Polk SDA 2s near me
kevhed72
kevhed72 Posts: 5,248
edited January 31 in Vintage Speakers
The guy threw out 600 but that sounds steep. How much would you pay?
    xschop Posts: 5,931
    400 frozen C-notes.
  • kevhed72
    xschop wrote: »
    400 frozen C-notes.
    Copy that. On a scale of 1 to 10, how would these stack up sound wise against all the other vintage SDAs ever produced? The guy has the original cable BTW.
    F1nut Posts: 52,406
    Blade/blade...can't use mono blocks or non-common ground amps.
    xschop Posts: 5,931
    You'll need the extra $200 frozen C-notes for RDO's
    or Wuhan them and put the duckets elsewhere.
    pitdogg2 Posts: 27,921
    Not to mention some of the hardest drivers to get. MW6509. These drivers were only used in 2 models, SDA 1b and those Blade/blade SDA SRS 2.
    They will be expensive to recap as well.
    audioluvr Posts: 6,079
    Check all the drivers for coil interference and it looks like one of the binding posts is damaged. They'd probably sound very good restored.
  • jmardy
    jmardy Posts: 27
    edited February 2
    Yes they will! ;)
    I spent around $400 and that's using Jantzens to replace the electrolytics.
