(ASR)
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Chevy 6.2?^^^The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Woof, that's not a good sign!
What in the? I have seen many screen displays posted online before, but that one's a first!
[EDIT:] That has to be AI. The display is off center and the damned engine light isn't even lit.
Underneath parts of north Alabama lies an ancient underground ocean, preserved in the rock. Fossils of sea creatures are still being found in limestone beds!"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Up in the Shenandoah mountains of Northwestern VA, I have found seashells up at the very top of the mountains, buried in the landscaping. Specifically, in George Washington National Forest.
Same here and we live @ 7,220'. When we head up into the hills we find sea shells.
Old scopes repurposed as clocks.
https://oscilloscopeclocknixiecrt.com/Kit.htm?fbclid=IwY2xjawMB2_VleHRuA2FlbQIxMABicmlkETFqTDVpaW5TUTlVT085S2xzAR7keT1a6B8E-JvAIRqlk91FyGKB5-sQYGMOvIQVZlYp8MfQqru7-ADrFY5foQ_aem_UCjTurfN7rpawyzTViyO-QSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I'm going to need much MUCH stronger astigmatism correction to use that as a clock......
Bigger help?
Yes, it's been a thing for many years. Gary Kaufman has one (or more).
The only interesting clock here has a Nixie tube 'display'.
meanwhile, I've brought back a bountiful harvest from the fertile memefields of ASR...
(I have one of those printers -- maybe you do, too!)
I - ahem - saved the best for last.
I believe this last one is my long-lost family crest.
SCompRacer wrote: »Bigger help?
#3 or #4 ....3 or 4 ......one more time #3....#4...... -
The airship USS Los Angles...
https://en.m.wikipedia.org/wiki/USS_Los_Angeles_(ZR-3)
"On 25 August 1927, while Los Angeles was tethered at the Lakehurst high mast, a gust of wind caught her tail and lifted it into colder, denser air that was just above the airship. This caused the tail to lift higher. The crew on board tried to compensate by climbing up the keel toward the rising tail, but could not stop the ship from reaching an angle of 85 degrees, before it descended. The ship suffered only slight damage and was able to fly the next day."
I've seen this picture so many times, but I thought it was artwork, not a real photo of an accident.See profile for rigs. Nothing else here. -
― Aleksandr Solzhenitsyn -
The crew on the other hand...Gustard X26 Pro DAC
Agreed; I'm thinking that would not be a pleasant experience if a fella happened to be using the can at that point in time. -
as long as the media player one uses isn't "smart". A DVDP (or whatever) hooked to the internet can be "updated" any time, with... well... whatever changes the updater wishes to enact. Seems like it would be pretty easy to block playback of a specific title or, say a class of discs, via firmware.
No, I am not PARANOID!! WHO TOLD YOU I WAS!?!
Articles say only minor injuries and no fatalities.See profile for rigs. Nothing else here. -
The new Rose Garden."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
Jeff Beck, Jimmy Page, and Eddie Van Halen. (1999)
hmm... here's the best I can do.
Tiny Tim & Jackie Gleason.
... maybe Jack Nicholson & The Monkees.
ahem.
Blame hifihaven, not me.
