1198199200201202204»
    SCompRacer Posts: 9,159
    I swapped in some 7C's Ed dropped off last Feb. He's been asking if they were OK. No loose magnets. They pass the push the passive radiator test, no leaks. Sound ok but they deserve some upgrades. They are in very nice condition with original matching serial number boxes.
    Carl chipped in with some Larry's rings. They had some surface rust so I sanded and painted them. Jay surprised me with RD0194's. I bet this project wont give me any trouble like open reel decks can.....
    xschop Posts: 5,668
    SCompRacer wrote: »
    Nice looking 7's. I'd like to karma a set of RDO plates to these beauties. If you'd like, just PM. What color are those cabs?
  • agfrost
    agfrost Posts: 2,483
    After Rich breathed new life into my LT-30, I've listened to more vinyl in the past week than I had in the last handful of months. The turntable has performed flawlessly, but its feet were blowing out/cracking, and generally not attractive enough for how I want it to present.
    The only "Googleable" feet for this TT are some silver aluminum ones that didn't appeal to me. Researching a bit harder, I found an open-box deal on a set of Isoacoustics Gaia III Neo feet. These are made as speaker isolation feet for speakers up to 70 pounds, but I thought they'd serve my purpose. They come with three different thread adaptors and the M6/1.0mm pitch ones match the threading on the stock feet on the LT-30.
    Each foot is easy to adjust height on after installation, making leveling the turntable simple. Easy to install and happy with the new boots!
    With original feet:
    A new foot:
    One new, three old showing their age:
    All dressed up:
    Jay
    edited June 27
    Thanks! That's a very generous offer considering I haven't done anything for you! Carl swore he had a pair but couldn't lay his hands on them.
    They look like Walnut to me. They suffered some Styrofoam transfer, probably while in storage. I was leery of some cleaners as they can degrade the thin vinyl material. You can see how the corners look scuffed and dull compared to the unaffected areas. It's more noticeable with light from a certain angle.
    edited June 27
    This makes me very happy. I held it hostage here for several months. I'm slipping, missing thinking the carriage motor could have a bad spot. Some guys have told me they like the mirror trick idea, observing the carriage pulley while monitoring voltage. I see the Elac is still in place. That is a very nice sounding cartridge.
    Nice job on the outstanding footers! That deck deserves them. The OEM ones are aging poorly.
    xschop Posts: 5,668
    SCompRacer wrote: »
    50% isopropyl alcohol wont affect the vinyl. Ive tested a couple times.
  • agingboomer
    agingboomer Posts: 488
    Reinstalled my Concept 11.0 receiver into my tertiary system after a repair hiatus to cure its tendency to go into protection mode at the slightest provocation. Now pumping 110 wpc into a pair of Infinity Monitor IIa speakers with lovely vintage audio satisfaction.
    pitdogg2 Posts: 27,597
    https://forum.polkaudio.com/discussion/119467/concept-11-0-by-pacific-stereo-lab-accurate-receiver
