Weather at Your House?
Oh no!!!
That sucks!!!!!!
Sump pump time.
That sucks!!!!!!
Sump pump time.
You think I don't have a sump pump!?
I do and it works fine.
Unfortunately when the water comes through floor drains as sewage and over the top of your toilet as sewage you're kind of left to what happens is happening. Sure I blocked all the drains, how do you block a toilet? It's very hard!
The other thing is if you block all your drains and you block the toilet the pressure underneath your house will explode the PVC piping. Then you have a much larger dilemma going on. I screwed 19 inch PVC pipes into the drains. The pressure from the water coming in shot out of the 19-in PVC pipes another 2 ft into the air. Understand the amount of pressure going on now Tony?
This was the first flood back in 2022. See how nice my basement WAS?
This was after the remediation.
I had drywalled the back room 3/4 of the way. I completely redid all the electrical because I had to. Put a 60 amp sub panel in the basement and ran everything off of it with the proper gauge wire.
Now I get to start all over! I don't think I can do it. I can't redo this every 3 or 4 years. From 1992 to 2022 there had never been any water in the basement that wasn't spilled from a glass. So from 1992 to 2022 zero issues. Somehow the sanitation and stormwater system out here has been overwhelmed. There are two completely different systems rainwater does not go into sanitation and sanitation does not go into rainwater.
Now every time we get heavy rains there is a very good possibility that I'm right back in the boat I'm trying to row away from.
Yeah I'm a little salty today! 8 sheets of 4x12 drywall cut into half to go on the wall, GONE, bags of insulation Gone. I could go on, but I won't.
This is what we had ALL night long, just a freight train of a storm that just kept going on and on and on. I believe this was like at 2:40 ish am or so
Deleted User wrote: »Not good, not good at all.
The rain was just relentless overnight and this morning, from about 1:00 until 10:00. And, it looks like we may get another round tonight before we finally get some dry days next week.
I had 6" in my gauge from overnight. From Thursday afternoon until today our city has been just beaten. Some folks won't see electricity for another couple of days. The amount of trees taken out snapped off, we're talking very healthy not old rotting trees, of course there was some of those don't get me wrong. But the ground is so saturated from all this rain that major trees were just pushed over by the almost 70 mph straight line winds we had Thursday afternoon. If I remember correctly they said they were 66 mph. We got almost 3 in of rain and 45 minutes along with that serious serious wind. -
That's crazy!!!
Sad and frustrating to see you go through this again. In 2021 didn't the mayor say it will take until 2030 to replace the combined storm water and sewer lines in older neighborhoods?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
SCompRacer wrote: »Sad and frustrating to see you go through this again. In 2021 didn't the mayor say it will take until 2030 to replace the combined storm water and sewer lines in older neighborhoods?
Mine are separated Rich. Subdivision was established in 1990. My older home was not. -
Had one of these installed when they built our home. Not required, but we're next to a main line....
Don't take experimental gene therapies from known eugenicists. -
Dang Ivan, sorry you’re going through this again.
Religion began when the first scoundrel met the first fool……….Voltaire. -
Thanks Craig 👍🏼motorhead43026 wrote: »Dang Ivan, sorry you’re going through this again.
Sorry for your trouble!Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
Daggum, Ivan. When are you gonna get a break?! So sorry to hear of this for you and your family.
This is why I'm glad to be on a septic tank. Sorry to hear this happened again Ivan.
Hot even for SC Low Country
1KVA Dreadnought
Marantz SA 8005
Sony PS4
