You’re doing it wrong…
    VR3 Posts: 29,657
    edited January 2025
    1 plus 4 is 5
    5 plus 2 plus 5 is 12
    12 plus 3 plus 6 is 21
    21 plus 5 plus 8 is 34
    I'm pretty sure the answer is 42 though, it's the meaning of life, 42
    billbillw Posts: 7,992
    Trey's example is what I thought as well, but like I said earlier, its hard to argue with maxward's explanation. Neither are wrong. Who knows what the author had in mind. Social medial garbage.
  • daddyjt
    daddyjt Posts: 3,207
    The “pattern” is a+(ab)=c
    ― Aleksandr Solzhenitsyn
    txcoastal1 Posts: 13,519
    daddyjt wrote: »
    We now have 3 possible solutions. None are wrong. 34, 37, 45 all fit a pattern. Exactly what I said earlier. It is not real math. It an ambiguous social media post designed for clicks/shares/comments to monetize an account.
    audioluvr Posts: 6,032
    The answer is "mud"
  • daddyjt
  • daddyjt
  • bcwsrt
    bcwsrt Posts: 2,610
  • mrbigbluelight
    billbillw wrote: »
    treitz3 wrote: »
    I ain't into common core BS...
    Take this test and shove it where the sun don't.....oh, wait a minute...
    You are cool here at CP. Rock on wid'yo'bad self!
    This ain't common core. Its a stupid social media garbage logic test. Not real math, but a 'follow the pattern' test. They post them to get views and comments. There is almost never a clear answer, but by my logic, the answer is 34. I'm sure others could argue something else and be correct as well.
    Well....wrong again, but I will award you half credit for Consistency
    There is 1 correct answer, and 1 correct answer only. 🤔👍
    billbillw wrote: »
    That's easy to say when you are not offering anything to support your conclusion. Three patterns offered in this thread all fit without any dispute. No rules given for the garbage math problem, so pick your favorite.
  • maxward
    maxward Posts: 1,731
    edited January 2025
    Second guess: 45. Edit: previously guessed, but I agree.
  • mrbigbluelight
    billbillw wrote: »
    billbillw wrote: »
    That's easy to say when you are not offering anything to support your conclusion. Three patterns offered in this thread all fit without any dispute. Norules given for the
    Rules ?
    For those of us with a level of familiarity with not only the scientificals but also with the advanced mathematicals are completely confident with the one, and only one, correct answer which is:
    45 ✅💯🧠
    mhardy6647 Posts: 35,445
    FWIW:
    I thought
    1 + 4 = 5 in base 6
    2 + 5 = 12 in base 5
    3 + 6 = 21 in base 4
    so
    5 + 8 = 41 in base 3 (13 in base 10)
  • CGTIII
    CGTIII Posts: 1,266
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
    billbillw wrote: »
    Rules ?
    45 ✅💯🧠
    Yes Rules. I know mathematicals just fine. This is math:
    Your puzzle wasn't math.
  • BlueBirdMusic
    ^^^^ That looks like arithmetic to me.
    Harry / Marietta GA
  • motorstereo
    motorstereo Posts: 2,399
    97.7% would fail this test ?
    WRONG
    I can't help but wonder; has anyone ever used this type of arithmetic for anything useful? I haven't sat in a math class since 73 but I've yet to use anything like that to balance my checkbook.
    Yup, not an x in sight.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited January 2025
    Contact your local cryptographer.
    He'll take about 5 seconds to decipher this most basic of "puzzles" .
    Ezy-Pezy, Simple Squezy.
    Also, in the original puzzle" the author avoided the
    "4 + 7 = ? "
    The answer is, of course, 32
    And why did the author purposely skip that particular question ?
    Hmmm ....🤔😲
    ......if he hàd, then a person could guess, using the progression of answers, that the next answer would progress by 13, which would still give the correct answer of 45.
    Instead he wanted the reader to decipher using the input without using the progression of answers
    So, what would be the answer to
    "17 + 20 = " 🤔
    You can determine the answer after a long while using the answer progression method or use the input pattern......
    (17x20) + 17 = 357
    Care to try 987 + 990 using the answer progression method
    Not me 🤗😘
  • BlueBirdMusic
    ^^^^^ There is another world out "there"!
    Harry / Marietta GA
  • bcwsrt
    bcwsrt Posts: 2,610
  • boston1450
    boston1450 Posts: 7,758
    Death chamber. I can understand why that window is wide open.
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    Well, if you’re a drinker, might be good as you won’t wobble to much…plus you have a wall to lean on while you do the “aim and shoot”
    pitdogg2 Posts: 27,670
    Of course they were ....
