Weather at Your House?
1…252627282931»
  • bcwsrt
    bcwsrt Posts: 2,687
    That sucks, Ivan! I hope the basement is OK. I could probably make a generator happen yet tonight if you need it. Now, figuring out the route you took to get to your house might be an issue ...
    Brian
  • Unknown
  • bcwsrt
    bcwsrt Posts: 2,687
    Man, you have a long night ahead, it sounds like, but glad it's manageable. Yes, that would be my normal route. My sump pump has calmed down quite a bit the past couple hours, so hopefully that's a good sign for you. Hope you don't lose anything in the freezer, either!
    Brian
    xschop Posts: 5,823
  • Unknown
    edited August 13
    F1nut Posts: 52,406
    Good luck bro, hope they get your power back on pronto.
    SCompRacer Posts: 9,395
    edited August 14
    Hope all is well with you Ivan! I keep getting texts from ComEd saying "we will restore your power shortly," yet we have not lost power....
    We had nasty weather here with large golf ball sized hail July 27 in Plainfield, IL. Minor siding damage, roof OK. Trees down in neighborhood. I snuck on the roof and inspected it before the wife could scream at me not to. She says "73-year-old men shouldn't go on roofs!" I respond with "73-year-old men shouldn't fall off roofs!" :D My back window on the Kia was shattered. The tint film along with safety glass sandwich film helped keep rear glass in one piece. A few dents in body.
    I've done windshields at work and had tools to cut the polyurethane. Saved me some money at Safelite. I removed glass as it would have fallen in if I hit a bump. It was broken away at both sides and rainwater ran in. I had to remover rear seat, rear deck and side trim and all trunk trim as it and the insulation got wet. Water under hybrid battery where a space saver tire would normally be. Harman Kardon sound system survived.
    Aug 11, three doors down, neighbors tree knocked down, we just lost some small branches.
    While not weather related, August 4th at 1AM the ambulance took wife to hospital. The section where they removed part of her intestine flipped and caused a blockage. Got her out a few days later.
    My BlackVue rear view camera survived.
    I laid a tarp inside to first remove the big chunk, then reinserted it to cut the remaining bits stuck to the polyurethane. There were glass bits on the dash and front seats.
    Shrinking away awaiting Uber...?
    All dried out and reassembled. Glass was backordered, had to wait a week.
    At least the lawn looks good for August...we don't water it in drought like we had in July.
  • Unknown
    F1nut Posts: 52,406
    Do you have power now?
  • Unknown
    edited August 14
  • Unknown
    F1nut Posts: 52,406
    Oh no!!!
    Tony M Posts: 12,015
    That sucks!!!!!! :#:s
    Sump pump time.
  • bcwsrt
    bcwsrt Posts: 2,687
    Not good, not good at all.
    The rain was just relentless overnight and this morning, from about 1:00 until 10:00. And, it looks like we may get another round tonight before we finally get some dry days next week.
    Brian
  • Unknown
    edited August 15
  • Unknown
    F1nut Posts: 52,406
    That's crazy!!!
    Sad and frustrating to see you go through this again. In 2021 didn't the mayor say it will take until 2030 to replace the combined storm water and sewer lines in older neighborhoods?
  • Unknown
    xschop Posts: 5,823
    Had one of these installed when they built our home. Not required, but we're next to a main line....
  • motorhead43026
    motorhead43026 Posts: 4,114
    Dang Ivan, sorry you’re going through this again.
    And the boots you lick will stomp you too.
  • Unknown
  • machone
    machone Posts: 1,588
    Sorry for your trouble!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    treitz3 Posts: 20,359
    Daggum, Ivan. When are you gonna get a break?! So sorry to hear of this for you and your family.
    billbillw Posts: 8,248
    This is why I'm glad to be on a septic tank. Sorry to hear this happened again Ivan.
    xschop Posts: 5,823
  • machone
    Hot even for SC Low Country
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
