Polk SDA 2s near me
kevhed72
The guy threw out 600 but that sounds steep. How much would you pay?
400 frozen C-notes.Don't take experimental gene therapies from known eugenicists.
Copy that. On a scale of 1 to 10, how would these stack up sound wise against all the other vintage SDAs ever produced? The guy has the original cable BTW.400 frozen C-notes.
Blade/blade...can't use mono blocks or non-common ground amps.Political Correctness'.........defined
President of Club Polk -
You'll need the extra $200 frozen C-notes for RDO's
or Wuhan them and put the duckets elsewhere.Don't take experimental gene therapies from known eugenicists. -
Not to mention some of the hardest drivers to get. MW6509. These drivers were only used in 2 models, SDA 1b and those Blade/blade SDA SRS 2.
They will be expensive to recap as well. -
If they were Pin Blade maybe, but Blade Blade, I personally would pass at that price tag..
Check all the drivers for coil interference and it looks like one of the binding posts is damaged. They'd probably sound very good restored.Gustard X26 Pro DAC
Yes they will!
I spent around $400 and that's using Jantzens to replace the electrolytics.
