Audio strangeness
dwp_junk
dwp_junk Posts: 3
I have a patio and pool behind my house. I had 4x Atrium 4s even spaced across the back of my house to provide audio to the patio and pool.
This season, I upgraded the center two to Atrium 8s.
So it's now like this
|--A4
A8
A8
A4--|
Each speaker is on its own 100W channel. Each A4 and A8 are L and R respectively.
The weirdness is when I move to different areas I get dramatically different sound profiles.
Center stage is of course the best. Full, rich, warm, and clear with great width of stage.
Move left or right to be on center with an A8 and it's like listening through a tube. Highs and lows are gone.
Move a little farther and the highs return, but the bass seams to quickly roll off.
I have checked polarity and phasing - everything is correct.
Anyone seen anything like this? Any ideas?
    F1nut Posts: 52,221
    The 8 has a single/dual input switch on the rear. Whatever setting you have it on now you need to change to the other setting.
  • dwp_junk
    dwp_junk Posts: 3
    The speakers are in single channel mode and wired with a single lead.
    F1nut Posts: 52,221
    dwp_junk wrote: »
    You need to change to the dual mode. In single mode they are 4 ohm nominal. In dual they are 8 ohm. The Atrium 4 are 8 ohm nominal.
  • dwp_junk
    dwp_junk Posts: 3
    dwp_junk wrote: »
    Not sure how this applies. My head unit handles 4 Ohm loads just fine.
  • hoosier21
    hoosier21 Posts: 4,427
    |--A4
    A8
    A8
    A4--|
    What are you trying to tell us with the different A4?
    l--A4
    A4--l
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
    F1nut Posts: 52,221
    dwp_junk wrote: »
    dwp_junk wrote: »
    Read the manual. I'm done trying to help as you don't want to listen.
