CRS+ RestoMod
I dig it
Go magnetic grills to really go all out 😁
I did do one of the 8TLs to try. They were 5/16 dia. These CRS would be easy using 7/16 Neodymiums.Don't take experimental gene therapies from known eugenicists. -
Well the Krylon Kid can oblige.Don't take experimental gene therapies from known eugenicists.
Looked at two different beige/cream speaker cloths with an antique white card from paint store....
Shot a coat of Flex Seal Max to entire interior. This is to stop the oxidation process of the formaldehyde glue of the particle board. Also makes the butyl mat adhere much better. I will put a single damping layer on tops and bottoms to take the last bit of hollow out of those areas...
Check the cure time on that stuff... I k ow it says 24 to 48 hours in normal applications but this will be sealed. I wouldn't seal that enclosure completely for atleast 2 to 3 weeks.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Can't argue with that. It's been 24hrs now. I shot like 3 coats of this stuff on the interior of a set of CX100s and it tooks a few days for the tack to go away. But the butyl mat stuck like super glue.Don't take experimental gene therapies from known eugenicists. -
Wonder why Polk didnt drill and install the 4 extra fasteners on the covers. They pre-drilled the PRs however...
PITA getting them accurate with a 3/16 bit....
Makes sense why 360 brass is 4x the cost of 6061...
I guinea pigged these 8-32 brass inserts. Mainly because I want to avoid any galvanic reaction with the brass screws. They're more accurate than the Parts Express hurricane nuts. Those teeth dia. are not consistent I've found.
A 0.190 drill is perfect and they don't split the particle board or need trimming near the thru holes....
I heated the base and top with a heat gun. The butyl mat is now permanent....
And the primer is drying F1😉....
You, and Trey are inspiring me to pull mine out of the closet for a few..
JayMX went all-out too.Don't take experimental gene therapies from known eugenicists. -
2 new belts snapped on me.
It's either the brand or Polk particle board doesn't like 50 grit. 120 and took a little longer...
shot a coat of primer before wood filler. Those little pegs that held the front wood trim on were 2.5" long and one glued in, other popped right out with pliers...
Just glued it in and sawed it off...
Think I'll go with a diffent grill cloth. I guess acoustically transparent accompanies visual transparency with the linen style cloth...
No likey...
Not sure if I'll have to go back with Bondo in the dowel holes to keep their edges clean when I redrill for brass inserts...
To fill in the small microdimples left behind from the old vinyl removal...drywall compound and 12" blade foots the bill quickly. Ready for light sand and final primer, then paint....
Trusty mag tool made quick work of removing the pole-pieces....
Next shop visit will get 1/8 pinholes thru centers and oxidation cleaned up with some fresh focus rings...
The MW sticker applicator position at Polk must have been a DEI hire lol...
Forgot to mention, the new grill frame dimensions are 12.625" x 19.875"
And I only have one 6511 with 0.020" suspension sag (seen alot worse). All others are good.
That wood filler stuff is crap. Wood epoxy is much better.
Yeah, think this stuff is only good for small crevices and the seams where the boards are folded together.Don't take experimental gene therapies from known eugenicists.
I've used JB Weld KwikWood for side panel veneer repairs. It's a two part putty and dries hard, can be sanded.
For clear finish you have to touch it up with various color gel stains (or mix for color match) to get a decent grain and color match. Being partially color blind I need the wife for that.
I had a wood floor repair kit once that had the basic colors to mix for a match.
Outstanding work being done on these CRS+.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Great info. I'll have to check that out next time I'm at Lowes.
Sounds like a generic brand for tadalafil 🤣
Picked up some beige spray paint to coat the frames and bought a test patch of that first cloth to place over 8TLs to see how it changes sound. Its WAF approved.Don't take experimental gene therapies from known eugenicists. -
This is a better product than the Quik Wood. It cures faster and harder. The Quik Wood really takes 24 hours to cure. This one says 20 minutes, but I wait at least a few hours.
Using water, slightly wet your finger tips to knead the material. Too much water results in a real mess.
https://www.amazon.com/Mohawk-Finishing-Products-Epoxy-Putty/dp/B013RKDKWO -
I would steer clear of the Quick Wood. I have used it many times and it doesn't harden up as well as it should. I still use it for some exterior work where a deep hole needs filling and I need ease of sanding, at least until I find some alternative that I like better that is available in the box stores.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
You need the longer overnight curing product, Morning Wood.Don't take experimental gene therapies from known eugenicists.
Enough wood shop talk, how 'bout some plastic subject matter. Made both shapes to try best orientation of the SBDI, yet have quick access of X-over to test a couple different tweeter caps...
Too close?
Got two other options without adapter plate...
Taped a patch of this material over one of the XS-8TLs. Not bad. Maybe only knocks down the tweeter output a wee touch...
Used 3M spray. Hard part was getting it taught, yet weave aligned...
There is a hint of brass colored accent interweaved into this one.
Embled will get final color match to cabinet....Wifey approved.
Looking good Rob
Would be nice to find an obscure cast brass emblem, if they existed. The sanded top does match the billet theme, but not going there this time...
Looking forward to hearing the Silver Dragons. They didn't come in 20 and 40uf, so the Black Dragons will be just fine.
Hat's off to @VSAT88 suggestion. These still remain in the XS-8TLs. I tried a Clarity PX and CSA on their
tweeter circuits and could not hear much a difference, just fantastic clarity. I will do the same for these when the time comes.
Went with a 3 ohm wire wound resistor since I deleted the safety polyswitch. Had to mount it this way to keep it off the TL shunt cap cause the leads are short with longer bodies.
Is that a Jantzen or Mundorf resistor?
Green Dragons as VSAT would say....
https://www.cinergyaudio.com/collections/resistors/products/bevenbi-3-0-ohm-10-watt-1-premium-audio-resistor-42-030Don't take experimental gene therapies from known eugenicists. -
What are the white inserts called?
If I could find some with threaded bases and pronged inserts would be ideal...
