Polk SDA 2s near me
kevhed72
kevhed72 Posts: 5,172
edited January 31 in Vintage Speakers
The guy threw out 600 but that sounds steep. How much would you pay?
    xschop Posts: 5,466
    400 frozen C-notes.
  • kevhed72
    xschop wrote: »
    400 frozen C-notes.
    Copy that. On a scale of 1 to 10, how would these stack up sound wise against all the other vintage SDAs ever produced? The guy has the original cable BTW.
    F1nut Posts: 52,049
    Blade/blade...can't use mono blocks or non-common ground amps.
    xschop Posts: 5,466
    You'll need the extra $200 frozen C-notes for RDO's
    or Wuhan them and put the duckets elsewhere.
    pitdogg2 Posts: 27,423
    Not to mention some of the hardest drivers to get. MW6509. These drivers were only used in 2 models, SDA 1b and those Blade/blade SDA SRS 2.
    They will be expensive to recap as well.
    Toolfan66 Posts: 18,226
    If they were Pin Blade maybe, but Blade Blade, I personally would pass at that price tag..
    audioluvr Posts: 5,996
    Check all the drivers for coil interference and it looks like one of the binding posts is damaged. They'd probably sound very good restored.
  • jmardy
    jmardy Posts: 27
    edited February 2
    Yes they will! ;)
    I spent around $400 and that's using Jantzens to replace the electrolytics.
