Polk SDA 2s near me
kevhed72
The guy threw out 600 but that sounds steep. How much would you pay?
400 frozen C-notes.Don't take experimental gene therapies from known eugenicists.
Copy that. On a scale of 1 to 10, how would these stack up sound wise against all the other vintage SDAs ever produced? The guy has the original cable BTW.400 frozen C-notes.
Blade/blade...can't use mono blocks or non-common ground amps.
You'll need the extra $200 frozen C-notes for RDO's
or Wuhan them and put the duckets elsewhere.Don't take experimental gene therapies from known eugenicists. -
Check all the drivers for coil interference and it looks like one of the binding posts is damaged. They'd probably sound very good restored.Gustard X26 Pro DAC
