Audio strangeness
dwp_junk
I have a patio and pool behind my house. I had 4x Atrium 4s even spaced across the back of my house to provide audio to the patio and pool.
This season, I upgraded the center two to Atrium 8s.
So it's now like this
|--A4
A8
A8
A4--|
Each speaker is on its own 100W channel. Each A4 and A8 are L and R respectively.
The weirdness is when I move to different areas I get dramatically different sound profiles.
Center stage is of course the best. Full, rich, warm, and clear with great width of stage.
Move left or right to be on center with an A8 and it's like listening through a tube. Highs and lows are gone.
Move a little farther and the highs return, but the bass seams to quickly roll off.
I have checked polarity and phasing - everything is correct.
Anyone seen anything like this? Any ideas?
|--A4
A8
A8
A4--|
The 8 has a single/dual input switch on the rear. Whatever setting you have it on now you need to change to the other setting.
The speakers are in single channel mode and wired with a single lead. -
You need to change to the dual mode. In single mode they are 4 ohm nominal. In dual they are 8 ohm. The Atrium 4 are 8 ohm nominal. -
Not sure how this applies. My head unit handles 4 Ohm loads just fine. -
|--A4
A8
A8
A4--|
What are you trying to tell us with the different A4?
l--A4
A4--l
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Read the manual. I'm done trying to help as you don't want to listen. -
I have read the manual. I understand the Ohm loads. I am asking how Ohm loads effect the sound issues. -
|--A4
A8
A8
A4--|
l--A4
A4--l
The original had characters that were stripped. I was attempting to draw the straight line of speakers positions across the back of the house.
Edge of house - A4 - A8 - A8 - A4 - edge of house
I will say, as you are experiencing, when you have more than one speaker for each channel, in "close" spacing, there are weird things that happen acoustically, cancelations and weird phasing and nulls.
can you run all 4 speakers mono?
Might simplify things, but who knows.
I can't take it, so in case he comes back...
The basic issues are as follows.
The A8 has a sensitivity of 91 dB, while the A4 is 89dB. That alone is a problem as the A8 will play louder than the A4. In addition, the A8's are playing in mono, while the A4's are playing in stereo. Furthermore, the A8's in single mode are 4 ohm nominal, while the A4's are 8 ohm creating an even more unbalanced presentation. If the OP had simply done as instructed the noted odd presentation would be a lot less noticeable.
Don't ya love it when folks ask for help then fight you when provided with that help.😬
