more dynamic with very Airy highs , tighter deeper textured bass and the midrange is very holographic becoming effortless ,Liquid almost
    I’m finding the more upgrades I’m doing ,the better control the Monoliths bottom end has , it feels like more energy and control is focusing into the midrange and top end.
    The Audioquest is no slouch though ,I feel it’s a bit more analytical and in my face than the SInope,I loved the AQ for the 6 weeks I had it and highly recommend it !
    xschop Posts: 5,796
    treitz3 wrote: »
    That'd fix my printer problem.
  • ptrooper
    ptrooper Posts: 671
    edited 10:55AM
    xschop wrote: »
    treitz3 wrote: »
    That'd fix my printer problem.[/hrt5lsc242kv.png
    Will .75 be long enough for your printer?
    xschop Posts: 5,796
    Lol. My printer needs an audio grade USB so it can make the annoying sound clearer. :D
