Y'all still don't realize, that Caddy is an homage to the Duke's car in Escape from New York. John Carpenter's classic which was really the first Big Screen role for Kurt Russell. That Plissken is one bad mo-fo.
You really don't have a clue. -
There's not a redneck on earth that would be caught dead in that abomination.
That's it!
It belongs to the abominable ho-man!
Hey, WOW man......the lights are psychotropic man......
The Antikythera Mechanism. Housed at the National Archaeological Museum in Athens, Greece.
Built around the beginning of the 1st century BCE, the Antikythera Mechanism built by the Greeks may be the oldest known analog computer in human history, and there’s an enduring mystery surrounding what it was used for. because parts are missing.
___________________
I read the long story in Popular Mechanics of its apparent origin, discovery after residing at the bottom of the Aegean for 2000 years, and ongoing analysis by researchers. It was found by sponge divers at the turn of the 20th century.
Only one-third of of the roughly shoebox size mechanism, spread across 82 fragments of varying sizes, has been found in 100 feet of water at the bottom of the Aegean Sea, off the coast of the Island Antikythera.
Milled with millimeter precision, likely using ancient tools like vertical lathes and bow drills, the device contained dozens of gear wheels that operated together in a dizzying display of astronomical information.
With insights gleaned from the fragments that remain, scientists know that a hand-cranked dial on its front side tracked the motion of the sun, the moon, and the other five planets known to antiquity: Mercury, Venus, Mars, Jupiter, and Saturn. The other side of the device housed two more circular dials. The upper dial reconciled the mismatch in periods between the lunar month and solar year, while the lower dial calculated both lunar and solar eclipses. It even contained a separate, smaller dial for marking athletic events like the Olympic Games."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA
lsi 9's -
@Viking64 LMAO !!
lsi 9's -
What is puzzling is that I cannot get my pocket to undo that when I need it to.
I've even tried other peoples' pockets.
Side note: I've found it best to ask first before trying this.I disabled signatures. -
SCOTTY..........Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3 -
If only I had seen this a couple of weeks ago, before Valentine's Day."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Very romantic!
It would certainly be hard to resistor.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
two from... well... you know...
Is this Robert McNamara when he was at Ford Motor Corp. after WWII?
Long before he asked for kill totals. :'( -
My favorite:
(ASR)
ken brydson wrote: »
And most likely drive a Subaru... Probably an Outback -
Deleted User wrote: »
I bet that is delicious, toasted! -
But there's only three of them.
