1…201203205206207
  • joecoulson
    joecoulson Posts: 4,986
    I know. Sad. Mine is still working very well, however, I just know the day is coming when the streaming part of the DAC will not work.
    treitz3 Posts: 20,367
    Why would that be? I thought they were still selling overseas, just not here anymore. The updates and functionality would still be good to go, no? I am curious, because I sold mine to a member of this forum who might be very interested in your answer.
    I really enjoyed mine when I had it. It was my first taste in higher end streaming, and it introduced me into the possibilities that had no idea existed at the time.
  • joecoulson
    API updates from streaming services might not be supported as there is no active US based support anymore.
  • jdjohn
    jdjohn Posts: 3,462
    joecoulson wrote: »
    Beautiful new acquisition Jody!
    Thanks, Joe, and good to see you posting here again!
    billbillw Posts: 8,371
    edited August 7
    Yesterday technically, but fresh in memory. I got my SCD-C333ES working again. It needed all new (3) belts.
    I took it out of the box last weekend (it has been stored since early 2022) and when I plugged it in, it made nothing but motor spinning sounds. I actually had plans to replace all the belts about 6-7 years ago, but was having a hard time sourcing them all. What? You mean Sony doesn't stock belts for 25 year old players? Yeah. I stopped looking for some time, but still had the part numbers on a sticky note in the box. So I searched again and found some eBay hits. Most of the sellers were only offering two of the three belts. The C333ES and C555ES were unique in that they have a motorized front door that swings down before the platter opens. That belt was hard to find. Eventually after a dozen searches, I found a seller that had all three, part numbers confirmed. They came yesterday. I thought it would be a 30 minute job to swap them, but due to the robust double steel shell on that old flagship changer, it ended up taking over 2 hours. I had to completely remove all the circuit boards, remove the whole front and rear panels, and take out several dozen screws to get access to the platter belt. Anyway, I'm happy to report that it is back to 100% functional.
    Not sure how much I will use it, but it's nice to have the option. I still have hundreds of CDs that I haven't ripped and many of them, I probably don't want to listen to anymore, but this gives me a way to listen without ripping and decide if I should part with them.
  • Unknown
    xschop Posts: 5,925
  • Geoff4rfc
    Geoff4rfc Posts: 3,062
    SCORE!!!!! A friend of mine had, brand new still in the box, AudioQuest 507 series silver plated spades. He "donated" them to me for my 2ch amp to mains.
    Was using Viborg silver plated copper bananas. I don't expect a sonic change by any means but improved connection is the key.
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
    edited August 13
    Nice. I have built all my DIY speaker cables over the last 15 years with AQ silver plated solid copper spades, but they are the crimp/solder type. I bought a bulk bag and just finally used the last couple recently.
  • Geoff4rfc
    billbillw wrote: »
    Right on Bill, that's exactly the direction I was headed as well, using the AQ crimp/solder spades, then my buddy says, Hey, I got these and never used them, will they work for you?? I choked and coughed and said with a crackly voice, Um, yeah man, that'll hit the mark ....... :D
  • jdjohn
    jdjohn Posts: 3,462
    edited August 16
    jdjohn wrote: »
    I picked-up a new-to-me line-level tube preamp last weekend. It is a Blue Circle BC3. I believe these came out near the 'turn of the century', if I can use that phrase at this point. I bought it from a local dude off FB marketplace. We had a nice conversation during the sale/hand-off, albeit in the boiling TN sun. These are two-piece units, with a separate umbilical power supply.
    After spending some time with the BC3 tube preamp, I have a few observations.
    First, I discovered that many Blue Circle enthusiasts see my unit as an atrocity due to the 'upgrades' that the previous owner had done. The original builder/designer even chimed-in, offering to do their current official upgrades. I haven't inquired yet about the cost and timing of potentially getting that work done. Frankly, I think my unit sounds really good as-is...when properly matched with source components.
    The most important part of that matching seems to be impedance. When Stereophile's John Atkinson performed measurements on the BC3, he noted that at low volumes, the input impedance dips below 2,000 ohms, which might not be a good match for some source components. I think I encountered an impedance mismatch myself with one of my phono preamps. When using the balanced phono inputs on my CODA 06x, the sound had too much warmth IMO, and the highs were rolled-off. After looking at the specs on the 06x, I saw that the balanced signal path has a somewhat low output impedance. Switching to the unbalanced setting cured the issue. I also tried a different - much more basic - phono preamp, and the resulting sound was very good. I have several other phono pre's to potentially try, but man, that's a lot of work.
    Overall, I really like the sound of the BC3. One review I read said (paraphrasing), that their reference SS preamp brought the music to them, but the BC3 drew them into the music. I can't disagree with that.
    SCompRacer Posts: 9,407
    edited August 16
    You bring up something that is often overlooked, impedance mismatch. I haven't thought about impedance matching since 2015 when I built my Bottlehead Eros phono stage. (My ARC Ref 3 SE input impedance is 300k ohms, balanced is 120k ohms).
    I used Vcaps Coupling Capacitor Calculator to arrive at the correct coupling cap in the Eros. That keeps the corner frequency roll off well below 20Hz. Manufacturers typically stuck a coupling cap value in that would work with anything but may not be optimum for your gear. This can cause issues like phase anomalies or a dB bump or dropout at a particular undesired frequency. At least that's the way I remember it.
    Are the current official upgrades for the BC3 made public so you could DIY?
    Vcap coupling cap calculator.
    https://www.v-cap.com/coupling-capacitor-calculator.php
  • Geoff4rfc
    Cool!! Got the 507 silver plated spades installed! Not sure just what a difference it makes however it's still cool that AudioQuest labeled specific placement for; Amp and Speaker assignments on the spade jacket.
  • HzTweaker
    HzTweaker Posts: 1,137
    Warming up the rig to do a quick speaker cable "shoot out".
    I totally forgot the Maggies have tiny set screws (making them hard to dis/connect in a quick manner) clamping the speaker cables in place. I've never had a pair of banana plugs just fallout. Has anybody? Who likes this feature? :#
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
    VR3 Posts: 29,762
    Perfect time to spend hard dollars and upgrade! 😁😁😁😁
  • newbie308
    newbie308 Posts: 848
    @Geoff4rfc I like the way you are supporting your cables with those Velcro wraps! I need to do something like this with my rig, but I don't have the cross bars like your rack does. I'll need to fabricate something for this. It must be nice to have so much space behind the audio rack...
  • Geoff4rfc
    edited August 18
    HzTweaker wrote: »
    @HzTweaker
    Ahh fun times!!! Cable shoot out. Don't forget to list the contenders :)
    The bananas I was using are from Viborg. They have spring loaded retention clips. Pretty solid fit. The silver plating however has begun to tarnish in under a year of use. The silver plating on the AQ spades appears to be more robust, hoping for improved longevity.
    While you're involved with your cable shoot out, and maybe looking for a new cable, I highly recommend Furutech Alpha 12, can be found at Douglass connection. Doug, AKA @ptrooper, loves to work with forum members as I believe you already know :)B)
    newbie308 wrote: »
    @newbie308 thank you!! I have some very heavy power cables being supported with zip ties as well. I'd rather be using velcro straps for them as well but I have what I have at the moment. The stress relief on the power cables is excellent.
    Yes sir, the space behind the rack is very convenient but the space IN the rack however....it's so tight I don't think I could put a f a r t in there :D the exhaust fans would just blow it out the "rear" anyway :D:D:D
  • jdjohn
    jdjohn Posts: 3,462
    SCompRacer wrote: »
    I'm certainly no expert, but it seems that with SS gear, impedance matching is rarely an issue. But when tube gear is incorporated, impedance values have to be considered more closely.
    No, Blue Circle is literally a one-man show, so design particulars are closely-guarded. From what I have read (and watched videos about), the upgrades seem to focus around power supply design, and in particular, increased PS capacitance. There appears to be one fellow Canadian - they are both in Ontario - that is also entrusted with doing upgrades to Blue Circle gear. The place that worked on my unit is in Oregon, and I never received a reply from them about the work done on this piece.
    pitdogg2 Posts: 27,918
    edited August 18
    Yes pure silver will tarnish pretty quickly. They can be cleaned up with a silver jewelery polishing cloth easily.
    Those that do not readily tarnish will have a top coat of Rhodium. Rhodium is a very hard metal, to my ears it can be a very harsh sound. They like to use it on hard use items, outlet contacts and plugs for example. Pure silver tarnish still conducts signal very well, much better than badly tarnished copper for instance.
  • HzTweaker
    Thanks @Geoff4rfc , I liked what I heard so much after a three hour listen sesh yesterday morning I decided to leave the new cables in one more day/listening sesh before I put up a brief wright up.
  • Geoff4rfc
    @HzTweaker .......waiting with bated breath......looking forward to hearing who the winner is!
    VR3 Posts: 29,762
    My understanding is that tarnish on silver has zero effect on conductivity
  • Geoff4rfc
    @VR3 good to know, many thanks!!
  • Geoff4rfc
    edited August 19
    @HzTweaker hey man, I misspoke (not the first time lol, not the last either) "While you're involved with your cable shoot out, and maybe looking for a new cable, I highly recommend Furutech Alpha 12, can be found at Douglass connection. Doug, AKA @ptrooper, loves to work with forum members as I believe you already know :)B)"
    Doug is actually @helipilotdoug .....which I'm sure you must already know.....man, it sucks when I drop the wrong name.....you know you're getting old......
  • HzTweaker
    edited August 19
    @Geoff4rfc Doug's cables are in high regard for sure. But the ones I'm testing are a diy from another member here.
    I wanted to wright up something short and sweet this evening (admittedly while I'm at work lol) but I left my notes at the house. :#
    edit: I also meant to mention, I listened to the hifi for another few hours this morning when I got home. I forgot to post that because I only spun CDs so I never got my laptop out to update ya's.
    edited August 25
    I did some experimenting over the weekend, and today, I ordered 3 more acoustical panels for the room. Probably gonna throw the ones that I will be swapping out up for sale when the new ones get in.
    For the first reflection spots, I will be going from a 2" thick panels to 4" thick ones that are rated at 100Hz. The biggest difference will be what resides behind my head at the listening position. I currently have a 2" panel that is 1x4', and has a decorative diffuser on it. This one will be replaced with a 2'x4' 6" thick panel that is rated down to 80Hz.
    I carried on a conversation with Chat GPT (I have the paid version, so it remembers previous conversations and the gear I have) and went into extreme detail about my room dimensions, speaker location, height and locations of the subs, what the current acoustical panels were, where they are currently placed, where they are located on the ceiling, where the listening position is, blah, blah, blah.
    During this chat, it suggested multiple times that I do some experimenting.....and I did plenty of experimenting. I relayed to Chat GPT what I heard, as I was experimenting and it bounced back with other ideas. This entire chat and experimentation time took about 6 hours. My word, was it an eye opener.
    It turns out that my placement of the panels was spot on. Where I went wrong was choosing the right panel for that specific application. The first experiment I thought of, after it suggested that I get a new panel for behind my head, was to remove the decorative diffuser. It stated that the diffuser was too close to my head and it affected what I was hearing. It also explained why I was hearing what I was hearing. So, I removed it....and BAM.
    What I am now hearing is increased spatial locational cues, a greatly widened sound stage, more depth and the speakers disappeared even more than they already had. That was something I didn't think was possible. Oh, it was possible! So, the conversations went on and I would tell it my preferences, what I liked about a move, what I didn't like and at the end of the conversation and experimenting, I walked away much more knowledgeable about my room acoustics and what affects what.....and why.
    It provided me with references, why the panels we choose were good for the soundstage, depth, image specificity, an even stronger center image and literally the speakers disappearing. You couldn't even tell how far away they were from you (even though I know full well where they are). It calculated my room nodes and educated me on why each move for the new panels was a wise choice or a bad decision.
    I asked questions like, if I go to a bigger sized panel (like a 3x6' versus a 2x4'), what, if any, would the attributes or deficiencies be? I asked questions on the thickness and why they would matter, given my room and system/seating location. It gave very precise answers and I know that Chat GPT can be wrong. But with that said, as we were chatting and I was doing my experimentation(s), what I was starting to hear was spot on to what it suggested. Not everything, and I let it know when I was displeased with a move or recommendation. It would bounce back with another suggestion or ask another question, and the entire conversation steered me into exactly what I needed, based upon my preferences and proven mathematical ways on how sound reacts within the room. Specifically my room, with my gear and the location of everything.
    I will not get the panels for another two months, but based upon my experimenting? I should be ecstatic with the sound when they come in. Heck, I am already enjoying the hell out of what I am now hearing, just with the removal of just the one diffuser behind my head, making that Amplitude panel into just an absorption panel. The difference is almost hard to believe and I have never heard my system sound so good.
    Just thought I'd share that. If you already have panels to experiment with (different sizes and thicknesses), you may want to have the same conversation. It was eye (ear) opening for me.....and I know exactly what will happen when the new panels get in. I can't wait!
    Just keep in mind, you only get something like 5 questions in one day with Chat GPT, but if you happen to have Co-Pilot, Chat GPT, or some other paid or upgraded service - I would highly suggest using it specifically for this purpose.....and be very specific.
  • tratliff
    tratliff Posts: 1,910
    Hey Tom. Where did you order the panels from?
    2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Signature 21 w/Hana Umami Red, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
    GIK Acoustics. https://www.gikacoustics.com
    I didn't use their "services" initially to get what I have now, because I noticed that many of the rooms they have pictured, have a boat ton of panels. Well, of course they want to fill your room with panels...that's what they sell. There is a big difference between a good balance of panels and an acoustically dead room.
    I am pleased with the panels I have gotten from them.
  • Unknown
    edited August 25
  • tratliff
    treitz3 wrote: »
    I’ll be interested in how long it takes to fill the order. I have been working with them for more than 6 months to get an order completed. I received the panels after 4 months but 2 were damaged. Now I’m waiting on those 2 to be replaced. Their customer service is terrible and expected ship dates are way off. Good luck.
