1…201202203205207
    treitz3 Posts: 20,366
    Fine tuning only. At this point? Nothing drastic. Just simple adjustments to get the system optimum.
    This sounds SO good!!!! I am in hog heaven!
  • rebelsoul
    rebelsoul Posts: 802
    Looking forward to the results. My next upgrade is room treatments
    billbillw Posts: 8,367
    Turned It On...
    And listened to this entire album on a really good SDA system 🥰
    nooshinjohn Posts: 26,178
    Turned mine on for the first time in nearly two weeks... Poured a glass of Jefferson's and turned off the lights. Toby Keith tonight, followed by some Dolly.
    So, I played around tonight with the sub adjustments, after listening to many selections after the new panels came in.
    I made 4 slight adjustments on the back plate of the Rhythmik F-25's. Let me be the first to tell you that I am in awe. It seems that now no matter what I throw at the system? It delivers it in spades.
    Please allow me to correct my last statement. When I say in spades? I really mean in an aspect that words cannot really describe.
    This is not only the best I have heard my system....this is the best I have heard any system I have ever heard. This is so susinctly musical, completely natural and thoroughly enjoyable. Every song I listen too.
    I should have done this years ago. It would have GREATLY increased my listening pleasure. I am simply listening to music....the way it was meant to be listened too.
    I could literally walk around the lead singer(s) and still have room to walk back to the other performers within the sound stage, with room to spare.
    This is F'n awesome!!!
    Words cannot describe...
    edited September 11
    Well, technically, it was my theater system, but I'll share anyway because I'll be doing the same for my 2-ch system shortly because they share the same power conditioner.
    I woke up this morning, and as soon as I left the bedroom, I could hear a noise that only means something is broken. It was coming from the basement. A harsh 60hz electrical noise of some sort. I first thought it was the compressor on my mini fridge in the theater room, but when I got down there, I traced the sound to my Belkin power conditioner that's been in service since around 2012. It stopped when I pressed the switch to turn off the switched outlets (this has a mixture of switched and unswitched outlets). I unplugged it and went to work.
    After work, I put it on the bench and took off the cover. Nothing charred, but when I tried to power the switched outlets, the noise was clearly coming from one of the relays. I suspected the DC clamping power wasn't clean and some ripple was getting through the power supply caps. Close inspection showed some cheap Chinese caps from around the capacitor plague years. Some were slightly bulging. Swapped out four 100V/470uF caps (was lucky to find them in my stash) and reassembled. Back to normal. I'll be putting in an order to DigiKey to restock that size because I used all that I had left. I need to get some other sizes too, because, you know, it's nice to have various common PS cap sizes in your repair kit. I'll probably redo the one in my 2ch as soon as I get resupplied.
  • WagnerRC
    WagnerRC Posts: 2,227
    impressive, jealous
  • PSOVLSK
    PSOVLSK Posts: 5,452
    I can’t remember what Pink Floyd title we listened to at SWAF, but it was unreal. I’m not a big fan of NIN, but what we heard at SWAF was just absolutely fantastic. Since I’m very familiar with your integrated, somewhat familiar with your speakers, and have heard your source, I know you are in audio nirvana. Happy for you and jealous of you at the same time.
    edited September 19
    So I sit down to listen tonight... I think this counts. Anyway, the best improvement I have made in the past couple weeks is killing off the damn cricket that has been messing with me for the past week or so. Tonight, the little basterd was hopping all across the soundstage in plain sight, daring me to take him out. I obliged him with a thick, heavy book and still he tried to get away. It took several more drops before I was able to subdue him but finally there will be no more unwanted frequencies injected into my listening session.
    That can be extremely aggravating!!!
    pitdogg2 Posts: 27,914
    Cricket season sucks, the good thing is it usually doesn't last but a couple of months. Them be some long months truth be told.
  • Conradicles
    Conradicles Posts: 6,436
    On a tube hunt, I need more patience.
  • erniejade
    erniejade Posts: 6,327
    indyhawg wrote: »
    @SCompRacer - I had it hooked up to my NAS. I was still under 2 TB.
    Did you every try it with an internal drive? When I used to run one, I found internal sounded slightly better than external.
  • agingboomer
    Reinstalled my Pioneer CT-F9191 cassette deck into my study system after some mechanical restoration.
  • ptrooper
    ptrooper Posts: 837
    Noice, Brings back memories of my first auction bought deck"ctf 1250" <3
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
  • displayname
    displayname Posts: 1,248
    tratliff wrote: »
    I mentioned in a for-sale thread about a month ago that I was waiting on the delivery of a SonoruS ATR10 R2R and that I would provide some details and pictures once it arrived. Well, it has now been in my system for about two weeks. When I first received it, I had it sitting on a temporary rack in front of the two racks while I went through setup, testing, and trials. I'm happy to report that it now has a permanent home on top of the first rack.
    This source is amazing.
    The level of detail, imaging, and texture I'm hearing from the ATR10 are not something I have heard in my system to date.
    With the purchase, I was also able to secure several premium titles on 15 IPS tape. My goal was to get a broad spectrum of music so I could evaluate what works and sounds best on the format. The initial titles were:
    • Pink Floyd — The Wall
    • Pink Floyd — Dark Side of the Moon
    • Pink Floyd — Wish You Were Here
    • Pink Floyd — Animals
    • The Beatles — Abbey Road
    • Grover Washington Jr. — Winelight
    • Nirvana — Unplugged
    • Michael Jackson — Thriller
    • Nine Inch Nails — Pretty Hate Machine
    • Kraftwerk — Minimum-Maximum
    I then ordered three additional titles from Rhino High Fidelity:
    • Fleetwood Mac — Fleetwood Mac
    • ZZ Top — Tres Hombres
    • Yes — Yes
    I've now listened to every tape, with several getting multiple spins. There have been some real standouts. Winelight, Animals, Thriller, Minimum-Maximum, The Wall, and Pretty Hate Machine have all been particularly impressive.
    Thriller is a great example. That album is already a fantastic production, but hearing it on the ATR10 is something else.
    Minimum-Maximum was another one that really surprised me. The sense of space and imaging was excellent.
    Overall, I am extremely happy with the purchase and with what I'm hearing from the ATR10. It has definitely become a serious source in my system, and I plan to continue expanding my tape catalog in the future.
    So awesome, and such a killer starting collection!
    Discogs
  • tratliff
    tratliff Posts: 1,906
    tratliff wrote: »
    • Yes — Yes
    I’m really enjoying it. Have not played a record since I got it. Need to get back to the turntable! Listening to Kraftwerk now. Very interesting tape. Image/placement/spacial/texture is great.
    2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
    There was a reason most studio recordings were made on R2R up until the 80's, when digital took over.
  • displayname
    treitz3 wrote: »
    While most may be going to digital, if you look at some of the best recordings even of more recent work, some of the very best are still recorded to tape. The first example that comes to my mind is Tool - Fear Inoculum.
    Discogs
  • Geoff4rfc
    Geoff4rfc Posts: 3,062
    Awarded the DAC with an AudioQuest Monsoon power cable. Initial reaction?? Hearing subtle detail not heard before.
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
    PC's can make one heck of a change. That fo'sho'.
    This song I just ran across. I don't recall ever hearing it before. Sounds wonderful in the room (or lack of a room, shall I say).
  • newbie308
    newbie308 Posts: 848
    @Geoff4rfc That Polk Forum Snake River Audio cable demo enlightened me to just how significant of an impact a quality power cable can make. To be completely honest, before I heard it with my own ears, I doubted the impact a PC could make. The AQ storm series is quite good. I'm using the Blizzard PC on my power conditioner, preamp, subwoofer, and power amp. The SQ difference from the Pangea power cables was significant.
    newbie308 wrote: »
    I don't doubt that. I have a Pangea cord and it has never....well, let's just say that it sounded horrible in every application I have ever used it in. I do not get why people buy from this brand. It was a complete waste of time and money for me.
    I am not surprised at all on that one. The difference between that and the SRA PC should have been significant for you.
    A bit harsh Tom. I honestly think you are all under the influence when you claim PCs make THAT much difference. Subtle maybe, but nothing to get in arms about.
    Then we shall agree to strongly disagree. Did you participate in the Snake River Audio PC demo program?
    I can tell you with complete certainty that almost every single PC I have can make a subtle, to horrendous, to stunning difference in the sound. You don't need to take my word for it. All you have to do is listen to the folks that tried it.
    I now have the Takshaka's from Jonny. The demo cable was only a portion of what I am experiencing now (in comparison). Now that most of the most critical paths are Takshaka's? This makes the PC even more noticeable.
    I have boxes of PC's. This isn't spoken from conjecture. This is spoken from experience. If you want, I can send you the Pangea free of charge (you cover shipping) and you can see/hear for yourself. TBT, it wouldn't even be worth the cost of shipping.
    One other thing, Bill. It depends on the system's caliber, what it offers, how it is set up, dialed in and most importantly, the room acoustics. Being under the influence has NOTHING to do with it. This is based upon years/decades of listening, both stone cold sober, and under the influence.
    I didn't appreciate the insinuation on that one, to be completely honest.
  • Geoff4rfc
    @newbie308 yeah man, I was in the same camp as you...."it's a power cable, it transfers electricity from the wall to your gear, go blow smoke up someone else's skirt" lol. I've never had the caliber of gear to be able to make a distinction between cables, and this DAC??? I was also running Pangea, love em! Had the AC-14XL MKII XL from the DAC to the AVP, great shielding in that cable. Then, put in the Monsoon and now, I'm the smoke blower lol.
    Sounds like you have the Blizzard in the right places!! I'm running Pangea AC 9SE MKII Signature on my amps and power conditioner. My next move is to put the Niagara 5000 in primarily for the 2ch set up, then, I'll look at the Blizzard for the XPA-DR2 to get that last bit of refinement. Right now, the 9SE is doing a great job plugged into the PQ 707, the 5000 is where the difference is going to be!!! IF....you get tired of one of those Blizzard PC's...well.....
    B):D
    Right on man, thanks for sharing, I'd love to hear that Blizzard one of these days!!
  • Conradicles
