The 1.2TL, Project Monolith
1…79111213
  • Unknown
    edited August 30
    xschop Posts: 5,931
    I've done a few enclosures now, and the best way is measure front to back with a garment tape.
    Cut the dowel 1/16" longer, then belt sand til it is snug. Pre-glue enclosure where they will reside and press in to position. After that layer dries, go back and smear on a filet around the perimeter.
    Then shake those 1.2's boss.
    xschop Posts: 5,931
    It always amazes me when it comes to audio that you don't know what you're missing until you know it.
    BH5 isn't supposed to effect the enclosure volume because of the floating vinyl layer with the closed cell underneath. That floating layer tends to help with preventing sound transmission prevention. The No-Rez stuff does away with that layer.
    There have been a few ways people have done the braces, joebass3 made them out of square stock with v-blocks on the front and back so that the braces could be screwed into them. I think xschop and tool just power grabbed them into place with a slight clearance I guess, and SCompracer used a pocket hole jig and screwed and glued them into the front and back. I think another way might be with one end cut short (I'd use square stock with the corners rounded off at the router table) and at a slight angle and you could have a wedge that jams it and you could (maybe?) even listen to the configuration before gluing everything in place or maybe just tack glue with a few dabs of super glue that could be cut through (or just run a JB Weld fillet around everything) for the permanent glue. I'd use epoxy but I know that is overkill. I like overkill.
    https://www.youtube.com/shorts/YTGGRGbOGNs
    I found my old tech drawing of removable pre-loaded compression rod device I drew up when I built those Tsi's.
    Would be spendy for a set of 1.2's however, why I suggested the dowels and some Power Grab.
  • Gardenstater
    Gardenstater Posts: 4,991
    The Jean Maurer speakers have that system, but with a woofer that is "isolated" from the baffle with soft rubber (probably sorbothane or the like) and then they use the "tension rod" (compression really!) that contacts the driver and pushes on it and in turn the driver pushes on the other end of the tension rod which is adjustable for length at the rear of the speaker which is a sand filled sandwich deal with other layers designed to dampen the driver's motion. That's the only speaker I've seen that on so far.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,931
    Mine are designed from alloy hex rod to save machine time and have a pointed divet for placement accuracy. They'd have to be done on lathe.
  • Unknown
    edited August 30
    xschop Posts: 5,931
    I updated drawing for hand twist rod dowels and a locknut. Most of the vintage enclosures would only need two maybe three of them.
  • motorstereo
    motorstereo Posts: 2,428
    Why not a turnbuckle? Instead of gluing perhaps secure a nut with ears or washers attached on the outside with screws? Twist the the turnbuckle to the desired tightness and call it a day. If there's a thought of the metal being sonically reflective it's easy enough to put foam pipe insulators over them. Just a thought.
  • Unknown
  • Unknown
    edited August 31
    xschop Posts: 5,931
    This simple design accomplishes the goal. Originally had a 3/4" hex rod drawn out, but a 1" round rod will seat by hand....Unless you're a girly-man.
  • Unknown
    edited August 31
    xschop Posts: 5,931
    ptrooper wrote: »
    xschop wrote: »
    Righto, now we're on the money. looks like you've got it sussed.
    https://www.youtube.com/watch?v=M2VBmHOYpV8
  • Unknown
    edited September 1
  • Unknown
    edited September 1
  • Unknown
    edited September 1
    xschop Posts: 5,931
    Big question now is... Oak, fir, or maple, etc.?
    SCompRacer Posts: 9,408
    edited September 1
    Threading wood dowel rods popped into my head changing a push broom handle. One pic shows a plastic coupling. Various size wood threading tools are available, 3/4," 1" and larger. Use two different size dowels, male and female threads. One could make threads longer/deeper for stability. Slobber glue on threads and tighten in place.
  • Unknown
    edited September 2
    xschop Posts: 5,931
    Knock it out.
    Where are the vibes settling at now?
  • Unknown
    edited September 2
    xschop Posts: 5,931
    edited September 2
    Im working on my WOPL amp while its only 80.deg in garage lol.
    That should solve the issue.
    Forgot to add, fair dinkum.😉
  • Unknown
    edited September 2
  • Unknown
    edited September 2
  • Unknown
    edited September 2
  • Unknown
    edited September 2
    edited September 2
    For you Dr Who fans.
    Since you brought it up, number 11, Matt Smith was my fav Dr. Who.
    Doctorin' the Tardis by The Timelords, KLF Communications. AKA the Justified Ancients of Mu Mu, the JAMs,...
    https://youtu.be/DsAVx0u9Cw4?si=1-YPjYKhVSDIdbPy
