No, that was the one. A.I. cannot fathom or understand system synergy.
What it can do, is tell you how to hook things up, what certain functions do, how making an adjustment within the system settings will affect things, etc.
A perfect example would be for someone who doesn't know how to dial in their subs, when there are 32 different settings on the plate amp. It can tell you what each function does. What it can't do is tell you how it will actually sound in your room.
This is approaching face palm territory. You guys are giving Cyberdyne and Skynet the keys to infiltrating your homes.
I try to keep them confused and always throw other random stuff in there like ,How to make a bomb with a 45 min timer look like an accident?, Where's the best place is to bury a body on my mates property?How long does it take pigs to eat a headless body, How much weight to keep it down in sea or spring water? and best place to hide 50 kilo's of coke?. joking of course.
I'm Your Dingleberry
SDA SRS 1.2TL VR3 Duelund Monoliths<3,Lumin u2x,LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb...Working on it! -
I’ll be interested in how long it takes to fill the order. I have been working with them for more than 6 months to get an order completed. I received the panels after 4 months but 2 were damaged. Now I’m waiting on those 2 to be replaced. Their customer service is terrible and expected ship dates are way off. Good luck.
I have only worked with GIK one time and it was several years ago, but this pretty much reflects my experience. I think it was several months to get two bass traps. One had very light damage on the corner, and I decided to live with it vs waiting several more months. I honestly wonder how much of their backorders are driven by repair/replacements.
And don't forget that if it doesn't work out, you'll likely loose your shirt on the investment.Analog: Hana ML > VPI Prime Signature 21 > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
Here is a pic of Tom during that testing
Thanks @billbillw. @treitz3 I reread my original post and will take responsibility for not elaborating well enough.
I was interested in a separate DAC. A.I. knew the existing DAC in my (at that time) Marantz processor and the one in my CD player. I did not want to spend money to make a lateral move or even possibly go backwards in quality.
So I asked for list of external DACs that would exceed the quality of my existing DACs. Turns out, the Denafrips Venus was a winner.
Asking if I should buy a Bose vs Polk speaker isn't even close to what I was trying to convey.Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
Interesting turn of events today. I received the GIK replacements. If they would have packaged the original order like they did this one everything would have been fine.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
Here is a perfect example of the depth perception.
The speakers moved back at least 10 feet on the song, "The expert. The band is Yellow.
The only thing that changed was removing the diffraction part of the panel behind my head.
With this recent change, you cannot tell what location the speakers are in. Simply awesome!!!
This is just one example. There are MANY others. Wonderfully, crazy listening!!!
FSYLL
Feng Shui Yoga Listening lessons.
First lesson free.
Remove ear rings and any head wear.
Using both hands simultaneously,Pull-up and down 5 times on each ear lobe and release.
Pull ears outward gently 5 time and release .
Place palms directly over ears ,start rubbing the right ear in a clockwise and left ear in a anticlockwise motion for 15 seconds and stop.
Breathe
Move away any head hairs that maybe directly touching your ears.
With your left hand ,pinch your nose and block your nasal passage, take a big breath , close your mouth and whilst holding your breath proceed to blow for 5 seconds . Stop
Breathe
This should pop your ears ,recalibrating your Drums.
If this doesn’t work.
Chew gum for 30 minutes and
listening, begin
This is what you need....flush and cut....
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »This is what you need....flush and cut....
Clearing the forrest and setting the trail is pre Yoga instructions
@treitz3 wrote. "keep in mind, you only get something like 5 questions in one day with Chat GPT, but if you happen to have Co-Pilot, Chat GPT, or some other paid or upgraded service - I would highly suggest using it specifically for this purpose.....and be very specific. "
Tom [/quote]
And just like that ,on the day I said I can ask questions all day long, it is now limited to 5 questions only ,they'r definitely listening to us.
I will NEVER purchase from GIK Acoustics again.. They are a nothing what they used to be, TERRIBLE Customer Service, TERRIBLE Packaging, and their Craftsmanship is in the Crapper.. -
Has anyone here tried Real Traps?
I recently treated my room with a bunch of their mini traps, and had a positive experience. The placement advice was great, they're made well.
I can not speak on the shipping however. I picked them up. -
Local fella picked up my Denon DP-2000 for a recap and a going over.
Hoping that takes care of my speed at
33-1/3, holds good @ 45.
Having the guy do them all (caps) while he’s in there.
Bought this one new in 79.
Installed an SME Series III Tonearm on this one.
Getting ready to sell some of my TT’s.
We just don’t spin anymore. -
I remember your frustration with them. That's sad compared to what they once were. I purchased when they were still very good to deal with. They were very helpful with room recommendations. Our open floor plan main level is over 10,000 square feet not counting doors open into rooms, lower level. I had two setups that caused various issues and they were pretty helpful. Later I went to software (Dayton Audio OmniMic V2) for speaker setup/acoustic treatments.
This all GIK stacked bass tri traps and panels in Guilford of Maine silver papier cancelling most of ESL's rear wave south wall setup was from when the wife worked lots of hours, before she took the living room back...lol I bravely (or stupidly) told her this in mine, she can have the lower-level family room.
Well, I got an update on the panels. They have already shipped! That was much faster than I expected. Looking forward to getting them all installed. I have been enjoying the heck out of what I am already experiencing, with just that one small change.
AI will be very happy.
That’s crazy after what I just went through. Keep us updated.2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables -
Believe it or not?
I guess I should have clarified. This is apparently only two of the three panels. Not the complete order. Apparently , there are 2 pieces with the dimensions of 49x25x10 in.
I am assuming that these are the two side panels for the first reflection points. I am guessing that the panel for behind my listening chair will be delivered separately.
I got three panels for my ceiling about 3 1/2 years ago now. Had to wait quite a while for the panels themselves, but also ordered their mounting brackets. No indication when ordering that they were on back order. Finally, after waiting another two or three months after the panels arrived, the mounting brackets showed up. No tracking info. ahead of time, no “hey, those brackets will be shipping soon” email. Nothing. Just showed up out of the blue. There’s nothing to them, just powder coated stamped steel, so no good reason for the delay in my mind. Bridget in CS there was no help.
That was my last and likely final order.
Good luck, Tom.
Brian -
Well, in this case, GIK Acoustics came through with flying colors. They shipped weeks before the anticipated date. Everything arrived in perfect condition and there were no blemishes or issues at all. That said...
Leave it to Fed-Ex to screw things up. I was off yesterday and delivery was supposed to happen between 10 and 2. At around 3:30, I finally see the Fed-Ex truck come down my street....and drive right on by me. I am like, WTF? He pulled in a driveway down the hill.
Okay, no problem. He will probably swing back by my house after that delivery. Heck no, the bastage turns the other way and drives off. About 10 minutes later, he drives back by and slows down near my house. I am thinking, "cool". I'll walk out to him, and I as I start heading toward his truck, he speeds up and drives off. Again, WTF?
A couple of hours later, the package was right back where it started from that morning. Whatever. They are as bad as the brown ape company. Bunch of idiots. As big as the two packages were? They were most likely the biggest packages he had on the truck!
Anyhoo, they were delivered today and I just installed the new panels about 45 minutes ago.
I am liking very much what I am hearing. The presentation is much more musical and that depth! Man, talk about layers! There are many more subtlties that apparently were masked, as I am hearing things that are very prominent now, that maybe I had heard before (many times not), but they are now a part of the music. Overall, it is much more "musical" than before. When I say musical, it's more of a live performance, rather than a reproductive effort and there are no walls. No speakers, no floor, no ceiling...just an awesome presentation of music!
I have only listened to some Yellow and some Eva Cassidy, and so far, I am VERY impressed with the end result.
All because of a conversation with ChatGPT, some experimenting and my time. I am SO glad I did this! The texture and definition of the bass, mid-bass, and especially the vocals (male or female) are just sublime. The spatial locational cues are so much more definitive, yet at the same time, more air and aura around every single sound you hear. The layering sounds much more natural and not so....definitive within the layering. I guess that's the aura I am talking about. Much more natural and realistic.
Bottom line, everything I have heard so far has been fantastic. Had I put a black sheet in front of the entire system and had I not known what I did with the changes of the panels? I would swear that I replaced the system. With all of the same attributes, but with none of the deficiencies. Although there weren't many deficiencies after removing that deflection panel, this is definitley next level sound. Simply put? It's a performance, not a playback. So very musical...
So, as I listen more? It becomes apparent that I need to reajust how the subs/mains interact with the room, given the new parameters.
That should be pretty easy. Still in awe at what this change has made. This is so much fun!!!
Fine tuning only. At this point? Nothing drastic. Just simple adjustments to get the system optimum.
This sounds SO good!!!! I am in hog heaven!
Looking forward to the results. My next upgrade is room treatments
Turned It On...
And listened to this entire album on a really good SDA system 🥰
See profile for rigs. Nothing else here. -
Turned mine on for the first time in nearly two weeks... Poured a glass of Jefferson's and turned off the lights. Toby Keith tonight, followed by some Dolly.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
So, I played around tonight with the sub adjustments, after listening to many selections after the new panels came in.
I made 4 slight adjustments on the back plate of the Rhythmik F-25's. Let me be the first to tell you that I am in awe. It seems that now no matter what I throw at the system? It delivers it in spades.
Please allow me to correct my last statement. When I say in spades? I really mean in an aspect that words cannot really describe.
This is not only the best I have heard my system....this is the best I have heard any system I have ever heard. This is so susinctly musical, completely natural and thoroughly enjoyable. Every song I listen too.
I should have done this years ago. It would have GREATLY increased my listening pleasure. I am simply listening to music....the way it was meant to be listened too.
I could literally walk around the lead singer(s) and still have room to walk back to the other performers within the sound stage, with room to spare.
This is F'n awesome!!!
Words cannot describe...
Well, technically, it was my theater system, but I'll share anyway because I'll be doing the same for my 2-ch system shortly because they share the same power conditioner.
I woke up this morning, and as soon as I left the bedroom, I could hear a noise that only means something is broken. It was coming from the basement. A harsh 60hz electrical noise of some sort. I first thought it was the compressor on my mini fridge in the theater room, but when I got down there, I traced the sound to my Belkin power conditioner that's been in service since around 2012. It stopped when I pressed the switch to turn off the switched outlets (this has a mixture of switched and unswitched outlets). I unplugged it and went to work.
After work, I put it on the bench and took off the cover. Nothing charred, but when I tried to power the switched outlets, the noise was clearly coming from one of the relays. I suspected the DC clamping power wasn't clean and some ripple was getting through the power supply caps. Close inspection showed some cheap Chinese caps from around the capacitor plague years. Some were slightly bulging. Swapped out four 100V/470uF caps (was lucky to find them in my stash) and reassembled. Back to normal. I'll be putting in an order to DigiKey to restock that size because I used all that I had left. I need to get some other sizes too, because, you know, it's nice to have various common PS cap sizes in your repair kit. I'll probably redo the one in my 2ch as soon as I get resupplied.
