CRS+ RestoMod
What I picked up from you look the same. The speakers I dropped off not so much.🤣 I can’t wait to see the finished product. Great work.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Ok, well a few other options are lacquer for brass or Renaissance wax
https://www.woodcraft.com/products/mohawk-lacquer-for-brass-gloss-aerosol-13-oz
Edit: If you use the spray lacquer be sure to clean the brass first with a degreasing agent.
Ill check out the wax. Once I settle on patina matched to RDO plates. Will do face operation next.Don't take experimental gene therapies from known eugenicists. -
dkfreebird wrote: »
Another reason we need a "badass" button.Don't take experimental gene therapies from known eugenicists. -
Fixed the 2 traces that had half their tracks deleted when drilled from factory...
Almost forgot I ordered fresh open-cell foam...
Looks like it has an embossed surface like the BH5? Is it adhesive backed?George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Yes and yes. It's what I'll use to make the custom double-backed stand offs in these CRS. No cones this time lol.....
The 3/4 sonic barrier is actually a very good product. The 1/2 and the one larger is missing the layers that make the 3/4 a stand out.
The adhesive on the sonic barrier line is terrible though, I always apply power grab to the back if I'm using that
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Guess I should have said back-to-back, as a layer of 1/8" butyl mat will be sandwiched between the two opposing layers and suspended in center of cabinets.Don't take experimental gene therapies from known eugenicists.
1/8" thick PVA foam spray glued to 1/8" thick dense felt for the @Gardenstater foam frame mod. Will cut to 1.25" x 1.25" squares. This will make positioning easy with Powergrab....
Started left channel Enclosure last night...Gallagher Mansion had plenty of black paint....Plenty enclosure glue as usual too...
Wish they used same glue on their magnets... Heat gun on low and slow blade peel. Luckily didn't tear them....
I'll peel the vinyl tonight with heat gun as that will speed up
the curing process of the Flex Seal...
Upgrading stickers lol...
0.020" thick paper...
Think I'm going with this finish...
Matching plugs....
Very nice! Looks like I have the model for that!
Mods, it's only a thermos, not an artillery shell.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Each driver gets the 3 extra tabs cut off and terminals bent upward away from windows, with downward fastons removed....and superglue to lock the tabs tight. Haven't ran into a driver yet that were snug...
@xschop every time I read one of your posts on this thread (and others), this song pops into my mind:
The Rolling Stones "Time is On My Side"
https://www.youtube.com/watch?v=jOxHsuV83KA "Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
BlueBirdMusic wrote: »@xschop every time I read one of your posts on this thread (and others), this song pops into my mind:
Keith Richards must have wrote that one lol.Don't take experimental gene therapies from known eugenicists. -
Parting shot before the epidermis is scalped. Do like the old school look. Real Walnut or Mahogany would be peachy...
Looks great! Will the lower conductivity of the brass be a factor in the shorting ring effect of the phase plug? Or will the eddy currents not be affected all that much, it being such a large chunk of metal? I know it is too late but it might've been cool to press on a ring of copper at the base, where it wouldn't even be visible.
Also, although probably not the look you want here, this could be another option that is now possible, that isn't possible with aluminum:
George / NJ
iFi nano iDSD DAC
iPurifier3
The brass will illicit less eddy currents than the alloy for sure. Will it matter? Not sure. But the real unknown (for me) right now is if the alloy focus ring/brass plug will exhibit the same excellent cone control behavior that the alloy ring and alloy plug do.
I'll do a tone sweep on the bench, but that's free-air. Mounted in the enclosure is propper to see the behavior.
I have all summer to experiment. I'm more excited to hear these back-chambered RDOs in the CRS+. Why Polk didn't add this feature, like they did to the SL3000's was a serious faux pax.
Note to self and maybe help others. Tested the continuity, and the Neutrik male NL2 whips I have on hand match the female NL4 (for new terminal plates). The "Pin" being 1+ and the "Blade" being 1- respectively....
I'm ecstatic to say the least after running sweep tests. The questionable 6511 is staying dead center at clearly over max excursion. I'd never play these that loud, but by eye sight I can see the cone base traveling a quarter inch or more both ways...
Best vid I could do. This is after I turned volume down on amp too. Ran about 20 cycles on all drivers.The pop is in the bass tone recording at end.
I believe a factory driver would have over extended and crashed the coil on the base plate...
https://youtu.be/fGaQL44KR0Y?si=RJmNnSVw6ZOF302w Don't take experimental gene therapies from known eugenicists. -
Only thing I could work on today.
Large upright belt sander cleaned up overhang of attached piece. Thick coat of flat white primer, then smokey beige hides the frame under the grill cloth nicely.
I'll lightly Dremel the peg holes out like I did for the first one, then attach cloth...
Filled the seams before sanding this time....
