1186187189191192203
  • jdjohn
    jdjohn Posts: 3,371
    I've gotta say -- 3 dB at 2k might be jarring.
    Indeed, that is in the 'painful' frequency range...definitely in the defeat realm.
  • jdjohn
    jdjohn Posts: 3,371
    The 681EEE in particular was a very fine piece of hardware.
    I am embarrassed to say that I only learned of the... interoperability of Stanton & Pickering in the modern era; I had no idea back in the day. :blush:
    That's the one I had. It had a little brush attached to it.
    I'm a little late to this party, but agree these were/ARE very fine cartridges. In fact, JICO still makes brand-new replacement styli for certain vintage Stanton and Pickering cartridge models. I went through a stage of using this family of cartridges (almost exclusively), and always found them extremely neutral and balanced.
    Between certain Stanton and Pickering cartridges, there are interchangeable styli, BUT a person must be very careful. Each brand had both MM and MI cartridges, so care must be taken if trying to do a "crossover".
    Regarding the stylus brushes: my personal preference has always been to remove them. Rule of thumb is: if the brush is installed, the VTF setting should be 1g higher than typically published numbers. For example, the published VTF for a Stanton 681EEE is 0.75-1.5g, which is sans (without) the stylus brush.
    F1nut Posts: 51,872
    I can't recall if I removed the brush or not...way too long ago.
    Tony M Posts: 11,668
  • aprazer402
    aprazer402 Posts: 3,400
    My 681EEE was handy. I bought it new on Dec. 6, 1977. I bought a replacement Stanton stylus for it around 1980. The original stylus is shown with it's brush on left side in the case. The replacement is still on the cartridge on right.
    I was duped back then to believe that a stylus was only good for a few hundred album plays. I've always kept my records and styluses clean.
    I had the original stylus examined closely later by a tech and he said it was in great condition.
    Yes, you increase tracking force by 1 gram when using the brush. I used the brush for a short time then took it off.
    I always liked the sound of this cartridge.
    F1nut Posts: 51,872
    ^That's the one^
  • jdjohn
    jdjohn Posts: 3,371
    aprazer402 wrote: »
    I have a decent setup for stylus wear inspection, so let me know if you want an evaluation of the original, and/or the replacement stylus wear patches. No charge for inspection...just need coverage for shipping.
    edited December 2025
    I got out and enjoyed the afternoon 65* temps and got some blood flowing digging on the side of the barn shed. About 4 wheelbarrows full of dirt. It's beautiful, soft topsoil from 30+ years.
    IT WENT PRETTY EASILY TOO. :) Some roots got in the way here and there, but I dug about 5' of the 16'. Maybe some more digging tomorrow. :D I just remembered...it's supposed to rain tomorrow morn and early afternoon till 3pm. Oh well.
    Perhaps I'll go get a new front door unit early in the morning.
  • interstellar object flying through our solar system is "changing colours" as it hurtles to its closest point with Earth
    one scientist has said the object is nothing natural and could instead be a potential spaceship from another galaxy
  • skipshot12
    skipshot12 Posts: 2,037
    ^ I'll believe it when I see it......
    audioluvr Posts: 5,970
    Nothing like someone's first post being meaningless information.
  • aprazer402
    @jdjohn
    Thank you for the kind offer. I'll keep you in mind, if I reuse it someday!
  • audioluvr wrote: »
    I’ve been posting meaningless stuff since my first post.
    – Kevin Alfred Strom
    mhardy6647 Posts: 35,135
    audioluvr wrote: »
    I'm just getting to be really adept at it! Practice makes perfect.
    :blush:
    meanwhile...
    from our chums @ hifihaven...
  • skipshot12
    Have eaten Armadillo cooked over a camping bonfire, tastes like a tad fishy pork. Was quite tuff but that could have been our cooking method, done well to make sure it's done.
    Have to watch when you're handling those suckers as their nails carry some nasty's.
    pitdogg2 Posts: 27,152
    More than nails, they're Mycobacterium leprae reservoirs.
  • TEAforONE
    TEAforONE Posts: 1,064
    Armadillos come in their own microwave safe bowl.
    Cook for 10 minutes on high,stir,cook for another 10 minutes on high. Let stand for 2 minutes before serving.
    CAUTION, bowl will be hot
    Harry / Marietta GA
  • daddyjt
    daddyjt Posts: 3,113
    TEAforONE wrote: »
    ― Aleksandr Solzhenitsyn
  • skipshot12
    TEAforONE wrote: »
    They also put on quite the Acrobatic Show when popped with a .22.
    ^^^ Don't tell that speaker ;) about Himalayan salt!
    They're probably stripmining that stuff! :#:o
    Viking64 Posts: 7,582
    They have to hurry and harvest it before it expires!!!
    From the bottom of the Himalayan Sea, of course. :*
