PSW 110 Service Manual or Schematics
13»
  • Hello,
    See if you get it now..
  • TeeKriss
    TeeKriss Posts: 5
    edited December 2024
    Hello!! I am tring to repair my SUB - PSV 111.
    Need Schematics.
    Post edited by TeeKriss on
  • TeeKriss
    TeeKriss Posts: 5
    Schematics sent..
    Hello!! Please share it for me
    Thanks a lot!!!
    Post edited by SeleniumFalcon on
    F1nut Posts: 51,713
    Big mistake posting your email addy on a public forum.
  • TeeKriss
    TeeKriss Posts: 5
    I've replaced almost all the capacitors, but the problem is still there. We really need a circuit for troubleshooting.
    PSW 111 v2 230v.
  • TeeKriss wrote: »
    PSW 111 v2 230v.
    The defect is the heartbeat? Are you able to check if the dual voltage regulators for the pre/filter stage are working well?
  • Fabio_rm wrote: »
    TeeKriss wrote: »
    PSW 111 v2 230v.
    Hello!!
    The problem with my subwoofer was that from time to time it seemed to stop sounding, but not completely, but it did not work as usual. I can't really explain exactly how it was.
    Yes, well, I'll try to check the dual regulators.
  • Schematic sent..
    Got it!! Thank you so Much!!
  • You're welcome, good luck with the repair!
  • TeeKriss wrote: »
    Hello!!
    The defect for which the capacitors and/or their voltage regulators, which then power the op-amps, are suspected is the heartbeat, it is a self-oscillation of the circuit. If the defect that your sub has is different, the problem may be elsewhere.
  • Maurobay
    Maurobay Posts: 3
    Hello! If you have the schematic/diagram/service manual for the Polkaudio PSW111, could you please email me a copy? Thanks.
  • Hi.
    Im looking for the service manual or schematic diagram for PSW111 also. Please send me a copy.
    After replace some Ecap. The resistor that near Q5 was burned after 1-2mins normal running. The R34 seems got high temperature also. I'm trying to fix it. Thank you..
  • bao19922002
    bao19922002 Posts: 4
    edited November 12
  • Fabio_rm
    Fabio_rm Posts: 60
    edited November 12
    Hi.
    I just send it in your inbox.
    The part of the circuit with Q5 and R34 is for stabilize the virtual ground at the halfway up the voltage for the final power transistors. A single supply switching voltage comes from one of the secondary of the transformer after D1 and the filtering of Ecap C14, after Q4,Q5,R34,R35 end other components split the voltage. There is something that unbalancing the circuit
    What was the problem before recap?
    Post edited by Fabio_rm on
  • Fabio_rm
    Fabio_rm Posts: 60
    edited November 12
    Fabio_rm wrote: »
    .. A single supply switching voltage comes from one of the secondary of the transformer after D1 and the filtering of Ecap C14, after Q4,Q5,R34,R35 end other components split the voltage. There is something that unbalancing the circuit...
    First static split is operate by 2 watt power resistors R24 - R25, dinamic stabilzed after by Q4 and Q5
    Be careful that the supply voltage varies depending on the amplitude of the signal, using a feedback, this is the BASH amplifier patent to increase efficiency
  • Fabio_rm wrote: »
    Hi.
    Before recap, only the indicator on but not working, also had little pop noise came out from spk at all mode(On/Auto/Stby).
    After recap, pop noise gone and working properly, but Unfortunately the resistor smoke and born after 1-2mins.
  • Fabio_rm
    Fabio_rm Posts: 60
    edited November 14
    did you also change the 120uF Ecap c14?
  • Fabio_rm wrote: »
    C14 wasn't replaced.
    Today, I checked the components near Q4/Q5, including D10/D13, and found no problems. So, I replaced R34/R35, and it works normally. I've been running test for 3 hours, and everything is normal. It's strange that the resistor was overheating and smoking before.
  • Fabio_rm
    Fabio_rm Posts: 60
    I don't know what to say, perhaps there was a faulty solder; desoldering and soldering the components restored the faulty solder. We'll never know for sure; all you can do is hope the problem is solved for good and doesn't happen again.
    pitdogg2 Posts: 26,980
    Some of these boards are covered in a type of glue that becomes conductive as it ages. Maybe the removal of the glue to get to the problem you inadvertently solved both problems unknowingly.
  • ZZyXXy
    ZZyXXy Posts: 1
    Hi. I am working on a Polk Sub-Woofer. The board is PSW110V2 110V.
    Diode D1 (MUR420) shorted. I replaced that but output is oscillating.
    Not getting any further without a schematic. Could I get it sent to me?
    Thanks & regards.
  • Schematic sent..
  • ss0
    ss0 Posts: 2
    Could someone provide the value/specs for the ceramic disc cap C8?
  • There are two possible variations of the PSW110 amplifier with two schematic drawings. I found a C8, on one of the schematics, connected in series with R75 (100 ohm) which is 100pF rated at 1kV.
  • ss0
    ss0 Posts: 2
    Thanks!
  • You're welcome, good luck with your project!
  • pavelsim
    pavelsim Posts: 1
    edited December 26
    Hello everyone!
    I'm trying to fix the issue with a very distorted sound especially in auto mode. The led color is looks strange as well - white and orange. Could anyone please share a schematic diagram for PSW110 if possible? It seems like the issue is with the control board. Thank you in advance
  • Schematics sent...
