Billet RD-0194/8 Tweeter Bezels
No disagreement here!Never liked the look after that plastic bent. -
Badass. I bet Megadeath never sounded so good lolDon't take experimental gene therapies from known eugenicists.
It’s Deth , not Death. But I’m sure you know that!!🤣
I didn't...
Now I do.
Had no clue. My friend in HS would play hooky and watch Headbangers Ball on MTV think it was.
Don't take experimental gene therapies from known eugenicists. -
If I torqued too much or too little, that original -194 I designed them from would make the nastiest sound.Don't take experimental gene therapies from known eugenicists. -
I had to super glue 2 ss washers under each screw hole to get them air tight enough yet not deform or sizzle on certain frequencies. -
I think this is what is known as a Mandela effect?
Same thing as Loony Tunes (not toons), JIF, not Jiffy peanut butter, etc.
They must have graduated from The Quality Learing Center.
That's quality manufacturing.Don't take experimental gene therapies from known eugenicists. -
Yea, I'm not sure why the made the stand off shorter in the RD-0xxx series, makes no sense. -
8 left from this run.
Anyone building Monoliths?Don't take experimental gene therapies from known eugenicists. -
Someone didn't measure twice.Political Correctness'.........defined
President of Club Polk -
6 left.Don't take experimental gene therapies from known eugenicists.
